1954 RHD Barndoor Samba - Back To Stock Restoration
Air Kraft
Air Kraft is offline
PostPosted: Fri Apr 29, 2016 8:59 am    Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration Reply with quote
More little tricky areas...
www.air-kraft.com
Air Kraft
PostPosted: Fri Apr 29, 2016 9:08 am    Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration Reply with quote
www.air-kraft.com
Air Kraft
PostPosted: Fri Apr 29, 2016 9:16 am    Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration Reply with quote
www.air-kraft.com
wcfvw69 Premium Member
Samba Purist
wcfvw69 is offline
PostPosted: Fri Apr 29, 2016 9:25 am    Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration Reply with quote
Beautiful, quality work and craftsmanship. This bus is lucky to have found both an owner to invest in repairing it right and a shop with this talent.
My question for you is this. What are you doing to treat the rust inside the frame rails and other boxed in sections? Obviously the welds are bare metal inside after they are closed up. In many of your photo's of the frame rails opened up, you can see the corrosion/rust inside them.
Keep up the great work and updates!
The Samba member since 2004.
Air Kraft
PostPosted: Fri Apr 29, 2016 10:33 am    Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration Reply with quote
Hi Bill. Thank you for the kind words. We are treating any bad rust as a cancer and cutting it out completely. The light surface stuff is being treated with soda blasting, then phosphoric acid and then finally a heavy zinc coating. I'll probably upload some pictures of this process when time allows. I have a million photos of the work done, but I'm adding only a fraction to keep the thread from being overly boring.
In future updates there'll be lots of Pullmax, Eckold and English Wheel action!
Have a good weekend folks!
Matt
www.air-kraft.com
Air Kraft
PostPosted: Fri Apr 29, 2016 11:48 pm    Post subject: Re: Barndoor Samba - Back To Stock Restoration Reply with quote
[quote="RockStock"]
Scotty wrote:
good detail
why are they there?
is it bracing/strengthening for the receptive threads of the beam bolts?
Yes, they are exactly that. On our bus the arc welds were extremely rusty and porous. They needed to be completely repaired and redone. The reason they aren't finished yet is I'm having to borrow an arc welder to replicate the authenticity with 100% accuracy. Not many shops use arc any more including us, so tricky to find! Very Happy
www.air-kraft.com
Scotty
Scotty is offline
PostPosted: Tue May 03, 2016 6:12 am    Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration Reply with quote
It's really interesting to see photos inside places you can't normally see.
Great fab skills Mr K as always
Air Kraft
PostPosted: Tue May 03, 2016 9:34 am    Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration Reply with quote
Thanks Scotty 👍
www.air-kraft.com
Air Kraft
PostPosted: Mon May 09, 2016 11:21 pm    Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration Reply with quote
Another tricky task: the inner window skins had perforated, so needed replacing. As no commercial panels are readily available, we decided to make our own; to exact original spec. The panels have a tricky radius return, which is impossible to make on a folding break...
To do the job with 100% accuracy, we cut a small section out from a corner and side window, and then cast two pairs of Pullmax dies:
www.air-kraft.com
Air Kraft
PostPosted: Mon May 09, 2016 11:26 pm    Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration Reply with quote
The panels were then radiused with the special dies (corner windows) and then welded in and planished/hand finished:
www.air-kraft.com
andre b
andre b is offline
PostPosted: Tue May 10, 2016 6:22 am    Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration Reply with quote
Nice to someone pay attention to detail.amazing work!! Very Happy keep the pics flowing
Samba Purist
wcfvw69 is offline
Beautiful work!
Did you have the dies made or? Love the attention to detail.
Air Kraft
PostPosted: Tue May 10, 2016 8:53 am    Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration Reply with quote
Thanks guys!
Bill: we make the dies ourselves at Airkraft. We cast them specifically for any forming job necessary.
Thanks, Matt
www.air-kraft.com
Samba Purist
wcfvw69 is offline
PostPosted: Tue May 10, 2016 8:53 pm    Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration Reply with quote
Air Kraft wrote:
Thanks guys!
Thanks, Matt
Nice...I'd love to see some pictures of that process if you're will to share. Very Happy
vwhelmot
vwhelmot is offline
PostPosted: Tue May 10, 2016 11:54 pm    Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration Reply with quote
Yeah, get sharing ! lol :D
Air Kraft
PostPosted: Thu May 12, 2016 1:11 pm    Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration Reply with quote
Well, I have to say that Sam excelled himself today! Since joining Airkraft he has taken to every challenge thrown his way with gusto. Today's task was to make a lower door skin for the Barndoor Samba. Now you may ask why didn't we just buy one? The simple answer is that there aren't any out there that fit as well as a custom wheeled item. We take pride in being 100% as good as we can be. We just love hand crafting panels whenever we can! Now the lower section of the cab door is a very difficult panel with a varying compound curve in both directions, requiring some tricky English Wheel work...
www.air-kraft.com
kilgore
kilgore is offline
PostPosted: Fri May 13, 2016 3:58 am    Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration Reply with quote
absolutely incredible workmanship Matt! love seeing all the fabrication photos keep them coming!!
Air Kraft
PostPosted: Fri May 13, 2016 11:31 pm    Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration Reply with quote
Thank you Kilgore 👍
Don't worry, there's plenty more pictures to follow Wink
www.air-kraft.com
EmpiGT
EmpiGT is offline
PostPosted: Sun May 29, 2016 4:34 pm    Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration Reply with quote
Great work.. PM sent, could use some metal you made dies for.
Air Kraft
PostPosted: Wed Jun 01, 2016 11:31 pm    Post subject: Re: 1954 RHD Barndoor Samba - Back To Stock Restoration Reply with quote
Hi Empi. Yes, we can make and supply you the necessary rear corner and side window inner sheet metal. Where are you based?
Regards, Matt
www.air-kraft.com
Page 3 of 5
