flat4olsen Samba Member
Joined: February 20, 2014 Posts: 342 Location: Denmark, Europe
Posted: Fri Apr 01, 2016 11:39 am Post subject: Re: Homemade central air filter. Now installed. |
Heat is no problem at all with the epoxy. There is nowhere near as hot on top of the carbs as around the cylinders and heads. And there is plenty of epoxy hardened fan shrouds around, that won't fail
Go ahead! Fabrication is fun.
Cool idea with a resonator chamber, but I am quite pleased with the sound right now |
chubby53 Samba Member
Joined: February 17, 2005 Posts: 2106 Location: Eugene, Oregon
Posted: Sun Apr 03, 2016 11:15 am Post subject: Re: Homemade central air filter. Now installed. |
Is the inside diameter 2-1/2"? How much
H of a pain is to make up molds? Have you thought about coming straight out the top with the opening? Just wondering. If you start manufacturing for selling. That would be cool to be able to make some kind of snorkel system for my Baja. I wanted. To go through a 3' deep mud hole last time out in the mud, but was worried about sucking in water and hydrolocking.
Again just curious. Thanks. _________________ My build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=385100 |
Posted: Mon Apr 04, 2016 3:45 am Post subject: Re: Homemade central air filter. Now installed. |
yes, the inside diameter of the tubes are 2-1/2".
If you are unfamiliar with glassfiber/epoxy and mold building I would advise you to study some before trying to build molds. It is not overly complicated, but takes some time and patience to get it right.
I donīt own a Baja, so tubes on the top was not an option for me. It would be rather easy to just turn the silicon tubes 45 degrees to point the inlet upwards, though.
I will do a version 2, but with designated left/right units with inlets pointing towards the filter unit. |
W1K1 Samba Member
Joined: March 04, 2004 Posts: 4919 Location: Southern AB
Posted: Mon Apr 04, 2016 2:35 pm Post subject: Re: Homemade central air filter. Now installed. |
fiberglass is messy to work with, but holds up to engine temps just fine.
There are a few pics of the foam process I used to form mine. it works well for a one shot mold, the foam melts out with acetone after.
what we started with
in the end
_________________ http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap |
Posted: Mon Apr 04, 2016 9:10 pm Post subject: Re: Homemade central air filter. Now installed. |
That looks super nice! |
Slow 1200 Samba Member
Posted: Tue Apr 05, 2016 2:11 am Post subject: Re: Homemade central air filter. Now installed. |
hmmmmmmmm, this is when a 3D printer would come handy! |
Posted: Tue Apr 05, 2016 2:37 am Post subject: Re: Homemade central air filter. Now installed. |
Exactly! Thats why the prototypes for my version 2 will be 3D printed, to ensure perfect symmetry between left and right.
3D printing is an amazing technology! |
Posted: Tue Apr 05, 2016 12:30 pm Post subject: Re: Homemade central air filter. Now installed. |
you do good work, looks factory built. very nice. If you do deciede to build to sell, please PM me or repost. I would definately be interested. _________________ My build:
Posted: Fri May 20, 2016 4:16 pm Post subject: Re: Homemade central air filter. Now installed. |
New designated left/right design. Will fit the engine compartment better. The left side version is fresh from the 3D printer. Next is mold-making and glassfiber/Carbon fiber construction.
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Fri May 20, 2016 4:20 pm Post subject: Re: Homemade central air filter. Now installed. |
Very nice. |
Howard 111 Samba Member
Posted: Fri May 20, 2016 6:27 pm Post subject: Re: Homemade central air filter. Now installed. |
A really nice looking, functional design. You could sell those in a heartbeat! _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
Posted: Thu May 26, 2016 4:58 am Post subject: Re: Homemade central air filter. Now installed. |
Thanks
I still need to make the 3d printed parts ready for mold making, and to fabricate the molds for the fiberglass versions, so still a fair amount of work to do, before I will be able to sell any.
I will keep you posted!
Price? I have no idea.... |
mark tucker Samba Member
Posted: Thu May 26, 2016 10:02 am Post subject: Re: Homemade central air filter. Now installed. |
oh I see it now, the vw emblem is on the air box!!! nice work. it dosent take a lot to knock down the noise.just my vinyl rain covers quieten mine a good bit. |
Posted: Thu May 26, 2016 10:41 am Post subject: Re: Homemade central air filter. Now installed. |
Thanks Mr Tucker. |
Scott65Beetle Samba Member
Posted: Fri Jun 10, 2016 6:50 am Post subject: Re: Homemade central air filter. Now installed. |
This set up is so slick. I love the 'can-do' attitude as well. Interested in seeing version 2.Cheers |
SoCalJes Samba Member
Joined: November 02, 2011 Posts: 1093 Location: Broward, FL
Posted: Fri Jun 10, 2016 1:20 pm Post subject: Re: Homemade central air filter. Now installed. |
_________________ Jesse
71 Ghia
______________________________________
Just because it didn't come that way, doesn't mean it shouldn't have. |
Posted: Sun Jun 12, 2016 5:01 pm Post subject: Re: Homemade central air filter. Now installed. |
I have a 3d printer in my dreams and in my nightmares too now to get one for real...and connect it to a spool gun....with aluminum wire,titanium wire and more.... keep on building ,Ill keep on dreaming....I seem to spend a lot of $$ on tooling&machines, I may never get to building/finishing my new car. |
Posted: Mon Nov 28, 2016 7:38 am Post subject: Re: Homemade central air filter. Now installed. |
The project is stil alive. The first two carb tops fresh from the moulds. Still have to fabricate the baseplates.
The filter box will be a modified 1967 dual snout air cleaner. Pulling air from the a 120 mm hole in the bottom to the carb tops via a 2.5" pipe where the snouts used to be. Thougt it would be fun, to use a VW part just to keep a semi-stock look to the engine.
To be continued...
hobbybob517 Samba Member
Joined: June 02, 2011 Posts: 1194 Location: Netherlands
Posted: Mon Nov 28, 2016 10:08 am Post subject: Re: Homemade central air filter. Now installed. |
I would love a set of these _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
3 million rpm? Well there's your problem! No wonder it blew up! |
