bullibene Samba Member
Joined: August 20, 2011 Posts: 70 Location: Munich, Germany
Posted: Sun Mar 13, 2016 3:00 pm Post subject: Re: The "Gartenkäfer" - '62 resurrection |
Thanks a lot
Before I could place the body onto the frame I built I needed to remove the leftovers of the crossmembers and the firewall
drilled/sawzalled out
Next step was to repair the left inner structur of the b pillar/quarter panel
cut out all the rotten metal
built a repair panel
And welded it into place
I won't grind the welds right away because of one of my neighbours(veeerrryyy special neighbour) and due to the rest periods of Munich. I'm only allowed to make noise between 8-12am and 3-6pm.
Yeah... and due to that I'm doing this all at once somewhere outside after the welding is finished. |
Posted: Sun Mar 27, 2016 5:04 pm Post subject: Re: The "Gartenkäfer" - '62 resurrection |
Next step was to repair the A pillars.
At first, I planned to use the very cheap after market A pillar pieces.
But even for a project like that I didnt have the heart to weld in those pieces of crap.
I went with the ones from Hookeys Panel Shop. Very very nice quality for a reasonable price.
Hookeys A pillar vs cheap after market piece (black)
First i drilled out the door hinge screws to remove the hinge
removed outer skin
whole pillar cut out
aligned, then welded (forgot to tak picture)
Same for the otherside
Now i can aligne the door gaps and weld the a pillar to the heater channel.
Benedikt |
samstheman Samba Member
Joined: August 18, 2015 Posts: 239 Location: whittier
Posted: Sun Mar 27, 2016 5:31 pm Post subject: Re: The "Gartenkäfer" - '62 resurrection |
Nice job |
Joe.F Samba Member
Joined: April 13, 2013 Posts: 43 Location: New Zealand
Posted: Sun Mar 27, 2016 10:21 pm Post subject: Re: The "Gartenkäfer" - '62 resurrection |
This is fantastic! |
Posted: Mon Mar 28, 2016 4:39 pm Post subject: Re: The "Gartenkäfer" - '62 resurrection |
Next was the left inner rear wheel well.
Everything missing in this picture rusted away. Nothing was cut out to this point
Made first cut for the wheel well reinforcement repair panel
tacked in
completely welded in
rusted out fender nuts replaced with also cheap aftermarket repair panel
needed to make room for the cheap rear bumper hanger repair piece
cut out
engine bay bulkhead corner also was very crusty and needs to be replaced...
removed and cleaned up
repaired rusted out nuts for fender bolts
And finally the bumper hanger
had to fabricate a little piece
finished wheel well
Posted: Mon Apr 18, 2016 12:54 pm Post subject: Re: The "Gartenkäfer" - '62 resurrection |
The right wheel well is also finished.
Same procedure as on the left side
lolight70 Samba Member
Joined: August 22, 2013 Posts: 160 Location: West Australia
Posted: Mon Apr 18, 2016 3:13 pm Post subject: Re: The "Gartenkäfer" - '62 resurrection |
Amazing talent
A lot of us including myself live in warmer/dryer climates,
seeing a car in this condition would certainly mean a parts car
If thats all you can find,go for it!!
I wish i had these skills |
SixtyThreeRag Samba Member
Joined: July 12, 2015 Posts: 101 Location: Fort Worth, TX
Posted: Mon Apr 18, 2016 5:13 pm Post subject: Re: The "Gartenkäfer" - '62 resurrection |
Damn nice work. |
62ItalianRagtop Samba Member
Posted: Thu Apr 21, 2016 2:26 am Post subject: Re: The "Gartenkäfer" - '62 resurrection |
lolight70 wrote: |
Amazing talent
I think that in Germany you can find more and better old vws than in other country .... this is only a challenge _________________ LOOKING FOR 62 ENGINE WITH NUMBER FROM 6.904.xxx TO 6.915.xxx
http://tettodistraccio.blogspot.com/ |
Posted: Wed Apr 27, 2016 10:15 am Post subject: Re: The "Gartenkäfer" - '62 resurrection |
62ItalianRagtop wrote: |
I think that in Germany you can find more and better old vws than in other country .... this is only a challenge |
Exactly In the background of the picture for example is a better candidate for restoration
I made progress on the left front quarter. As it was super rusty everywhere and i dont care about original pressing in this project, I decided to replace the whole quarter with a cheap repro one. It didn't go as smooth as i expected.
I started by removing the front apron... Job done with 2 hard pulls
Then I drilled out all spot welds and unfolded the A pillar seam
removed
original vs repop
The later model bumper mounts will be removed later and the correct will be mounted on the inside
The area where the tank sits on top was also crusty
cut out
bend a panel with my cheap ebay folding machine
welded in place and ground down
Next rust through
cut out
made a patch panel and welded it in
ground down
And finally... the new quarter welded into place
TheBoltofWonder Samba Member
Joined: May 05, 2013 Posts: 14 Location: Carson City, Nevada
Posted: Thu Apr 28, 2016 8:01 pm Post subject: Re: The "Gartenkäfer" - '62 resurrection |
Oh wow, man! That's a parts car in the U.S.! We are pampered over here, it seems. You're doing Gods work, and no vehicle will EVER come close to the amount of sentimentality this car will posses to you. Keep it up, you're putting us all to shame! _________________ It's all a labor of love. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9754 Location: Oregon
Posted: Thu Apr 28, 2016 8:48 pm Post subject: Re: The "Gartenkäfer" - '62 resurrection |
TheBoltofWonder wrote: |
Oh wow, man! That's a parts car in the U.S.! We are pampered over here, it seems. You're doing Gods work, and no vehicle will EVER come close to the amount of sentimentality this car will posses to you. Keep it up, you're putting us all to shame! |
x2 on this. The European guy's kick our spoiled USA asses when it comes to metal work. We whine about how our engines don't start or run poorly. Then there's the electrical issues we all have here.
While the European guy's methodically go about returning our (perceived junk) to wonderful pieces of art.
To the OP. My hat's off to you sir. You are a craftsman.
Have a great weekend. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Fri Apr 29, 2016 12:05 am Post subject: Re: The "Gartenkäfer" - '62 resurrection |
Bullibene you are my hero! |
Posted: Wed May 11, 2016 4:03 pm Post subject: Re: The "Gartenkäfer" - '62 resurrection |
Thanks for the compliments
Next was the right quarter panel
I cleaned up the the areas where the spotwelds were hiding, drilled them out and opened the seam to the A pillar.
removed quarter panel compared to repro panel
I blasted and primed all areas which won't be easy to reach after the quarter installation.
Quarter in place!
Replacing the quarters was actually more time consuming as i thought.... work i didn't want to do again in the near future
Make sure to check out my personal blog where I also post progress of my other ongoing projects ... the 089garage
www.089garage.blogspot.de
best regards
bene |
ratlooker Samba Member
Posted: Thu May 12, 2016 7:28 am Post subject: Re: The "Gartenkäfer" - '62 resurrection |
Hi Bene,
thx for that stunning project sharing with us!
We all appreciate the youngsters doing these restos
They are getting rare, as the cars too
When can we expect the next post ?
Regards
Gunar |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22639 Location: NYC/Upstate/ROW
Posted: Fri May 13, 2016 3:15 am Post subject: Re: The "Gartenkäfer" - '62 resurrection |
I thought I had seen innovation until I travelled to the Russia and east Europe republics. The folks there who had to live with nothing teach us how amazing we can be. _________________ .ssS! |
Posted: Sun Jun 19, 2016 5:28 pm Post subject: Re: The "Gartenkäfer" - '62 resurrection |
Another piece of the puzzle:
I fixed the brake fluid resevoir area without completely removing it!
Rust:
cut out all the rot to the solid metal and treatetd with rust converter
I first repaired the beneath lying panel
...applied weld thru primer
and then the brake fluid resevoir area itself
painted
spare tire well in position
welded
_________________ www.089garage.blogspot.com
Instagram: 089garage
Rome Samba Member
Joined: June 02, 2004 Posts: 9640 Location: Pearl River, NY
Posted: Mon Jun 20, 2016 8:32 am Post subject: Re: The "Gartenkäfer" - '62 resurrection |
Tremendous work, skill and dedication, Bene.
Why did you use late-style (big bumper) front quarter repro patch panels? Were the early style not available, so that you'll graft in at least the lower sections with the bumper bracket mounts that are inside the spare tire well?
Posted: Fri Jun 24, 2016 3:32 pm Post subject: Re: The "Gartenkäfer" - '62 resurrection |
Rome wrote: |
Hey,
Firstly there are no early full quarter panels on the market.
But also if they were, i probably also would have used the ones I did due to budget reasons. This is a low budget project and no period correct restoration(i have other cars for that )
My goal was to bring a car that nobody wanted even as parts car back to life to drive as a rat. Nothing more
Oh and don't worry about the bumper mount itself.
Next update will contain the removement of the late bumper mounts on the outside and the conversion to the old style bumper mount
best regards and thanks for reading
bene _________________ www.089garage.blogspot.com
Instagram: 089garage |
Scott65Beetle Samba Member
Posted: Fri Jun 24, 2016 4:58 pm Post subject: Re: The "Gartenkäfer" - '62 resurrection |
Der Hammer! |
