40 HP Judson pulley is touching the deck lid
Alex Dragone
Alex Dragone is offline
PostPosted: Wed Feb 24, 2016 4:02 pm    Post subject: 40 HP Judson pulley is touching the deck lid Reply with quote
Hi,
I have a 1963 VW bug that I just installed a 40HP Judson on. All is well accept when I put the lid down, the edge of the main pulley on the supercharger rubs the deck lid. Any ideas on what I should do? Any help is appreciated. Thanks!
oval56
oval56 is offline
PostPosted: Thu Feb 25, 2016 12:14 am    Post subject: Re: 40 HP Judson pulley is touching the deck lid Reply with quote
machine the pulley (take the lipp of, or use a decklid standoff:
http://www.thesamba.com/vw/classifieds/detail.php?id=1007835
www.oval56.com
1956 Oval, 2364ccm typ4
1957 Oval Ragtop 1584ccm singel port modified
1950 Hebmüller, 1584ccm okrasa modified
DBK Germany!!!!!!!!!!
www.dbkvw.com
billmetric
billmetric is offline
PostPosted: Wed Mar 30, 2016 12:31 pm    Post subject: Re: 40 HP Judson pulley is touching the deck lid Reply with quote
http://www.thesamba.com/vw/archives/lit/judson/installation/Judson%20VW%2040hp%20Instructions.pdf
Judson 40 hp installation instructions section F-1.:
"Remove wire from clamp at tail light. Break clamp off of lid by bending back and forth. Cut bottom bolt of tail light flush with nut if it rubs on the supercharger pulley with deck lid closed. Loosen tail light wire in other clamp and pull wire up and loop over top right hand bolt as shown."
by "tail light" they mean license light, sometimes I've just removed the taillight from the lid and unscrewed the stud right out of the housing and left it off, I hate bending stuff back and forth until it breaks off too but that's right out of the instruction sheet, 40 hp Judsons rub at the license light/wire area, that's normal operation, you can make a custom front trans mount with offset holes to tilt the engine at a lower angle, it doesn't take much, also brand new rear motor mounts tend to sit the engine up higher than old squished ones,
There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there...
