ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Mon Mar 21, 2016 6:23 pm Post subject: Date coding vw steering box |
... I have 2 codes on 2 steering boxes, I'd like to know what they refer to?
6c and 5b _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
EverettB Administrator
Joined: April 11, 2000 Posts: 69807 Location: Phoenix Metro
splitjunkie Samba Member
Posted: Tue Mar 22, 2016 8:48 am Post subject: Re: Date coding vw steering box |
EverettB wrote: |
I have seen those numbers on there but didn't know what they were for.
For Buses there is often an actual date like 10/53 stamped into the casting, I guess Bugs don't have that?
Examples
( Sorry for gross Bus content here ) |
The bus steering boxes were made by ZF. The Bug boxes were either made by VW or a different vendor so that would account for the differences in how they were date coded. _________________ Chris
Posted: Mon May 23, 2016 6:34 pm Post subject: Re: Date coding vw steering box |
... yes, I have finally found the date coding on the left side of the steering box (driver side). It can be seen by looking under the fender, the side where the horn is... seems my '54 has a date coded 1949 box in it... _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
bally Samba Member
Joined: April 29, 2006 Posts: 1182 Location: Melbourne, Australia
Posted: Thu Dec 29, 2016 12:33 am Post subject: Re: Date coding vw steering box |
I'm looking at this steering box for my July 51 beetle. Is this a split beetle box? Is the 1053 to the right of the VW logo in the first photo a date code? Is an October 1953 box the same as for a July 51 car?
Cheers,
Dave |
Posted: Thu Dec 29, 2016 2:14 am Post subject: Re: Date coding vw steering box |
Measure the lower shaft dia, it should be 22 mm. If 28 mm then later version. The filling plug head looks odd, should be hexaconal.
I'm quite sure the stamp 1053 is an inspection stamp, not a date code. _________________ Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects |
bally Samba Member
Posted: Thu Dec 29, 2016 4:27 am Post subject: Re: Date coding vw steering box |
Thanks Mika |
