pablovent Samba Member
Posted: Tue Apr 05, 2016 6:30 am Post subject: stock IRS trailing arms longer work advice? |
Hi guys;
I'm work in my street Baja project, front suspension lifted with 3,5" raised spindles, but IŽll need enlarge stock trailing arms 3 ", like photo. Maybe 1x3" will be better for me.
I need tips or any recommendation for stock trailing arms modification.
I`ll Really apreciate your experiences...
Thanks and regards. |
Posted: Wed Apr 06, 2016 4:40 am Post subject: Re: stock IRS trailing arms longer work advice? |
up |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Wed Apr 06, 2016 2:49 pm Post subject: Re: stock IRS trailing arms longer work advice? |
ok...I understand.......3x3 "arms only work with 930 cv joints? |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5411 Location: Holland, MI
Posted: Wed Apr 06, 2016 7:59 pm Post subject: Re: stock IRS trailing arms longer work advice? |
Couple questions for the original poster:
Is this an effort to make it look astheticaly pleasing, or for function?
Will this be used off road or is it a mostly street Baja? _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Sandjunky Samba Member
Joined: August 03, 2015 Posts: 292 Location: New Mexico
Posted: Wed Apr 06, 2016 8:34 pm Post subject: Re: stock IRS trailing arms longer work advice? |
Your type 1 CV joints are your limiter in travel. If you get 3x3 trailing arms then you will have to limit your travel with bump stops and limit straps to keep from destroying your joints, which defeats the purpose of the longer trailing arms anyway. Unless, like Vanapplebomb is asking, this is for aesthetics only.
If money is the limiter then I would save and do it right the first time.
Here is a full kit for $1100.
http://www.appletreeauto.com/TRAILING-ARM-KIT-FOR-930-and-002-TA3x3930-002/
I'm told that you can work with them to upgrade the CV joints to ultimate plunging CV joints which are a true 30 degree joint instead of the EMPI 930, which apparently only achieves 26 even though they advertise 28*.
http://www.rcvperformance.com/product-details.aspx?sku=301174CC
I plan to do this myself when the money is there. |
dustymojave Samba Member
Posted: Wed Apr 06, 2016 10:50 pm Post subject: Re: stock IRS trailing arms longer work advice? |
So that you guys understand Pablo's situation...
The country where he lives adds huge import duties on everything imported. So parts coming from the US will cost him 2 or 3 times as much as they do to us who live in the US. So a rear suspension kit that costs us $1,100 might cost him $3,300.
Also, he is translating from Spanish into English to write to the group here, so some of his writing might be a little difficult to understand. I speak and write Spanish, so he and I have communicated a few times. Between his knowledge of English, and my knowledge of Spanish, we get along pretty well. So if anybody needs translation in this thread, let me know. He has been around offroad VWs quite a while, and has built Bajas and tube frame buggies before, but does not have access to many of the parts we in the US take for granted.
Pablo seems to want to keep the width of the car close to stock, so he seems to not want to go for 3x3 arms. This may have to do with streets or trails in his area being narrow.
I think that 2x3 arms would be the best compromise for Pablo in that there are plenty of VW Type 2s around him. So he can get a 002 and Type 2 CVs and axles fairly easily.
In metric, that works out to about 50mm x 75mm. I think Pablo can build a jig and modify stock arms to that size himself. _________________ Richard
SoCalBajas Member
Posted: Thu Apr 07, 2016 5:55 am Post subject: Re: stock IRS trailing arms longer work advice? |
Hi guys;
I have a dune buggy only for hard off road, but my intentions with the Baja project are softer, I want to run legal street too, aesthetics and reliability are always important...many baja purist guys "anger" with this words !!.
I do import many engine parts and accesories from USA, but generally smaller to avoid excess freight and taxes.
Now I have two problems,; one, excessive 3x3 arms wide add my rear tires with excessive negative offset can be a big problem, sure complicate things with the law street traffic in my country, and Import large and heavy pieces makes the final cost too high for me.
Thank you for my English translation and time, but the best solution is too expensive for me now.
I'll go with stock bug arms until I can import from USA special parts for better results. I just hope that the camber achieve with the IRS jigs (switch to IRS) are compatible with future improved arms.
Best regards.
Posted: Thu Apr 07, 2016 6:01 am Post subject: Re: stock IRS trailing arms longer work advice? |
Sorry man. I didn't catch that you were from Chile. Best of luck on your build.
Thanks for the info DustyMojave! |
Posted: Thu Apr 07, 2016 8:16 am Post subject: Re: stock IRS trailing arms longer work advice? |
dustymojave wrote: |
In metric, that works out to about 50mm x 75mm. I think Pablo can build a jig and modify stock arms to that size himself. |
Thats correct, Thanks x1000 Richard. |
rockcrawl Samba Member
Posted: Thu Apr 07, 2016 2:36 pm Post subject: Re: stock IRS trailing arms longer work advice? |
I extended a set of stock arms, +1.5" length and +3" lift. My intention was to test fit these on the car, make sure everything fits and all the angles and alignment are correct, then use them to make a jig to make a set of tubular arms. They are on the car now, and due to lack of time or just laziness I will probably leave them on. I'm not 100% confident that they will not bend, but they are holding up for now. Anyway, here are some pictures to give you an idea how I did it. The rest of the pictures are in my gallery.
Posted: Thu Apr 07, 2016 3:00 pm Post subject: Re: stock IRS trailing arms longer work advice? |
Back in the 1980s, offroad race fabricators would often build their own IRS arms using the car for a jig. The hub forgings would be cut out of the ends of a pair of stock arms, and then mocked up in place with a straight piece of tube or pipe clamped into the stub axle bore of the hubs to set the camber and toe at zero. Then the tubes for the arms welded to the pivot tube bushing holder tube and spring plate brackets made to fit. One had to be careful to not bump or move the car or the bearing carriers during fabrication. Once a pair of arms were made, you could make a jig from them. _________________ Richard
SoCalBajas Member
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Thu Apr 07, 2016 9:01 pm Post subject: Re: stock IRS trailing arms longer work advice? |
rockcrawl wrote: |
I like what you did there! Haven't seen that . Did you position the hubs by tack welding and then setting with the wheels on? Or mathematicall? Or |
jsturtlebuggy Samba Member
Posted: Thu Apr 07, 2016 9:11 pm Post subject: Re: stock IRS trailing arms longer work advice? |
I stretched these trailing arms 2in using 3/16in by 2in wide flat stock. I use four pieces to box it in. Also added 1in by .095" wall round tubing to reinforce the arm. The shock has been relocated to the top of arm on a 3/16in thick plate. I made up temporary jigs to make them. They are on a sand buggy project. Distance between center of torsion bar and center of stub axle is 18-1/2in where stock is 16-1/2in.
They do 1in longer trailing arms stock width for racing classes that require them.
These are stock arms reinforced. Something like could be done with bending the tubing around where stock shocks would go. All shock may have a harder time controlling the movement of arm
_________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
Posted: Fri Apr 08, 2016 4:17 am Post subject: Re: stock IRS trailing arms longer work advice? |
dirtkeeper wrote: |
I did a straight saw cut and welded .120' wall rectangular tubing between the pieces. Used a digital angle gauge to align the bearing carrier to the spring plate horizontally and vertically. I believe they are supposed to be parallel in both directions. I added gussets cut from same tubing and 10ga plate. I didn't put them back on the car until they were fully welded as seen in the pics. I think the alignment was pretty good at that point, but the CV angles were too extreme for the 181 joints I wanted to use. I did another saw cut down the rear edge of the tubing and added a 1/2" flat plate between, moved the hub out 1.5", added more gussets. I did this on the car which made it more difficult to cut straight and clamp properly. I ended up with about 2 degrees negative camber at ride height and about 1 degree total toe out. I'm OK with the camber but it's a little squirrely at high speed, I suspect because of the toe out. I'll probably tweak these a little more to get them where I want them and then use them to build a set from scratch. |
Posted: Fri Apr 08, 2016 5:54 am Post subject: Re: stock IRS trailing arms longer work advice? |
Wow...........Really nice info!!!! |
Posted: Tue Apr 26, 2016 2:34 pm Post subject: Re: stock IRS trailing arms longer work advice? |
Hi,
I'm working switch to IRS, all very well, I have only doubt about the two washers or shims that are on the tip of the trailing arm, they should be one on each side of the bushing?, inside the arm support looks a lip, it is for the shim?
Regards... |
cbeck Samba Member
Posted: Tue Apr 26, 2016 2:44 pm Post subject: Re: stock IRS trailing arms longer work advice? |
The two washers per side are supposed to go between the bushing and the bolt head. |
