splitjunkie Samba Member
Posted: Fri Jun 24, 2016 2:16 pm Post subject: Re: 10 year old rebuilt engine. Still good? |
wcfvw69 wrote: |
The engines out of the bug, stripped with the heads off. I'd split that case so fast before trusting anything with the motor. It's providing clues that all is not right inside it.
You could get lucky and find everything's ok but everything just needs to be cleaned really well. Or, you could find that it was a ticking/running time bomb. |
Helfen wrote: |
I think it is time past and time wasted. I would get this thing apart and analyzed so you can move forward. |
I agree. You need to go ahead and open it up and see what's what.
Score one for the hand wringers... _________________ Chris
ArtistGollaher Samba Member
Posted: Fri Jun 24, 2016 5:33 pm Post subject: Re: 10 year old rebuilt engine. Still good? |
Another bit of info. The metal bit that I found in the strainer was not picked up by a magnet. _________________ '63 Beetle 1300 Black
'67 Beetle 1500 Zenith Blue
'67 Beetle 1600 Olive Green |
bugheadred Samba Member
Posted: Fri Jun 24, 2016 6:00 pm Post subject: Re: 10 year old rebuilt engine. Still good? |
was it from the top of an oil container? |
Posted: Fri Jun 24, 2016 6:12 pm Post subject: Re: 10 year old rebuilt engine. Still good? |
No it was a thicker metal. I could bend it but it takes a little force. _________________ '63 Beetle 1300 Black
Posted: Fri Jun 24, 2016 6:36 pm Post subject: Re: 10 year old rebuilt engine. Still good? |
ok looks thinner in the pic |
Posted: Sat Jun 25, 2016 12:32 am Post subject: Re: 10 year old rebuilt engine. Still good? |
What could a chunk of aluminum like that come off of? _________________ '63 Beetle 1300 Black
Posted: Sat Jun 25, 2016 11:13 am Post subject: Re: 10 year old rebuilt engine. Still good? |
It's nothing that should be in there. It looks like aluminum or magnesium. Just split the case and be done with it. There have been more than enough red flags at this point. _________________ Chris
wcfvw69 Samba Purist
Posted: Sat Jun 25, 2016 11:16 am Post subject: Re: 10 year old rebuilt engine. Still good? |
ArtistGollaher wrote: |
What could a chunk of aluminum like that come off of? |
In the time you're spending/wasting with guessing, seeking others opinions and speculating, you could've split that case and known for sure. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Sat Jun 25, 2016 12:24 pm Post subject: Re: 10 year old rebuilt engine. Still good? |
Some more pics of my progress. Got the cylinders off and this is what I can see so far.
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Sat Jun 25, 2016 1:49 pm Post subject: Re: 10 year old rebuilt engine. Still good? |
That's some rebuilt engine. A real midnight auto. Time to start ALL over. |
Posted: Sat Jun 25, 2016 3:13 pm Post subject: Re: 10 year old rebuilt engine. Still good? |
You can see the Moly grease on the cam and lifters so that is most likely what is in the oil. So it does appear that the engine was "rebuilt" and never run. Cam looks used and the lifters look shiny so they are probably used too.
The inside of the oil pump cover looks weird. Will all of that crud wipe off? Does it look like it is oil with Moly grease mixed in or is that rust? _________________ Chris
Helfen Samba Member
Posted: Sat Jun 25, 2016 3:34 pm Post subject: Re: 10 year old rebuilt engine. Still good? |
splitjunkie wrote: |
The inside of the oil pump cover looks weird. Will all of that crud wipe off? Does it look like it is oil with Moly grease mixed in or is that rust? |
Yes, it appears that the engine was rebuilt with used parts. Not what I call a rebuild or remanufactured engine. Better known as a midnight auto shyster job. |
Posted: Sat Jun 25, 2016 5:08 pm Post subject: Re: 10 year old rebuilt engine. Still good? |
I see. Well that's a little bit of relief. Yes on the pump cover that isn't rust, but the oil with grease. _________________ '63 Beetle 1300 Black
Posted: Sat Jun 25, 2016 6:24 pm Post subject: Re: 10 year old rebuilt engine. Still good? |
As long as the parts were within specifications they don't really need to be replaced. I do see new cam bearings peeking around the cam in one picture.
The piece of metal that you found in the strainer is concerning. What is it and where did it come from? Is there more like that in there?
The gunk that you pulled out of the lifter didn't look like clean grease.
The cleaning of the case and parts is very half assed by my standards.
We already know that only one of the pistons is new.
The nuts on the oil pump originally had a plastic sealing surface on them. Looks like instead of using new nuts they just put some RTV on them. Not that big of a detail but another shortcut.
It also looks like they might have used RTV between the oil pump and body. This is not a good idea as it can get squeezed into the oil passages and end up in the bearings or the relief valve.
The rebuild job on the heads looks pretty iffy to me. The exhaust studs are very rusty and some of the head looks like it wasn't bead blasted very well.
Generally remanufactured heads will be very thoroughly cleaned and new valve guides and valves installed after the seats are recut. Any studs that need to be replaced get replaced. These heads look like they were done in house and given all the other shortcuts I would question if the guides were replaced if they were worn.
Certainly not a top notch rebuild by any standard. _________________ Chris
Posted: Sun Jun 26, 2016 10:46 am Post subject: Re: 10 year old rebuilt engine. Still good? |
So I guess it was either really rebuilt by archway imports or it was once rebuilt by archway and then po rebuilt again without much care. _________________ '63 Beetle 1300 Black
Posted: Sun Jun 26, 2016 12:05 pm Post subject: Re: 10 year old rebuilt engine. Still good? |
So I guess it was either really rebuilt by archway imports or it was once rebuilt by archway and then po rebuilt again without much care. |
It appears to have had the case split and various parts replaced. Not knowing anything about Archway Imports it is hard to say. Maybe this is what a standard rebuild looks like for them or perhaps they were told to rebuild it and do it as cheaply as possible. _________________ Chris
Posted: Sun Jun 26, 2016 12:16 pm Post subject: Re: 10 year old rebuilt engine. Still good? |
Seeing more of inside the case do you think I should still split the case, or would it be good to put back together and fire her up? _________________ '63 Beetle 1300 Black
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9770 Location: Oregon
Posted: Sun Jun 26, 2016 12:24 pm Post subject: Re: 10 year old rebuilt engine. Still good? |
Open it up. You need to know where that chunk of metal came from.
Also this is an opportunity to re-lube all of the moving parts. While it's apart take time to measure everything so that you know for sure that all is good.
I know I was a bit of an a$$hole the last time I posted in your thread. My intent was to push you into making a decision on weather to start it or tear it apart. Looks like you made the right choice. Your this far along. You might as well complete the job for piece of mind.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Sun Jun 26, 2016 1:04 pm Post subject: Re: 10 year old rebuilt engine. Still good? |
I had a 1964 type 2 1500 rebuilt using 1600 heads in1988 by a great builder named George Filchak of Norwood, NJ... he really did it right. I have had that engine in 3 busses. Currently in my 1960 single cab... still running great, zero oil leaking and great compression... never drive over 50 mph... almost 30 years since rebuild. _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Sun Jun 26, 2016 2:11 pm Post subject: Re: 10 year old rebuilt engine. Still good? |
Seeing more of inside the case do you think I should still split the case, or would it be good to put back together and fire her up? |
wow your still asking take it apart! |
