NorCal Case Samba Member
Posted: Sat Apr 09, 2016 4:43 pm Post subject: Help ID year of oval |
My buddy an I picked up a oval today. We were told is was a 55, no semaphores no ribbed doors. Ok so late 55. Car was cut into a baja a long time ago. Problem is I'm not sure I'm reading the numbers right. The engine has a hand crank pulley on it and a 28pict carb. It has a trip odometer speedo.
The vin plate says 486550
The body right below the vin plate says 487140
The engine on the lower left side say 111 101 101A
Any help would be great.
I can post pictures of everything if that will help. |
janerick3 Samba Member
Posted: Sat Apr 09, 2016 4:57 pm Post subject: Re: Help ID year of oval |
Assuming the chassis number is 1486550, not 1-0486550, both the chassis and body date from March 1957. _________________ Thanks,
Jan K. |
Posted: Sat Apr 09, 2016 5:11 pm Post subject: Re: Help ID year of oval |
Don't see a 1 or 0
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sat Apr 09, 2016 6:58 pm Post subject: Re: Help ID year of oval |
That last pic is the case half part number. That's not going to help you date your engine much. The one you want is on the generator pedestal. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Sat Apr 09, 2016 7:04 pm Post subject: Re: Help ID year of oval |
There is no number on the post stand. It is blank so it's a factory replacement engine right? Just wondering why it has a crank start on it. Also the pan number does have the 1 in front of the vin number. The vin plate just doesn't have the 1 at all. Kinda weird. It also has the luvers in the heater channels right by the door pillers so it's a 57. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
chthemonkey Samba Member
Joined: July 30, 2008 Posts: 105 Location: united kingdom
Posted: Sun Apr 10, 2016 6:01 am Post subject: Re: Help ID year of oval |
Are there any stamps on the sides of the generator stand I f it's a factory rebuilt unit it should have kd then another letter then numbers
Chrisstiles Samba Member
Joined: April 09, 2016 Posts: 3 Location: Northern California
Posted: Sun Apr 10, 2016 10:18 am Post subject: Re: Help ID year of oval |
Hey everyone, Appreciate all the help thus far. So being that it's still raining a little, I only Took a quick look and at a glance it seems to be completely smooth.There does seem to be a bit of natures build up in and around the area lol. In a few i'll get out there and see if I can clean her up a bit more. Thanks again |
Posted: Sun Apr 10, 2016 9:13 pm Post subject: Re: Help ID year of oval |
Am I in the correct location? |
Posted: Mon Apr 11, 2016 10:25 am Post subject: Re: Help ID year of oval |
I just found that link after i had already posted. I'll check the above listed location when i'm back at the car. |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Mon Apr 11, 2016 3:32 pm Post subject: Re: Help ID year of oval |
Looking at the engine that is in the car now is not a good way to determine the year of yer Oval Window.
janerick3 wrote: |
Assuming the chassis number is 1486550, not 1-0486550, both the chassis and body date from March 1957. |
That's gonna be my guess as well.
What's the number on the pan?
On a bare body shell (or a car that has had parts swapped or is missing the VIN plate), check for the location of the interior heater vents.
If the heater channels have not been replaced, these can be important clues to determine the year of the car.
'55 and older has an oval-shaped heater vents with mesh screen inside.
'56 has one-year-only heater channels . . . louvered heater vents way up by the front bulkhead.
'57 and newer has louvered heater vents close to the hinge/door pillar. _________________ Jesucristo es mi Seņor y Salvador! |
747frieghtdog Samba Member
Posted: Sun May 29, 2016 11:35 pm Post subject: Re: Help ID year of oval |
Bump.
I hate stories with no ending. _________________ 55 Oval |
