Mk1 Rabbit knocking sound
Forum Index -> Water-cooled VW Share: Facebook Twitter
Chevy432
Chevy432 is offline
PostPosted: Thu Mar 03, 2016 2:48 pm    Post subject: Mk1 Rabbit knocking sound Reply with quote
Just started hearing the sound out of the blue. I started it up and it sounds like a knocking noise coming from the engine. Its relatively quiet at low speeds but the faster you go the faster and louder the knocking gets. Any ideas as where or what to check? thanks!
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Fri Mar 04, 2016 5:37 am    Post subject: Re: Mk1 Rabbit knocking sound Reply with quote
Depending on the year of the car or if it has a later model engine in it, you might have a bad hydraulic lifter.
ps2375
ps2375 is offline
PostPosted: Fri Mar 04, 2016 8:24 am    Post subject: Re: Mk1 Rabbit knocking sound Reply with quote
Mains and rods.
Chevy432
Chevy432 is offline
PostPosted: Sun Mar 06, 2016 6:25 pm    Post subject: Re: Mk1 Rabbit knocking sound Reply with quote
Its a 1980 if that helps, anything i can do to fix it for the next while before i can take it to a mechanic?
ps2375
ps2375 is offline
PostPosted: Sun Mar 06, 2016 8:49 pm    Post subject: Re: Mk1 Rabbit knocking sound Reply with quote
Not really. Driving it may or may not make it any worse. I once drove a 1.7L motor 500+ miles with a rod knock and it didn't blowup, I can't remember if it got louder or not, but I also added some thicker oil to it to help cushion it.
I have seen knocks from lower end due to spun bearings and loose caps. Any work done on motor lately? Have you checked for exhaust leaks?
cub
cub is offline
PostPosted: Thu Mar 10, 2016 10:57 pm    Post subject: Re: Mk1 Rabbit knocking sound Reply with quote
If it was sudden I would drive it as little as possible. Check oil pressure asap.
I love old cars
Reply to topic    Forum Index -> Water-cooled VW All times are Mountain Standard Time/Pacific Daylight Savings Time
