Pinetops Samba Member
Posted: Sat May 07, 2016 5:29 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
I love the bus, congrats. Ill stay tuned for your updates. _________________ "A rolling bus gathers no rust." |
Longboardluv Samba Member
Joined: September 23, 2014 Posts: 934 Location: Austin TX
Posted: Sun May 08, 2016 6:02 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
We were able to cut the shift rod coupler off but now the two tubes are fused together. I've been hitting them with a torch and am trying to twist them apart using two pipe wrenches, but it's not budging any suggestions??? I'd like to reuse the front one, but i know I could it off and get a new one.
got the trans out and cleaned up, new trans mounts front and rear, need to replace right side seals. will but new boots on when it's back in the bus
shiny new tie rods! still need to do the drag link
khalimadeath Samba Member
Posted: Sun May 08, 2016 8:04 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Look great! If only there was an easy way to strip all the dirt and rust from the bottom and recoat. |
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Sun May 08, 2016 12:17 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
khalimadeath wrote: |
There is, wire wheel and such, Ospho, clean, Zero Rust Red, Zero Rust gray:
(I guess "easy" could be debated. LOL)
Posted: Sun May 08, 2016 5:54 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
okay, zozo your bus is too damn pretty underneath that's all i gotta say about that!!
after a couple of tries i got both pieces glowing red and let them cool on their own
then after a couple of hours I pb blasted them and used the pipe wrenches and they finally started moving a little. I just kept working them until they came apart!
it felt so good to get those separated and see them out of the bus!
had this little brush for the dremel which was perfect to clean out the gunk, i also hit the whole outside of the front shift rod on the bench wire wheel to get all the old paint off
cleaning everything (including nuts and bolts) on the wire wheel
then repainting it - this is the shifter boot
front wheel axel covers
This is front shift rod with it's first coat of paint.
it was time upgrade some of my tools, these are 1/2 (which I didn't have before) and will end up going in the bus' road tool kit. 25% off each one at Harbor Freight! |
Malokin Martin Samba Member
Posted: Sun May 08, 2016 6:03 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Whoa... I normally think HF stuff is total crap... But the color thing is pure genius. Nice work on the bus also |
silkvw Samba Member
Posted: Sun May 08, 2016 6:42 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Embrace the rust and enjoy your bus. _________________ '64 single cab Big Bend Bus Bash 2015 '16
'59 camper BBBB 2017 '18 '19 '20 '22 New Mexico
'70 Ghia........Bonneville,........TX Mile,........142 mph......(sold)
https://www.thesamba.com/vw/forum/viewtopic.php?t=641871&highlight= |
Col_Forbin Samba Member
Joined: November 25, 2011 Posts: 84 Location: Austin, Texas
Posted: Mon May 09, 2016 11:44 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
I picked up those pop outs last night so they are in town now... let me know when you'd like to meet up n get them! _________________ Goin' where the climate suits my clothes
Levon the 66 Westy:
http://www.thesamba.com/vw/forum/viewtopic.php?t=655780
71 Deluxe Bay |
Posted: Tue May 10, 2016 4:43 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
hell yeah Silkvw! Thanks Col, I'll text you tonight!! THANKS
the shuttle cocks on the shift rod with a little grease ready to go back in
I had cleaned out the tunnel with a leaf blower and carb cleaner
rear rubber seal installed, also with a little grease
new MC vs Old
got the old one out
this is the front of the shift rod not the sun light coming through the floor, i'll have a lot of work getting the cargo floors all sealed up
now cleaning up the ends of all the hard lines soon i'll be squirting brake cleaner through them all and putting it all back together. |
Posted: Tue May 10, 2016 5:27 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
zozo wrote: |
That looks great. How has it held up? _________________ "A rolling bus gathers no rust." |
zozo Samba Member
Posted: Tue May 10, 2016 2:17 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Fine so far. No issues whatsoever. I've not done the center section, yet. I'm claustrophobic and just can't. I don't have a lift and just can't bring myself to be that far under it. (It us what it is.)
In hopes that it'll help, I want to check out a lift in the $2-3k range. |
Posted: Tue May 10, 2016 2:35 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Good deal, I'll probably do the same to mine then. The finish is nice, you can apply it in sections and its durable, sounds perfect for me. _________________ "A rolling bus gathers no rust." |
Posted: Thu May 12, 2016 5:55 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
The bolts holding the shifter were a little toasty, so i went ahead and replaced them.
Was able to figure out the correct way to get the front shift rod all assembled and ready to go back in, but had a really hard time threading the rear bolt
turns out I need to re-thread the damn thing, you know what they say about reproduction crap.
cleaning up the shifter
nice and clean now, ready for a little grease
Just need to throw the boot on and I'm good. I also got a shift extension from bullidriver steal works but i'll put that on later. Next I'll install the shift rod coupler and get back on the brakes. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Thu May 12, 2016 8:49 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
It's amazing how "one with your bus" you feel when the action of shifting is right on click-click.
Don't know 'bout yours but something I've discovered is the replacement nylon shift guide get real sticky especially against paint and once the grease dissipates. I end up going under the bus and just expand the spring clip off the nylon guide and leave it on the shift rod out of the slide path.
I guess you could spread the spring clip to not have it be so tight but anywho fwiw. |
Posted: Fri May 13, 2016 5:53 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Isaac helped me clean the spring plate with the dremel tool
I got all the lines disconnected an the ends cleaned up, then sprayed brake cleaner through them all
brake lines all back together and ready to go! I still plan on cleaning all the gunk off this area
my friend eric hooked me up with his old rear glass!
anti-seize on the shift rods
they are back together with the coupler and grub screw, just need to safety wire it in. |
Posted: Sun May 15, 2016 4:06 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Friday I ordered my front seat cushions and covers from SewFine. They are going to look really close to stock (mesh grey & black) It's going to be about five weeks before they make it in but that's okay because there's work to be done!! Made quite a bit of progress this weekend. The plan was the clean the wishbone area and transaxle with easy-off. It ended up taking off the paint, Whoops! So found two very similar colors in home depot and ended up going with "Matte Harvest Orange"
shiny exposed metal, whoops
ended up getting a 27mm wrench (adding to the tool bag) to remove the trans support so it too can be cleaned and painted
all primed up
since this is an area that no one will really see much I'm okay with it just being a close match. When I go to paint the nose, I'm actually going to have the paint color matched and put in a spray can.
ended up going with option #1 on the top
i think this ended up being a good "mistake" as now the area is really clean
after hitting it with the wire brush and mineral spirits, it too was hung from the painting tree!!!
Ended up cutting out what was left of the battery tray using an angle grinder and mostly the dremel.
This actually went really well and I'm really close to having it fit nicely. I plan on getting in there with wire brush and taking all the surface rust off. Then we'll weld in the new tray. #OneStepCloser ! |
Posted: Tue May 17, 2016 10:48 am Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
I'm trying to figure out a way to get both heater boxes pumping heat to the front. I'm going to have to make something similar to this or find a flexible pipe that can be put it. It's going to involve cutting the floor and welding.
I found these pictures of someone that did this same thing recently.
Posted: Wed May 18, 2016 1:02 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Made a little progress on the accelerator pedal. Realized that the whole linkage is pretty much toast so I'll be ordering a rebuild kit from Wolfsburg West. Was able to get the pedal pin punched out, but that needs to be replace. The pedal spring broke off at the base, so i need to figure out how to get that little booger out!
this all needs to get replaced
took a few good hits with the hammer to punch out the pin
this will get repainted black soon
underneath that little area is the bottom piece of the spring that needs to come out. |
BarryL Samba Member
Posted: Wed May 18, 2016 6:50 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
Longboardluv wrote: |
The pedal spring broke off at the base, so i need to figure out how to get that little booger out! |
Dang. Is it open at the top like at the bottom? |
Posted: Wed May 18, 2016 6:59 pm Post subject: Re: "Helga" Matt's 65 bus restoration thread - Austin TX! |
BarryL wrote: |
It's supposed to be. I've already tried hitting it with the torch and spraying penetrating oil. So far it isn't coming out I really don't want to have to cut that thing off |
