roadsportusa Samba Member
Posted: Wed Feb 24, 2016 11:42 am Post subject: Will 914 transmission fit in 912E |
what is needed to adapt 914 , 5 speed side shifter transmission to a 1976 912 shifter. |
BK911 Samba Member
Joined: May 11, 2005 Posts: 98 Location: Rocky Top, TN
Posted: Wed Feb 24, 2016 1:54 pm Post subject: Re: will 914 transmission fit in 912E |
As a start you have to flip the ring and pinion unless you want 5 reverse gears and 1 forward gear. _________________ '72 914 1.7
'74 Standard Bug 1600 |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Sat Feb 27, 2016 5:20 pm Post subject: Re: will 914 transmission fit in 912E |
And then you need nose cone from the 912/911 transmission and the mount. _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
thesatanicmechanic Samba Member
Joined: November 30, 2008 Posts: 102 Location: Charlotte, NC
Posted: Thu Mar 10, 2016 11:23 pm Post subject: Re: Will 914 transmission fit in 912E |
The 914 transmission is the earlier 901 type. 1st is on the bottom left. Flip the ring & pinion, change the selector rods to early, tail shifter type, install a 901 equipped 911/'69 and earlier 912 end cover, get hybrid axles for your abomination and a 901 shifter mechanism.
So yeah, it's doable, but you'll need lots of parts.
You missing your type 923 (912E) trans? It broken? What's the story? |
Dearindeed Samba Member
Joined: November 05, 2010 Posts: 22 Location: Southeast
Posted: Wed May 11, 2016 9:03 pm Post subject: Re: Will 914 transmission fit in 912E |
Thank you for that descriptive name for that 912E; (which gets a Triumph TR-3 picture pasted over it when it would appear in Sports Car Market.) |
914werke Samba Member
Posted: Mon Apr 02, 2018 1:54 pm Post subject: Re: Will 914 transmission fit in 912E |
thesatanicmechanic wrote: |
So yeah, it's doable, but you'll need lots of parts. |
So start with a early tail shift 914 box, all you need is a 914 shifter, & a early 911/912 nose cone & ...? Axles? Do you mean output flanges?
You are suggesting that the CV on the 912E is different than 914? |
Joined: December 28, 2016 Posts: 279 Location: atlanta ga
Posted: Mon Apr 02, 2018 3:08 pm Post subject: Re: Will 914 transmission fit in 912E |
certainly too much hassle to even try it. Get a 912e transmission (even we have one on the shelf) and it bolts right in, or a 911 earlier transmission but then you will have to change the shift mechanism and cv axles, just not worth it |
