Vwandxrlust Samba Member
Posted: Tue Jan 19, 2016 6:43 pm Post subject: VW bus Safare Custom Camper insulation |
Hi guys, I'm insulating my van and the ceiling, fiberglass, is my main concern:
Last time it rained I noticed humidity was going through, making the top wet, and the insulation wet as well.
Given the fast that I want to put wood on the ceiling, I am wondering what I can do to waterproof the fiberglass ceiling?
I was thinking of putting some waterproof paper before the insulation?
Any ideas, guys?
PS: The original ceiling had some yellow foam all over covered by the vinyl headliner.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51149 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue Jan 19, 2016 6:56 pm Post subject: Re: VW bus Safare Custom Camper insulation |
Are you sure the moisture is "getting through"?, or is it just moist interior air condensing on a cold uninsulated surface?
Step 1 is fix all the leaks in the bus so it doesn't get wet inside, window seals, rusty fenderwells, etc...., then insulate the inside of the single layer surfaces, if it doesn't get cold it won't build up condensation like the outside of a chilly beer bottle. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Thu Jan 21, 2016 1:09 pm Post subject: Re: VW bus Safare Custom Camper insulation |
Okay I'm going to check for any leak on the inside.
thanks for the advice.
Will let you know when any progress is made. |
laughtybus Samba Member
Joined: September 10, 2010 Posts: 118 Location: Terrell tx
Posted: Thu Jan 28, 2016 8:48 pm Post subject: Re: VW bus Safare Custom Camper insulation |
Busdaddy is right sounds like condensation is forming on the inside of the temperature differential. Try using 3m spray 90 rather than spray 77 better quality for heat and humidity |
Posted: Sun Jan 31, 2016 10:43 pm Post subject: Re: VW bus Safare Custom Camper insulation |
Yeah i found that the vent windows didn't close correctly and that's probably what creates this humidity. I will use this 3m adhesive thanks for the advice. |
ryyanking Samba Member
Joined: January 17, 2015 Posts: 17 Location: Seattle, Wa
Posted: Tue Jul 05, 2016 10:28 am Post subject: Re: VW bus Safare Custom Camper insulation |
How are you putting wood on the ceiling? I have 1/8in wood panels on the sides held in place by the side window frames, but I'd be concerned about the weight of the wood on the fiberglass. After 40 years these fiberglass tops don't seem to be all that strong weight wise.
Also what did you end up using for insulation? |
Posted: Tue Jul 19, 2016 9:04 pm Post subject: Re: VW bus Safare Custom Camper insulation |
I ended up insulating with bubble/aluminium insuation.
Also i cleaned the old glue to add some wood supports glued with construction adhesive. it worked great!
I then installed a bamboo type of ceiling with screws and chrome moldings, came out pretty cool! |
Posted: Tue Jul 19, 2016 9:40 pm Post subject: Re: VW bus Safare Custom Camper insulation |
Posted: Tue Jul 26, 2016 2:26 pm Post subject: Re: VW bus Safare Custom Camper insulation |
here is the finish product
i bought some bamboo paneling online and stained it then mounted it with some screws and chrome door steps molding from Home Depot.
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Tue Jul 26, 2016 9:18 pm Post subject: Re: VW bus Safare Custom Camper insulation |
Great job! I was gonna say I had mine painted and the painter said he found some holes that he glassed closed on the inside of the roof. Maybe you should get the outside painted too so it can be sealed up if it needs it. I would be sad to see the wood work get messed up. It looks great and I might copy what you did! _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
Posted: Tue Aug 09, 2016 2:37 pm Post subject: Re: VW bus Safare Custom Camper insulation |
yeah i actually got it painted. A good way to seal the holes made in its past life. it's now fully fixed inside and out! and we're back on the road my wife and I.
I'll put some pics of the outside in my gallery. |
Posted: Fri Feb 03, 2017 5:55 pm Post subject: Re: VW bus Safare Custom Camper insulation |
Check out my instagram for a lot of pics of VANLIFE : WandxrBus www.instagram.com/wandxrbus/
I am working on a big post to describe the whole restoration of my bus on www.wandxr.co/ |
