Stevie Hall Samba Member
Joined: September 15, 2004 Posts: 54 Location: Northern Ireland
Posted: Wed Jul 20, 2016 11:54 am Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? |
Sorry guys. Quick question here. What thread are the two screws that hold the large fan on? They are the cause of my rubbing noise. Mine seem to have gone AWOL in rebuild. Thank you _________________ 67 Steel slider
69 Notchback
88 Carat
34 Ford |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22712 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Wed Jul 20, 2016 12:14 pm Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? |
Stevie Hall wrote: |
Sorry guys. Quick question here. What thread are the two screws that hold the large fan on? They are the cause of my rubbing noise. Mine seem to have gone AWOL in rebuild. Thank you |
The two threaded holes in the big fan are for a puller. They have no bearing on the fan itself whatsoever.
If your fan is rubbing and not knocking your most likely suspect is that the bolts holding the front part of the aluminum fan housing to the case have backed out and are rubbing on the fan. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22413 Location: Kimball, Mi
Posted: Wed Jul 20, 2016 12:15 pm Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? |
Those 2 holes are for aiding in the removal of the big fan. There aren't any bolts that go in them. They holes are however M8x1.25 thread.
If you've got some extra movement from the fan, then it needs rebuilding. There's a thread on it that can be found doing a search. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Jul 20, 2016 12:43 pm Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? |
Thanks very much guys! I didn't remember there being screws in there. There is however some rocking of the fan and can see movement through the holes that are threaded. Id assumed I'd missed screws. I have a video on my phone _________________ 67 Steel slider
69 Notchback
88 Carat
34 Ford |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Wed Jul 20, 2016 1:09 pm Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? |
Another thing to check is the big bolt holding the fan/pulley in place. Many manuals repeat the Bug's ≈35 ft-lb torque, but the Type 3 is more like ≈90. It may be coming loose. |
Posted: Wed Jul 20, 2016 1:21 pm Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? |
True. It was damn tight with the engine in the car which is why I dropped it out last night. I'll remember when I'm putting it back on to make sure its FT! _________________ 67 Steel slider
69 Notchback
88 Carat
34 Ford |
Posted: Wed Jul 20, 2016 1:34 pm Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? |
Thanks very much guys! I didn't remember there being screws in there. There is however some rocking of the fan and can see movement through the holes that are threaded. Id assumed I'd missed screws. I have a video on my phone |
Uh oh.
I've had lots of problems with mismatched and misidentified main bearing sets (new non steel backed type) causing perceptible movement of the crankshaft after as little as a few minutes of running. Get the fan off and install the bolt to the crank and rock it up/ down/ to/ fro and tell us what you find. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Thu Jul 21, 2016 7:15 am Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? |
Any reasons why this wouldn't work? 2 M8 buttons
69 Notchback
88 Carat
34 Ford |
Posted: Thu Jul 21, 2016 11:04 am Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? |
I don't care what you put in there- it won't solve anything. Those holes are for a puller!!! _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Thu Jul 21, 2016 11:39 am Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? |
Totally agreed Tram! Ive thought about it and pulled it today. Going to do the rebuild. Better in the long run! Thanks for the help _________________ 67 Steel slider
69 Notchback
88 Carat
34 Ford |
Posted: Thu Jul 21, 2016 3:41 pm Post subject: Re: Fan rubbing / Pulling fan shroud with motor in car? |
Totally agreed Tram! Ive thought about it and pulled it today. Going to do the rebuild. Better in the long run! Thanks for the help |
Do the bolt in the crank test before you rebuild the fan... _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
