Longboardluv Samba Member
Joined: September 23, 2014 Posts: 934 Location: Austin TX
Posted: Tue Jun 07, 2016 5:48 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
nice welds
got the seam sealer down hoping to paint to night! |
Posted: Tue Jun 07, 2016 6:34 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
the clutch pedal finished drying so i threw the rubber thing on
and installed it on the bus!
now I have three pedals and a shifter!
all the old glue needed to come off
so i hit it with the wire wheel
The apron that came with my bus is green, covered in gunk and kind of beat up. I'm using the EasyOff method of removing everything off of it. Then I'll bang it into shape and paint it with the remaining red color that I used to paint the trans area |
Posted: Fri Jun 10, 2016 5:49 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
still have a few small holes to weld up. these are in the bulk head behind the wheel well on the right side
after easy offing the apron i cut out the remainng seal
then i hit it with the wire wheel, wire brush and brake cleaner to get all the caked on grime and old paint off. I probably would have kept the green if it wasn't so banged up, grimy and rusty.
hanging from the painting tree
i found this, it's a kind of close match but the previous stuff i had used is closer
it looks kind of neon red in this picture! |
MicBergsma Samba Member
Joined: October 25, 2015 Posts: 222 Location: Maui Hawaii
Posted: Fri Jun 10, 2016 6:56 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
right on! _________________ 1967 VW Bus walk-thru 21 window deluxe
Restoration series on YouTube right now!
YouTube videos > http://bit.ly/2g0E5b5
Instagram > http://bit.ly/2gHjIOV
Facebook > http://bit.ly/2Q9atMs |
khalimadeath Samba Member
Posted: Fri Jun 10, 2016 8:02 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Has your bus become storage for the kids toys? lol _________________ The United States Constitution
(c) 1787. All Rights Reserved
1970 Bus Westfalia
1964 Kombi |
Posted: Fri Jun 10, 2016 8:04 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
khalimadeath wrote: |
Has your bus become storage for the kids toys? lol |
very much so, the kickball and basketball fit nicely behind the tail lights. I can get both their bikes in the engine bay and their scooters go in the cargo area. having two dubs in the garage makes have to utilize the space efficiently! |
Posted: Fri Jun 10, 2016 8:10 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Longboardluv wrote: |
LMAO nice! _________________ The United States Constitution
1970 Bus Westfalia
1964 Kombi |
Posted: Fri Jun 10, 2016 9:14 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
haha that's what I thought! _________________ 1967 VW Bus walk-thru 21 window deluxe
Posted: Mon Jun 13, 2016 6:20 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
The seat covers and foam came in from SewFine!! Oh man I can't wait to get these all put together.
Heaterboxes and intake manifold freshly sandblasted
Hanging more parts on the painting tree! This time heater boxes and intake manifold. Duplicolor engine enamel de1650 really is nice!
found this little blower at Harbor Freight. It' moves a lot of air and has two plugs on it it. So now it's my new work buddy. Goes where every I go now that it's summer in Texas |
Posted: Wed Jun 15, 2016 6:24 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
I've been trying to get ready for the next time my welder comes over.
Trying to hammer this piece back to straight so that it lines up. I'm cleaning off all the paint and rust to prep for welding
This area by the battery tray is all apart. You can see where it separated.
this is where the new battery tray will weld up with the old metal
The previous owner had mounted some bracket from the rear tray into the engine bay. these will get plugged up too
my motor is coming along! Alternator kit has been ordered and clutch/pressure plate. Won't be long now |
Posted: Thu Jun 16, 2016 5:53 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
since i don't have any keys i'm hoping to have some cut based on the code that is on the locks.
i took down the parcel tray and got the ignition out farily easily. I had to cut one of the bolts off that holds the stearing column to the dash though
this is my buggered up rear hatch lock. it's a two year only part I believe (64-65) that looks like they are kind of hard to find. so if anyone might have one , let me know! thanks |
Posted: Thu Jun 23, 2016 6:14 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Big thanks to GLHTurbo for sending me these inner bumper brackets! Love it when team aircooled comes together to help one another! I'll be cutting these out and straightening them up. Then they'll get welded into my bumper, which is missing them.
Posted: Fri Jun 24, 2016 5:48 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
It was time to look into the fresh air vent to see why it wasn't working.
I had heard that these 14 little screws can be difficult so I had been pb blasting them for a few weeks
it was dirty in there, all the rubber seals are toast . You can see two little screws that hold the bar down, I wasn't able to get those out.
It's interestign how these flaps work, you turn a knob and they either direct air to the front passengers or to the back
They will get new rubber seals glued to them
they too get cleaned up on the wheel and hung from the painting tree
I wasn't able to the front flap out that opens and closes to let air in from the front. The little screws holding it in are crusty and will need a few days of soaking. |
Posted: Sun Jun 26, 2016 5:45 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
I was finally able to get the little set screw out of the flapper. I then drilled out all the rivets and will be ordering pretty much everything that WW sells to rebuild the vent system. Someone mentioned using regular rivets as opposed to pop rivets to repair this. Does anyone have any opinion on the subject?
it was nasty!
drilled apart
after hitting it on the wheel it too hung from the painting tree!
the it was time to clean the narrow vent. it had a very thick lay of dirt from years of sucking in air from the road. I attached wires to a long stick and then to the drill. It worked pretty good to kind of knock a lot of the dirt free
after some back and forth with the leaf blower and vac it stapled a rag to a long paint stirrer
after a few times i was happy with how it came out. You know rebuilding this air vent is exactly the kind of stuff I love. It a little no pressure project that isn't necessarily hard. It just something you get to learn how to do and get it done. Then, when I finally get to start enjoying Helga on the road I'll look up and remember all the little projects it took to get her going again!
I figure I hadn't posted a wide shot of her in a while. I think is is about as "apart" as she'll be. From now on, I think I'll be putting pieces back onto her.
Thanks again to GLHTurbo for sending me these. I got the brackets cut out and cleaned up as well to go into my bumper.
I also got my safari's from Wolfgang Int.! I'm so excited. Hope to start the cargo floors, rear seat/bed and seat belts soon! Then i'll be able to put the tank and trans back in. Which is closer to getting a motor in her! |
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Mon Jun 27, 2016 6:58 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
No problem, glad to see they're getting used. Looking good. _________________ 1957 Beetle
1966 Bus |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14266 Location: Casa de Oro, California
Posted: Mon Jun 27, 2016 9:34 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Surprising how much dirt you got out of there. |
silkvw Samba Member
Posted: Mon Jun 27, 2016 7:53 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Nice job on the fresh air vent Matt!
I think I need to check and clean mine now. _________________ '64 single cab Big Bend Bus Bash 2015 '16
'59 camper BBBB 2017 '18 '19 '20 '22 New Mexico
'70 Ghia........Bonneville,........TX Mile,........142 mph......(sold)
https://www.thesamba.com/vw/forum/viewtopic.php?t=641871&highlight= |
Posted: Tue Jun 28, 2016 2:18 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
General Grabber AT2 27 X 8.5 R14s, so meaty!
Posted: Thu Jun 30, 2016 5:59 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
I got the package tray out and one of the bolts that hold the steering column to the plate had broken off at some point. I sprayed with with pb blaster and attempted to extract the old bolt with an extractor but that didn't work so then i tried tapping it and failed at that. So i just drilled it out and will put a nut and nut and washer on there.
I like the patina on the tray but don't want rust dust getting on stuff i put in there so i decided to clean it and clear coat it.
