Schnage Samba Member
Posted: Wed Apr 13, 2016 12:47 pm Post subject: 28 PCI Carb with Judson |
What nozzel size do you use in your carb with judson?
I think i have to test some other sizes? |
Posted: Fri Apr 22, 2016 11:14 pm Post subject: Re: 28 PCI Carb with Judson |
Schnage wrote: |
No one no idea?
Hmm, so try and error maybe a choice.... |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13958 Location: Southampton U.K.
Posted: Sat Apr 23, 2016 2:13 pm Post subject: Re: 28 PCI Carb with Judson |
Thx John, i will try, i have orderd some jets to try some different cominations... |
Posted: Sat Jun 18, 2016 6:54 am Post subject: Re: 28 PCI Carb with Judson |
So now i try a 130 main, and a 135 air correction jet, maybe it runs better....but the trouble with starting hot will this setup not fix i think.....
I am waiting for the pertronix maybe that will help al little bit...
Markus |
Posted: Sat Jun 18, 2016 6:57 am Post subject: Re: 28 PCI Carb with Judson |
Posted: Thu Jun 23, 2016 10:05 am Post subject: Re: 28 PCI Carb with Judson |
Always the same, 20 kilometer autobahn, and engine wont go further, when i stopped the engine starts first after 1 hour........ |
Posted: Sun Jun 26, 2016 1:54 am Post subject: Re: 28 PCI Carb with Judson |
Would maybe a spacer under the carb helps? I thinking abaut a electric fan to blow fresh air to the judson and the carb .... Dont know.... |
busbusbus Samba Member
Posted: Wed Jul 20, 2016 11:38 pm Post subject: Re: 28 PCI Carb with Judson |
is there a good spark? |
Posted: Mon Aug 15, 2016 4:13 am Post subject: Re: 28 PCI Carb with Judson |
Today i removed the Judson Magneto and use a Flamethrower, it runs better, but when hot it wont start as before. Sometimes when run on autobahn it want take gas and wont idle up. There are some "explosions" from exhaust.... |
Starbucket Samba Member
Posted: Wed Aug 31, 2016 2:20 pm Post subject: Re: 28 PCI Carb with Judson |
Pull some plugs and see if they are white (bad = very lean) or worse covered with tiny specs of aluminum (very bad, that's bits of molten Aluminum = detonation from too much advance and too lean a mix trying to burn a hole in the pistons). The only way to tune a super charged motor without a dyno is to mount a pyrometer probe near the exhaust port and adjust till exhaust doesn't exceed 900 F under WOT. Aluminum starts going away at 1300 F. |
Posted: Sun Sep 04, 2016 12:48 pm Post subject: Re: 28 PCI Carb with Judson |
It was a problem wit the ignition, the cap from distributor was worn, curious that i didn't seen it before..... I installed a pertronix ignitor, a new coil, cap and rotor, now i have no problem....
Look at the thin black line....there goes the power that is missing on the plug... |
Telephunken Samba Member
Joined: November 23, 2004 Posts: 274 Location: Northern California
Posted: Sun Sep 25, 2016 4:58 pm Post subject: Re: 28 PCI Carb with Judson |
I was having a similar issue when I upgraded my carb from the 28PCI to a 32PCI. This was recommended to me to let the supercharger "breathe" better. Im running a Speedwell Pepco SC. It was popping and flaming out the carb, and ran like crap. was running way too lean. I had to switch up the jets, the air correction most importantly. I think its a 140 now. Then I upgraded my pilot to a 55 from a 40 which really helped on the bottom end RPM's, then last using a 125 Main jet. Now after a couple weeks of good running now im dealing with a new issue. loss of fuel pressure I think.... UGH |
Terry Gaudet Samba Member
Joined: March 11, 2004 Posts: 399 Location: New Brunswick, Canada
Posted: Thu Mar 07, 2019 1:55 pm Post subject: Re: 28 PCI Carb with Judson |
Quick question. Do most of you keep the manual choke hooked up with a Judson install or is there too much in the way to make it work? _________________ Terry Gaudet
1950 Beetle Standard
1955 Canadian Custom
1956 Kombi w/SO23 kit
1965 Kombi walkthrough
1965 Double Cab |
