Colorjazz Samba Member
Joined: January 12, 2016 Posts: 11 Location: Montreal
Posted: Fri Apr 15, 2016 9:23 am Post subject: Horn replacement... Easy? |
Hi !
I have a very rusted horn on my 1991 Vanagon. I sounds like the old 1930's horn. Its actualy cool but not at all convincing when being cut off on the highway...
Is it possible to just change the horn without opening the dash and all? Idealy, I would love to just unscew, unplug, replace, plug and screw... I would order the Gowesty replacement horn...
What do you think? |
Forthwithtx Samba Member
Joined: July 14, 2014 Posts: 717 Location: Fort Worth
Posted: Fri Apr 15, 2016 9:36 am Post subject: Re: Horn replacement... Easy? |
Mine was a bolt and a couple connectors under the bumper.
Picked up the horn at the local parts store. Universal item. _________________ Cheers!
-Karl
'84 GL with 2001/2004 Subaru 2.5L |
metropoj Samba Member
Posted: Fri Apr 15, 2016 9:38 am Post subject: Re: Horn replacement... Easy? |
Well, it is probably best for you to 'find' the horn first. Have someone honk it while you listen.
Then once you find it, compare what you find against your mechanical abilities to determine if you are 'capable' of replacing one.
Hard to say depending on the person.
The first concern here would be that you think the horn is in the dash. _________________ John.
86 TiiCo powered Westy. |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Fri Apr 15, 2016 9:48 am Post subject: Re: Horn replacement... Easy? |
I use Hella dual tone horns with Jay Brown horn relay harness... loud and nice tone - for ref. similar to BMW 5,6,7 series dual tone horn, I think BMW use the same in black.
installation on the outside at the original horn location, no need to touch anything under the dash.
newfisher Samba Member
Joined: January 05, 2012 Posts: 1764 Location: The wet spot--Oregon
Posted: Fri Apr 15, 2016 9:50 am Post subject: Re: Horn replacement... Easy? |
metropoj wrote: |
The first concern here would be that you think the horn is in the dash. |
You Sir, have a calmness about you that is admirable |
DwarfVader Samba Member
Joined: July 28, 2015 Posts: 646 Location: Missoula, MT
Posted: Fri Apr 15, 2016 10:22 am Post subject: Re: Horn replacement... Easy? |
yeah... if you're going to upgrade your horn, put get the relay harness it will keep you from burning anything out. _________________ - oderint dum metuant -
I'll find my van someday, or it will find me. |
yiucycle Samba Member
Posted: Fri Apr 15, 2016 10:38 am Post subject: Re: Horn replacement... Easy? |
+1 on horn relay. Stock horn wiring use the horn button as a ground with super long wire. With the horn relay, the horn button only trigger the relay and shorten up the ground loop. _________________ 1980 2.8LV6 Fiero ASI/Riviera Vanagon
"there is no point in being embarrassed of all the stupid shit i done and will continue to do"
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Fri Apr 15, 2016 10:58 am Post subject: Re: Horn replacement... Easy? |
Aloha
tp |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Fri Apr 15, 2016 11:01 am Post subject: Re: Horn replacement... Easy? |
And with a relay on that circuit you can go with a horn that will make them wet their pants.
I use the horn quite sparingly but when I do I want it to be noticed. |
chase4food Samba Member
Joined: February 27, 2016 Posts: 636 Location: PNW im Amerika
Posted: Fri Apr 15, 2016 3:13 pm Post subject: Re: Horn replacement... Easy? |
Colorjazz wrote: |
Hi !
No matter what you do, Vanagons never get any respect on the road, and a bull horn ain't gonna change that. I got cut off twice today going shopping by this same minivan weaving in and out of traffic, and each time endangering someone going like bat out of hell.
I kept my cool and drove efficiently and effortlessly. Guess what. About 3 miles from where he first cut me off cold and cut off countless number of cars, I pull up next to him at a red light. I gave him a piece of my mind and he just refused to make eye contact as he knew what he had done. It gets better. As I pull ahead of him, I saw he is one of those scum that sports a handicap sign when in fact he ain't one. I saw all too many time these scums even have fake guide dogs.
Oh! Back to the VW horn. I won't change the horn as it is the best way to say hi to a fellow VWer on the road. Just the other day I passed these nice couple on the highway in turtle lane in a 60's bug. I did my double beep beep and he immediately acknowledged with hand gesture before he turned his head and looked. _________________ - Vince 飲食玩睡
what Isolde wants Isolde doesn't always get, 4 I know what is best for her - Liebe macht frei |
Posted: Fri Apr 15, 2016 3:21 pm Post subject: Re: Horn replacement... Easy? |
chase4food wrote: |
... As I pull ahead of him, I saw he is one of those scum that sports a handicap sign when in fact he ain't one. ... |
In a parking lot I confronted one of those people I thought might be using a handicap placard without cause. I asked him what his handicap was and he replied, "mental". I smile and replied, "I thought so. Do you need help?"
Aloha
tp |
Posted: Fri Apr 15, 2016 3:32 pm Post subject: Re: Horn replacement... Easy? |
Tom Powell wrote: |
chase4food wrote: |
Aloha
tp |
Seeing these scum of mankind makes my blood boil. _________________ - Vince 飲食玩睡
Timwhy Samba Member
gene l Samba Member
Joined: August 31, 2013 Posts: 136 Location: LOS OSOS,CA.
Posted: Sat Apr 16, 2016 7:57 am Post subject: Re: Horn replacement... Easy? |
Thanks for not showing ignorance by saying on the subject, and thanks for the diagram, it helps me with my problem.
gene l, disabled veteran. |
kamzcab86 Samba Moderator
Posted: Sat Apr 16, 2016 9:33 am Post subject: Re: Horn replacement... Easy? |
Colorjazz wrote: |
So easy a chick can do it...
Like others, I removed the wimpy OEM horn (which didn't even turn the heads of those sitting outside a restaurant when I blew it for some jackass who ran a parking lot stop sign), and replaced it with dual-tone horns and a relay from my local O'Reilly. Didn't touch the dash during installation.
The original horn is mounted to the backside of van's nose, passenger side, basically behind the bumper.
Colorjazz wrote: |
I would order the Gowesty replacement horn... |
Which horn? The air horn, or the OEM horn? If the latter, forget it, unless you wish to keep the cute little, useless "toot" sound.
If going with GW's air horn, here are the install instructions: https://www.youtube.com/watch?v=jIxwSEtNFsc .
0to60in6min wrote: |
I use Hella dual tone horns with Jay Brown horn relay harness... loud and nice tone - for ref. similar to BMW 5,6,7 series dual tone horn, I think BMW use the same in black. |
FWIW, the VW Cabriolets (and perhaps Sciroccos, etc.) came with dual-tone Hella horns... relayed from the factory. When it comes to Vanagons, I've got two rhetorical questions:
1) Why the heck didn't VW switch the vans to CE1 electrics in 1983, when all other models (except American-built Rabbits) got CE1??
2) Since the later vans were finally switched over to CE1, why the heck did VW not mount dual-tone horns on these 4000-pound beasts with a relay in position #6 like other VW's?
Cheapskates... _________________ ~Kamz
2016 Golf GTI S
Posted: Sat Apr 16, 2016 9:48 am Post subject: Re: Horn replacement... Easy? |
@ kamzcab86
don't scratch your head too much over why VW didn't do this or that or should do this and that on vanagon.. otherwise you won't have many hair left...
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Sat Apr 16, 2016 10:19 am Post subject: Re: Horn replacement... Easy? |
On a recent trip to the U-Pull boneyard, I pulled a few of my favorite horns at $2 apiece. Find 70s-80s Cadillacs. They are beautifully tuned and very loud. They actually sound reminiscent of a yacht horn for elegance and I think that was intentional. I have a few sets sitting on the work bench and will be taking a family vote on which pair to install. The relay is a good idea - thanks.
Over the years I've tried air horns but they suffer from a couple handicaps. One is space and time to install pump, long bulky horns, and airlines. Two is the delay it takes when you press the button and the half second to spool up the pump and get the nice tweet sound - makes a little kind beep impossible. Three is that when they do get up to full sound they are too harsh for many uses.
I have the Hella Supertones on a couple cars and the note is nothing special but durability has been good at 250,000 miles so far.
Doug _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Sat Apr 16, 2016 10:28 am Post subject: Re: Horn replacement... Easy? |
yes.. the Hella Supertones are not nice as the Dual tone..
not as loud as the Dual Tone and the tone is not well balanced, too much in the high and not enough in the low |
Posted: Sat Apr 16, 2016 12:58 pm Post subject: Re: Horn replacement... Easy? |
This one for less than 16 bucks at the local parts store.
http://wolo-mfg.com/model-300-2t-disc-horn-low-tone.html
They have high tone and low tone. The low tone is plenty loud and perhaps not as "meep meep" sounding as the original. My wallet gets kinda weary of going top-shelf all of the time for parts. _________________ Cheers!
-Karl
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4097 Location: East Kootenay, British Columbia
Posted: Sat Apr 16, 2016 1:20 pm Post subject: Re: Horn replacement... Easy? |
Keep one thing in mind when contemplating changing the sound of your horn. Perception is important. If your horn sounds like a Cadillac or Mac truck, that is what the other driver will expect to see, and may not notice it's your Vanagon that is trying to get their attention. That split second of indecision/misperception may be all it takes to have an accident.
Having the sound of a european vehicle (that is loud and clear) may get better attention. Perhaps a fresh Vangon horn, with a relay for full power? Although I do like the idea of the duel tone BMW type. Hmmm… mines in good working order, but another upgrade may be in the making . _________________ Currently:
