flat4olsen Samba Member
Joined: February 20, 2014 Posts: 342 Location: Denmark, Europe
Posted: Tue Mar 29, 2016 10:57 am Post subject: Home made central air filter - Version 2 now installed |
Fits right in
vince1 Samba Member
Joined: December 14, 2003 Posts: 823 Location: Burgundy, France
nextgen Samba Member
Joined: August 19, 2004 Posts: 6025 Location: CONGERS, N.Y.
74 Thing Samba Member
Posted: Tue Mar 29, 2016 2:01 pm Post subject: Re: Homemade central air filter. Now installed. |
That is a nice looking airbox. Did it quiet down the carb noise a lot? |
theDrew Samba Member
Posted: Tue Mar 29, 2016 2:02 pm Post subject: Re: Homemade central air filter. Now installed. |
nice! can you go in depth on how you made it and the dimensions?
hows the noise reduction? _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25 |
mark tucker Samba Member
Posted: Tue Mar 29, 2016 5:13 pm Post subject: Re: Homemade central air filter. Now installed. |
so.. where is zit?? behind your vw add?? |
gt1953 Samba Member
Posted: Tue Mar 29, 2016 7:39 pm Post subject: Re: Homemade central air filter. Now installed. |
I am all about quieting the intake without sacrificing performance.
Do let us know. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Posted: Wed Mar 30, 2016 3:29 am Post subject: Re: Homemade central air filter. Now installed. |
Thanks guys.
Mr. tucker: The "VW add" is the same as every other "add" on the rear end of every car in excistence.... I like the look. If you donīt, I donīt care
I made an earlier post with a few more pictures, if you want more details.
It does seem to quiet the intake noise to some extend, based on unscientific study (ears only). |
Scott65Beetle Samba Member
Posted: Wed Mar 30, 2016 6:35 am Post subject: Re: Homemade central air filter. Now installed. |
What is the purpose of this? |
Posted: Wed Mar 30, 2016 7:35 am Post subject: Re: Homemade central air filter. Now installed. |
The primary purpose is filtering the intake air.
Secundary purpose is, that I love building stuff.
On second thoughts, it may be the other way around... |
chubby53 Samba Member
Joined: February 17, 2005 Posts: 2106 Location: Eugene, Oregon
Posted: Wed Mar 30, 2016 12:56 pm Post subject: Re: Homemade central air filter. Now installed. |
so how does it perform? I got some similare aluminum type carb intakes from CB performance and they choked the air flow too much and car ran like crap.
Would you consider building more of those for some $$$
It would be nice to have some kind of snorkle set for my dual carbs on my BAJA. do they seal up good on the carb base plates? Something like what you got might be the ticket... _________________ My build:
http://www.thesamba.com/vw/forum/viewtopic.php?t=385100 |
Alstrup Samba Member
Joined: July 12, 2007 Posts: 7212 Location: Videbaek Denmark
Posted: Wed Mar 30, 2016 4:14 pm Post subject: Re: Homemade central air filter. Now installed. |
nextgen wrote: |
As for the sound, personally what sets my bug apart from modern car is the the sound of a good exhaust, not too load, but you want to let people know it is not stock.
As for the sound of the dual Dells, that is my favorite sound, doing 60, then floor it and they kick in, nothing like that sound. Wish I could run no filters just the stacks. |
I do not dis aggree with you as such. On theother hand, a 5 - 10 hour Autobahn ride in the left lane can soon get on your nerves with four barrels yelling into your neck all the time.
I kinda like it. My only concern is if it chokes 2 & 4. Time will tell. |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3284 Location: Rapid City, SD
Posted: Wed Mar 30, 2016 4:20 pm Post subject: Re: Homemade central air filter. Now installed. |
Nice job. Very clean detailed work on everything.
Now lets get some info and pics of that linkage!!
Brian |
Air Cooleds Only Samba Member
Joined: October 18, 2009 Posts: 157 Location: Prescott, AZ
Posted: Wed Mar 30, 2016 8:49 pm Post subject: Re: Homemade central air filter. Now installed. |
Air box looks neat.
It appears you're still running points, I'm impresed _________________ Air Cooleds Only |
Posted: Wed Mar 30, 2016 9:37 pm Post subject: Re: Homemade central air filter. Now installed. |
Had a test ride yesterday. It does dampen the sound more than I initially notiched. Especially the inside of the car is a lot more quiet. No longer the roaring sound from the carbs, that can, as Alstrup mentions, kill al posibillity for conversation while driving.
Performancevise I don't feel any restriction at all. I suspect the old air filters to be restrictive though, because of the to small distance from the top of the stacks to the lid of the filter.
This has a lot more space for the air above the stacks. The surface area of the 2*44mm barrels in each carb is ((44/2)*(44/2)* phi)*2=3.039 mm2.
The surface area of the intake to each carb is (63/2)*(63/2)*phi=3.115 mm2. And the carbs are only sucking one barrel at the time, so I am pretty sure, it is not restrictive.
That said, there is room for improvement for version 2, which is on the drawing board. It will have a dedicated left/right unit without the need for the curved silicone tubes from the filter to the carbs.
The linkage is a Swedish Logmech linkage. Very nice quality, and easy to setup. www.logmech.se |
Posted: Thu Mar 31, 2016 10:35 am Post subject: Re: Homemade central air filter. Now installed. |
you should sell those filter tops -- and I would buy a set! _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Thu Mar 31, 2016 11:15 am Post subject: Re: Homemade central air filter. Now installed. |
Is the filter element itself part of the custom work? _________________ 1958 Karmann Ghia owner |
Posted: Thu Mar 31, 2016 11:43 am Post subject: Re: Homemade central air filter. Now installed. |
The filter is a standard K&N element (K&N e-9017). The housing for the filter is costum work. |
dnielsen Samba Member
Joined: June 19, 2005 Posts: 80 Location: Phoenix, AZ
Posted: Fri Apr 01, 2016 11:20 am Post subject: Re: Homemade central air filter. Now installed. |
Cool, I like this project. I was working on something similar but never got it all together, was worried about my epoxy resin failing due to high temperature. But it is good? You could add a resonator chamber like they do on modern cars and quiet it down even more. |
