ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2649 Location: West Coast (Michigan's)
Posted: Thu Apr 14, 2016 3:55 am Post subject: Re: Screwing around with my new bender. |
I would be nervous about the angle on that top tube.
BTW what are you going to on the car with that tube? The fenders on mine come down farther and I had a heck of a time getting just the right angle to hit a tube receiver at the top shock bolt. The tube is flattened on one end and a hole drilled through where it goes onto the shock bolt.
I mention the top tube for several reasons:
1. A horizontal tube that attaches to the vehicle is going to be able to take more force.
2. If you don't keep all four points where the bumper slides onto the car on the same plane, it makes sliding it on and off a real pain in the arse. I knew this going into my rear bumper I built last year but it still came out off just enough to make reinstallation an PIA. _________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
Posted: Thu Apr 14, 2016 3:59 am Post subject: Re: Screwing around with my new bender. |
In hind sight I would just flatten that top tube where it runs behind the shock tower and drill a hole there and skip the receiving tube all together. I'd have to remove the top shock bolt everytime but that might be better than what I had to do when I wanted to pull my engine this spring. _________________ Brian H.
enjoyther1de Samba Member
Joined: December 19, 2010 Posts: 1279 Location: chino,ca
Posted: Thu Apr 14, 2016 6:26 am Post subject: Re: Screwing around with my new bender. |
The angle on the top tube is a little extreme but it's what the customer wanted. He wanted a taller cage without attatching to the fire wall. It's mostly for looks. _________________ HBB took me to BBV. |
Posted: Fri Apr 15, 2016 5:40 am Post subject: Re: Screwing around with my new bender. |
Top is attached at the shock mounts. Smushed plate dudes are welded to cage. _________________ HBB took me to BBV. |
Posted: Mon May 09, 2016 9:25 pm Post subject: Re: Screwing around with my new bender. |
More fun and games.
Posted: Mon May 09, 2016 9:41 pm Post subject: Re: Screwing around with my new bender. |
Totally forgot to post the finished high angle bumper.
Posted: Fri May 20, 2016 6:42 pm Post subject: Re: Screwing around with my new bender. |
Got my new 1" die today. Made some tail light mounts.
Bends look like they'll do just fine for some roof rack work.
Posted: Fri May 20, 2016 6:51 pm Post subject: Re: Screwing around with my new bender. |
Mal evolent wrote: |
for what it's worth:
looking at
and
and Rotopax
and this
makes me wonder what a clever lad with a tubing bender could come up with if he applied his talents to side rails as storage spots |
Absolutely, were planning on running the mojave road in sept. Building racks and fuel storage is a must. We have four cars going that need racks so we'll be busy for a few weekends here pretty soon. _________________ HBB took me to BBV. |
66 Shorty Samba Member
Joined: May 10, 2007 Posts: 916 Location: Rhode Island
Posted: Sat May 21, 2016 4:36 am Post subject: Re: Screwing around with my new bender. |
Very nice job Bro! Like you, I've been contemplating purchasing one for about 4 years now myself... I don't have other jobs to do to make money for materials, or to pay for the bender itself, but, I still want to get one so I don't have to pay someone else's mortgage to have my cage, bumpers, side bars & roof rack made...
Looking Really good though! I think I'm going to purchase, but, I would need at least 2 size dies & they are what cost money! |
Posted: Sat May 21, 2016 8:45 am Post subject: Re: Screwing around with my new bender. |
66 Shorty wrote: |
Yeah ,it's a pretty big chunk of change upfront but as with all tools you will not lose money with the investment. I'm lucky I have a few buds that need some tube work. I say go for it. You'll be tripping over bumpers and racks in no time! _________________ HBB took me to BBV. |
cbeck Samba Member
Posted: Sat May 21, 2016 9:58 am Post subject: Re: Screwing around with my new bender. |
Here is one for you. My chassis builder hard at work.
Posted: Sat May 21, 2016 10:09 am Post subject: Re: Screwing around with my new bender. |
I think I just talked my buddy into going in on one with me. He's building a jeep cherokee xj. He wants to build a full cage for inside his jeep. I want to build a cage for dune buggy, and also bumpers, engine cage and side bars for the baja. And possibly a cage for the baja if all goes well. (And I can afford it... which I doubt lol)
That is quite the chassis! Wow! Is that for a rock crawler?
I think I'm going to actually purchase the jd squared with a 1 inch die. And hopefully, he'll buy a 1.5 x 4.5 (that should be good for a cage right? ) but idk if I should get a 3 inch or 4 inch radius on the 1 inch die. Both will be 180 degree dies though.
I'm sorry for kinda highjacking this post for a minute! |
dustymojave Samba Member
Posted: Sat May 21, 2016 10:26 am Post subject: Re: Screwing around with my new bender. |
1.5 x 5.5 would be much better than 1.5 x 4.5. The larger radius makes a stronger bend and is easier to bend as well. It's still not a large radius bend. I have a 1.5 x 5.5 for my JD2.
This is what the bends look like at the top of the A pillar in my Baja Bug:
Ohhh...The XJ, because of it's weight, should have a cage made of 1.75 x .120 for the primary tubes...4 uprights around the driver's compartment, halo above, rear braces down to the back, and diagonal behind the driver. Other tubes can be smaller. I've seen a play Cherokee with a cage made of 1.5 that the cage collapsed in a 20-25mph roll over off the side of a graded fire road. Not even real offroading or going fast. If there had been someone in the right front seat, they would have been in SERIOUS trouble. The roof was down to the window sill and the dash. The Cherokee weighs about 2x what my Baja weighs. _________________ Richard
SoCalBajas Member
Posted: Sat May 21, 2016 11:31 am Post subject: Re: Screwing around with my new bender. |
That looks perfect. Why would I want bigger if that's the perfect radius? Idk I'm all new to this cage stuff... lol!
Well it looks like more stuff for me to learn... glad my buddy offered to teach me how to tig weld and then leave it here for me to practice with! |
Posted: Sat May 21, 2016 1:04 pm Post subject: Re: Screwing around with my new bender. |
66 Shorty wrote: |
Wish I had a buddy that would leave me a tig welder... Lol all my friends a delinquents. sounds like your on the way to planet awesome! _________________ HBB took me to BBV. |
Posted: Sat May 21, 2016 1:22 pm Post subject: Re: Screwing around with my new bender. |
66 Shorty wrote: |
Oops!
I read your post and was wondering ...WTF is he talking about "why would I want bigger?" ... So I re-read my post and saw a mistype. Had to read it 3x before my brain caught on to the error. My brain knew what was supposed to be there and auto-corrected, even though my eyes could see it... I went back and corrected it. I have a 1.5" x 5.5" radius die set. The bends shown in the picture of the cage in my Baja were bent with a 5.5" radius die.
Derrrrr...
I edited it so it now reads correctly. _________________ Richard
SoCalBajas Member
Posted: Sat May 21, 2016 1:26 pm Post subject: Re: Screwing around with my new bender. |
ok that makes sense to me now. |
cbeck Samba Member
Posted: Sat May 21, 2016 1:53 pm Post subject: Re: Screwing around with my new bender. |
I think now they are called mega trucks. Real popular in the midwest and south. Think 15 year old monster truck with rice @ cane tires. This one now has a 900 hp alky swilling 427 mounted in the bed sitting on 67's. |
Posted: Fri Aug 19, 2016 6:28 pm Post subject: Re: Screwing around with my new bender. |
New beer and firewood holder. Stole the clamp idea from surf's blue 11 car her on the samba.
