sandhopper Samba Member
Joined: December 13, 2004 Posts: 453 Location: Norwalk Ca
Posted: Thu Feb 11, 2016 2:08 pm Post subject: Towd build |
Not sure what I just picked up , but it is a project .
It appears that the PO did a stretch job and added the gage, my idea is to bring this back to original .
Step 1 Strip it down
Posted: Thu Feb 11, 2016 2:10 pm Post subject: Re: Towd Or Sanhopper build |
I will need some info on some of the measurements
How long should this frame be , I was told that the wheel base should be 80 inches . Mine is measuring 94-95 inches
Posted: Thu Feb 11, 2016 2:34 pm Post subject: Re: Towd Or Sanhopper build |
It looks like this was stretched 14 to 16 inches
Buggy Brian Samba Member
Joined: October 26, 2006 Posts: 308 Location: Yulee, FL
Posted: Thu Feb 11, 2016 9:09 pm Post subject: Re: Towd Or Sandhopper build |
While we all love original, I'm thinking a stretched Tow'd (done correctly), wouldn't be so bad. I'm 6 foot even, and had a bit of a crowding problem in the one I had.
I could see how a few inches would work, but an additional 15 would seem excessive _________________ -(Loretta) Manx # M2940D910E on customized 1970 chassis by Joescoolcustoms
-(Scarlett) Manx Resorter #12 (R0012B931S) on 1969 chassis.
-Original Home built buggy that started all. I learned to drive in it back in 1985.
Manx Club Member # 4436
Check out my Loretta here: http://www.manxclub.com/forum/viewtopic.php?f=65&t=3365Manx
Scarlett is getting a Makeover! http://manxclub.com/forum/viewtopic.php?f=82&t=3745&p=24983#p24983 |
hillmotorsports Samba Member
Joined: December 27, 2014 Posts: 432 Location: Morrisburg, Ontario, Canada
Posted: Fri Feb 12, 2016 7:43 am Post subject: Re: Towd Or Sandhopper build |
Still not sure what we have, there seem to be differences from a Tow'd OR a Sandhopper.
Subtle differences... the double roll bar is secured with welded studs, nuts on top. There are 3/16" gussets top forward from the roll bar/tank mount, and 1/4" gussets forward on the bottom, drilled...seat belt mounts? Lower driver's side has a stamped number...
1213-3203-D1, a proper stamping job, not a hand stamped, misaligned number.
The rear torsion housing is secured with short U-bolts to a welded angle flange.
The rear shock mounts are tied to the main tube with a twisted pc of 2 x 3/16 flat bar.
The master cylinder is bolted to a 4-3/4 x 8 x 1/8" plate that is welded to the back side of the foot panel support tube.
The main tube is 2", the angled foot support panel tube is 1-3/4", as is the double tube roll bar.
The wheelbase measures 81".
If someone would be so kind as to refresh an old man's memory I would post more explanatory pictures... _________________ Rosemarie and Paul Hill
Morrisburg, Ontario
(With way more projects than spare time!) |
Posted: Fri Feb 12, 2016 8:27 am Post subject: Re: Towd Or Sandhopper build |
Most tell me this actually a Towd |
Dale M. Samba Member
Posted: Fri Feb 12, 2016 8:53 am Post subject: Re: Towd Or Sandhopper build |
Umm... Original TOWD had extension tube the was for a tow bar, the method of extending/storing tow bar also doubled as the steering wheel support....
http://seatoseasafari.com/?p=1
But if chassis has been modded all bets are off.....
Posted: Fri Feb 12, 2016 8:58 am Post subject: Re: Towd Or Sandhopper build |
This one had a cage built so I assume the sterring tube support tow bar was removed
I will be putting one back |
Posted: Fri Feb 12, 2016 9:09 am Post subject: Re: Towd Or Sandhopper build |
Here is pic of a reproduction tow bar....
Under hood pic...
Large hoop on front of your build leads me to believe your chassis had tow bar/ steering support but was removed when chassis was stretched....
The clinker in the fire (blacksmithing term) is I don't know if sandhopper used same steering mount/tow bar method...
l8sho Samba Member
Joined: March 12, 2013 Posts: 114 Location: Katy Texas
Posted: Fri Feb 12, 2016 10:09 am Post subject: Re: Towd Or Sandhopper build |
My Sandhopper does |
Posted: Sun Feb 14, 2016 6:56 pm Post subject: Re: Towd build |
Thanks for the pictures Dale it will help
I need to find someone that can bend the 2.5 inch tubing for the steering support |
Oz Towdster Samba Member
Joined: November 08, 2004 Posts: 133 Location: Brisbane QLD Australia
Posted: Mon Feb 15, 2016 10:33 pm Post subject: Re: Towd build |
among other reasons that they would have chopped out the towing bar support is if you go to rack and pinion steering it gets in the way _________________ Working at getting my Baja Bus and the Towdster back on the road |
Posted: Wed Feb 17, 2016 7:46 pm Post subject: Re: Towd Or Sandhopper build |
Buggy Brian wrote: |
I could see how a few inches would work, but an additional 15 would seem excessive |
I like your thinking , it would be the same amount of work to make it standard or say 4 inches longer. I have never sat in one and I'm short 5'6" , but if I build this to sell which would be better ? |
Posted: Wed Feb 17, 2016 7:49 pm Post subject: Re: Towd Or Sandhopper build |
sandhopper wrote: |
For sale, use original specs...
Posted: Thu Feb 18, 2016 11:56 am Post subject: Re: Towd build |
Where would the VIN number go . I have a pan with Non op paper and would like to use that for this build |
Posted: Thu Feb 18, 2016 6:01 pm Post subject: Re: Towd build |
sandhopper wrote: |
You can not move VW pan VIN to the TOA'D or Sand Hopper... Its state and federal crime to tamper with VIN....
Also Calif DMV rules state it has to be a SPCN (SPecial CoNstruction)..
IF it does not physically look like a Beetle then you can not use Beetle registration on it...
http://www.dmv.ca.gov/portal/dmv/detail/vr/spcnsreg
Posted: Fri Feb 19, 2016 12:40 am Post subject: Re: Towd build |
Why NOT Dale as the rear end out of the bug is completely bolted into the rear of the Towds and if you cut it out of the doner pan correctly the vw VIN has not been tampered with , mind you you cn't read the bloody thing but who would know where to look anyway
Which as i believe most of the Towds in Socal are registered like _________________ Working at getting my Baja Bus and the Towdster back on the road |
Posted: Fri Feb 19, 2016 8:55 am Post subject: Re: Towd build |
Oz Towdster wrote: |
Which as i believe most of the Towds in Socal are registered like |
Becasue CALIFORNIA USA has different rules than AUSTRALIA... DID you read the CALIFORNIA DMV rules in link I provided?....
AGAIN:
To misclassify car type and design can result in impoundment and monetary fines to a point where one can actually looses vehicle.... I not sure anyone wants to risk that...
Then there is this part of US law...
https://www.law.cornell.edu/uscode/text/18/511
http://www.justice.gov/usam/criminal-resource-manu...on-numbers
I don't make the rules, I just try to save people grief when they go to register their vehicles, sure there are a lot of vehicles out there that just have had VIN moves and are misclassified , but they have not been caught or officer has not made a issue of it...
A person is free to do anything they want, just don't get caught if you are not withing the rules....... _________________ “Fear The Government That Wants To Take Your Guns" - Thomas Jefferson.
Posted: Sun May 22, 2016 9:52 am Post subject: Re: Towd build |
I did a little work on the project and found that it was lenghtend 12 inches
I did cut the cage up to make it original . I'm going to make the frame stock length the fiberglass the tube back together . I'm still looking for a used hood , but will buy new when time comes . I'm working on and off on this one as I have other projects also
Larry |
caliif' Samba Member
Posted: Tue Feb 28, 2023 8:17 am Post subject: Re: Towd build |
Hi, IS someone can tell me if this body is for sale? |
