misterfred76 Samba Member
Posted: Tue Mar 29, 2016 1:19 pm Post subject: Help for a french guy -JGE Geebees with disc & drop spindles ! |
Hi everybody !
I usually read TheSamba.com but today it's my first post on this website.
I'll make short because my english is a bit poor
I have a 1969's Beetle Standard with stock beam (ball joint), dropped spindles CB Performance, standard disks, standard Boge/Cofap shock absorber (long).
I'm planning to purchase a set of 4 JGE Geebees 5.5*15 4x130 ET43 with 165/80R15 tyres.
For the rear wheels, everything should be ok.
for the front wheels, I measured the exterior wheel side.It will fit into the fender (almost 1cm)
But will it be ok for the rest ? inner side ? rubbing fender.... ?
I need your help before buying something, I don't want to make a mistake.
Thanks for your help
Frédéric |
ALB Samba Member
Joined: August 05, 2008 Posts: 3483 Location: beautiful suburban Wet Coast of Canada
Posted: Wed Mar 30, 2016 7:27 am Post subject: Re: Help for a french guy -JGE Geebees with disc & drop spindles ! |
I would go with something a little wider on the back (185/65?); since you have the 5 1/2" rims, the better handling will be a bonus. On the front a 175/65 (24" tall) would normally be a good fit (and again, the wider, shorter tire will improve handling), since with the 2 1/2" drop you may find the 165's (at over 25") are too tall. The issue will be whether the extra 5/8" the spindles add push the tire into the fender edge. If anyone else cares to chime in... Al _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
macbuick Samba Member
Joined: November 12, 2004 Posts: 54 Location: Belgium Namur
Posted: Thu Mar 31, 2016 6:00 am Post subject: Re: Help for a french guy -JGE Geebees with disc & drop spindles ! |
misterfred76 wrote: |
Hi everybody !
Frédéric |
4x130 Gas Burner copies are totally fake...and you will look like a redneck, ....buy 5x130 and redrill your discs and drums...by this way every chicks in your town will believe that you have real Gas Burners !!
You should post a picture of your car to see what it looks like ...do you want a stock look, mid stock, cal-look stance, German-look style ??
and SSP wheels are cheaper than JGE !
http://www.sspwheels.co.uk/#!ssp-wheels/c17d2
Posted: Thu Mar 31, 2016 8:51 am Post subject: Re: Help for a french guy -JGE Geebees with disc & drop spindles ! |
Thanks for the advices ALB ! I'm thinking about that.
But it's a bit hard here to have several tyre's size on a car. Moreover, it is preferable to respect the original tyre's size (155/80R15) +-2% to get the "Technical control" accepted....
Macbuick, we don't have redneck in france so that's not a problem
Ok Gasburner are usually 5x130.
Did original 4x130 exist ? no ???
The JGE are more expensive than the SSP but they exist with ET43 offset instead of ET35. That's why I choose thoses wheels.
Sorry I don't have recent photos of the beetle. It is more a mid-stock in full restoration. |
EVfun Samba Member
Posted: Thu Mar 31, 2016 4:20 pm Post subject: Re: Help for a french guy -JGE Geebees with disc & drop spindles ! |
The JGE are more expensive than the SSP but they exist with ET43 offset instead of ET35. That's why I choose thoses wheels. |
Haters gonna hate, run what you want! I don't know the offset of your stock wheels (ET40??) so I can mostly only guess about rubbing. I'm going to install some Empi slotted wheels on my old wide 5 Bug.
You are looking at a wheel that is 1 inch wider with an offset similar to stock. The drop spindles move the wheels somewhat outward from stock so the inside may not be a problem. Usually rubbing on the inside when turning is the inside corner of the tire and a wider wheel doesn't change the width there. Sometimes it is the sidewall touching the forward end of the control arm. You can adjust the steering stops if needed without being very noticeable. It shouldn't be very much if it happens. I would be more concerned about the outward clearance, and it sounds like you have checked that out. _________________
Wildthings wrote: |
