origsix38 Samba Member
Joined: March 25, 2016 Posts: 3 Location: Toronto Canada
Posted: Fri Mar 25, 2016 12:09 pm Post subject: 1983 GTI Callaway Turbo 2.0l 8v |
Having an issue with post Boost stall.Boost set @ 6PSI. Does anyone have an idea what recirculating or diverting valve can be used with this engine. |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Sat Mar 26, 2016 6:46 pm Post subject: Re: 1983 GTI Callaway Turbo 2.0l 8v |
If you are still on CIS, wouldn't it be easier to add a dashpot to the throttle stop or to raise the idle speed a bit? Your management has no ability to control a recirc or divert valve. What about a blow-off valve? |
Posted: Sun Mar 27, 2016 12:02 pm Post subject: Re: 1983 GTI Callaway Turbo 2.0l 8v |
ps2375 wrote: |
HI Happy Easter I have a Blow-off valve that is presently adjusted to max Blowoff. I'm thinking if I re-adjust the setting to minimal blowoff the back pressure to the Turbo will prevent the Post Boost stall. The idle speed is presently 1000rpm. Engine is a 2.0l 8v with Callaway Turbo |
ps2375 Samba Member
Posted: Sun Mar 27, 2016 12:57 pm Post subject: Re: 1983 GTI Callaway Turbo 2.0l 8v |
What are you using to deliver the fuel? |
Posted: Sun Mar 27, 2016 2:58 pm Post subject: Re: 1983 GTI Callaway Turbo 2.0l 8v |
ps2375 wrote: |
Hi Can you be more descriptive, Injectors are Chrysler 45lb injectors |
ps2375 Samba Member
Posted: Sun Mar 27, 2016 4:35 pm Post subject: Re: 1983 GTI Callaway Turbo 2.0l 8v |
CIS, Digi, standalone like MS....sounds like a tuning issue. |
