Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Mon Jul 11, 2016 7:59 am Post subject: Re: Engine fire, even after everything is done right |
Bus Depot offers 0280170402 as a CSV for a 1983 Rabbit. Looks like they offer a plethora of CSV's beyond that one.
We might just take a look at the variety and select one less likely to fall apart or leak, maybe search out online Rabbit forums to get a read on any associated problems.
As far as securing the wiring harness, I would add extra plastic wire loom on the outside of mine where it came in contact with other parts and securing it with several plastic zip ties to guard against vibration.
WARNING: Opinion follows...
VW engineers were not tasked with the Apollo Program... they were tasked with developing something reliable enough to generate sustainable profit. |
BayCreamPuff Samba Member
Joined: August 10, 2015 Posts: 769 Location: Oakland, CA
Posted: Mon Jul 11, 2016 8:14 am Post subject: Re: Engine fire, even after everything is done right |
Not sure the size, but you'll also need the hollow bolt and copper washers seen in this diagram and photo.
_________________ Cream Puff
'79 CA Stock FI Deluxe Campmobile
Earl Grey
'87 GoWesty 2.2 Westfalia
Marsha Mellow
'00 Eurovan VR6 Full Camper |
Max Welton Samba Member
Joined: May 19, 2003 Posts: 10697 Location: Black Forest, CO
Posted: Mon Jul 11, 2016 10:20 am Post subject: Re: Engine fire, even after everything is done right |
Wasted youth wrote: |
Yes.
I (we?) do many things to our individual cars that would have driven the cost of these (as new) cars out of the range of profitability. I insist on a real oil filter. And many other things.
Max _________________ 1967 Type-3 Fastback
Home Stretch https://www.thesamba.com/vw/forum/viewtopic.php?t=767836 |
Tcash Samba Member
Posted: Mon Jul 11, 2016 3:01 pm Post subject: Re: Engine fire, even after everything is done right |
Took a trip to the local pick-n-pull hoping to pull a CSV off an 86 Audi 4000. No such luck. Every car I looked at with an accessible CSV was removed (duh it's a $200 part). I eventually found one hiding under the intake manifold of a 91 Volvo 240. Took a lot of patience to get that little bastard out, but boy was it rewarding when it did.
There seem to be a lot of these cars at pick-n-pulls. I bet many of them still have their CSV since it's so awkwardly located.
Bosch Part # 0 280 170 445
Earl Grey
Marsha Mellow
cmonSTART Samba Member
Posted: Mon Jul 11, 2016 3:24 pm Post subject: Re: Engine fire, even after everything is done right |
Looks a lot bigger than stock. _________________ '78 Bus 2.0FI
de K1IGS |
Posted: Mon Jul 11, 2016 3:28 pm Post subject: Re: Engine fire, even after everything is done right |
Why not skip the banjo fittings and use a copper t-fitting with M8X1 male threads and 7mm barbs. Something like this:
Earl Grey
Marsha Mellow
Joined: January 01, 2007 Posts: 16883 Location: sticksville, ct.
Posted: Mon Jul 11, 2016 3:45 pm Post subject: Re: Engine fire, even after everything is done right |
here's my solution
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Mon Jul 11, 2016 3:46 pm Post subject: Re: Engine fire, even after everything is done right |
Nice work, BayCreamPuff!
Looks like it bolted right into the plenum no problem. Will it all fit up on top of the engine?
How much did Pic-n-Pull charge? Even if it was $35, and you added $30 for a professional ultrasonic cleaning and flow test, it would be a bargain.
Now that you had it in hand, after looking at the design and mount up, were you left with the impression that this route might be a safer improvement than what we are currently faced with... or do you think the benefits might be negligible? |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Mon Jul 11, 2016 4:10 pm Post subject: Re: Engine fire, even after everything is done right |
Fantastic it at least bolts up!
Creampuff, what did you search for that threaded t fitting? I can find anything with all search combinations? What did PaP hit you up for the injector? _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone)
Posted: Mon Jul 11, 2016 4:14 pm Post subject: Re: Engine fire, even after everything is done right |
Looks like it bolted right into the plenum no problem. Will it all fit up on top of the engine? |
Here's a side-by-side photo
Here it is resting on top of the existing one
How much did Pic-n-Pull charge? Even if it was $35, and you added $30 for a professional ultrasonic cleaning and flow test, it would be a bargain. |
They asked me what it was and I said a fuel injector. $6.99 + core deposit of $0.99 + tax. Guy behind me said I should have just put it my pocket and walked out.
It certainly feels a lot more solid than the stock one. If we can figure out a good way to mount it I think it could be a good alternative. One issue that comes to mind is the way the fuel lines will connect to this CSV. Even with a T of some sort (banjo or brass fitting) it will need to be angled at 45 degrees to allow for the harness to plug in. _________________ Cream Puff
Earl Grey
Marsha Mellow
Posted: Mon Jul 11, 2016 4:44 pm Post subject: Re: Engine fire, even after everything is done right |
Total score at the junkyard! For that price, maybe a little destructive testing and/or slicing a la Skills might be in order here.
Okay, so the wiring plug is 90 degrees out. And the fuel line arrangement will need to be reworked, but looks like not much when the banjo bolt and nipples are used. Might even be a nice opportunity to fabricate steel fuel lines with fittings. |
Posted: Mon Jul 11, 2016 4:55 pm Post subject: Re: Engine fire, even after everything is done right |
Actually it looks like it will fit pretty well - not much bigger at all. I was worried about space in that area, as things at least in my engine bay are tight there.
Nice! _________________ '78 Bus 2.0FI
de K1IGS |
Posted: Mon Jul 11, 2016 6:20 pm Post subject: Re: Engine fire, even after everything is done right |
aerosurfer wrote: |
Creampuff, what did you search for that threaded t fitting? I can find anything with all search combinations? |
https://www.google.com/search?q=brass+male+branch+barbed+tee
Still haven't found the right one online. Thinking of taking it to the hardware store tomorrow to see if I can find something. _________________ Cream Puff
Earl Grey
Marsha Mellow
Posted: Mon Jul 11, 2016 7:01 pm Post subject: Re: Engine fire, even after everything is done right |
that "T" fitting is even more of an abortion than you could imagine....for one, you'll still have the lines hanging off either end of it, two, when tight, where is the correct "clocked" position going to be and three, I think that is an even bigger fire risk than the OE set up.
I don't know what the real answer is, and we are still not 100% sure this has been the source of fires.
I am not 100% familiar with the FI harness and if it has un fused 12V running thru it or not. if it does, I would probably consider either 1) a piece of fusible link or 2) an inline fuse.
and don't make me dig thru my decades old collection of 240/740/940 shit to cut open a Volvo CSV _________________
Jake Raby wrote: |
Brian wrote: |
dwill49965 Samba Member
Joined: August 08, 2005 Posts: 1396 Location: Dartmouth, Nova Scotia
Posted: Tue Jul 12, 2016 4:32 am Post subject: Re: Engine fire, even after everything is done right |
skills@eurocarsplus wrote: |
I don't know what the real answer is, and we are still not 100% sure this has been the source of fires. |
I agree. Lots of speculation - in 10 pages, I think 2 people have suspected fuel leaks (and a fire) from a csv valve, and one person has a "loose" csv that does not cause a fuel leak while in operation. I don't recall seeing any test results from bench testing yet, although a couple of people had plans to do it.
What if someone asked a pro - like Witchunter or Cruisin performance who clean injectors and cold start valves to see what they think - if its plausible, rare, or common?
I think longer term, Wildthings has it right with a fire prevention proposal to find a modern in-tank fuel pump that would have the right specs for L-jet. That would include finding the right size - both diameter and height - for the pump/fuel level module. If that's unlikely (and I'm thinking it is), then modifying the stock vw gas tank by cutting out the right size opening for the pump you've found, welding in the correct one that you've cut out from a donor used tank, and sealing up the bottom outlets. Which all becomes a daunting amount of work for your average VW enthusiast. _________________ Darryl
'78 Westy, Boston Bob built 2.0 L, FI, MSD 6A
Meyer wrote: |
Lastly, you just referred to US citizens as 'Americans'. Exactly what kind of Canadian are you? From what continent? |
danfromsyr Samba Member
Posted: Tue Jul 12, 2016 6:23 am Post subject: Re: Engine fire, even after everything is done right |
you can get a double tall Banjo bolt and use 2 regular banjo ends.
one in, one out and the bolt is your flow thru T-fitting.
it'll take a little hard searching to find an M8 banjo with 7-8mm hose barb. but I believe there's a rare application out there with one.
https://www.google.com/search?q=M8+double+banjo+bo...&dpr=1
Abscate wrote: |
Posted: Tue Jul 12, 2016 7:26 am Post subject: Re: Engine fire, even after everything is done right |
and don't make me dig thru my decades old collection of 240/740/940 shit to cut open a Volvo CSV |
None of the circuit that feed into FI are fused; #15, #30, or #50. |
Posted: Tue Jul 12, 2016 8:22 am Post subject: Re: Engine fire, even after everything is done right |
danfromsyr wrote: |
you can get a double tall Banjo bolt and use 2 regular banjo ends. |
Good call. Might as well follow through with this experiment. If nothing else, it allows us to use pretty much any Bosch CSV made over 2 decades with this type of fitting. More modern and readily available at the junk yard.
http://www.ebay.com/usr/efuelpumps has all the parts needed. They'll be here Saturday. _________________ Cream Puff
Earl Grey
Marsha Mellow
