NWGeoff Samba Member
Posted: Sat Jan 09, 2016 2:48 pm Post subject: Has anyone ever seen a VW aircooled motor in a bike? |
Just thinking (or running in neutral). Has anyone ever seen a VW aircooled motor in a bike mounted in a fore and aft config. That is, take the motor and rotate it 90 degrees so the cylinders are inline, pointing front and back. Then you could put a standard sprocket on the output shaft and use an off the shelf tranny. It would make the bike long, but you would save space on the tranny.
As I said, running in neutral.
Thanks,
Geoff |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Sat Jan 09, 2016 2:52 pm Post subject: Re: Has anyone ever.....? |
I think the 3/4 (rear facing) cylinders will be shielded from fresh air and overheat. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Jan 09, 2016 6:45 pm Post subject: Re: Has anyone ever.....? |
I think that is an engineering issue that could be fixed without too much thrash, a couple of scoops or a ducted fan.
I'm trying to get around the transmission issue. Willis is out of business and those /2 trannies are pretty long in the tooth, whereas I can buy a 6 speed with reverse right off the shelf.
Geoff |
2weel Samba Member
Joined: February 18, 2007 Posts: 229 Location: Right in the middle of Coastal Cali.
Posted: Sat Jan 09, 2016 7:17 pm Post subject: Re: Has anyone ever.....? |
I play with VW powered motorcycles. I like your enthusiasm.
I think your idea of the fore and aft would just be too complicated. BUT! You would be the only one with one would be my guess.
Here is one of my bikes at idle. It is an Amazonas
https://www.youtube.com/watch?v=-DoE5NGSDwU
On Yahoo Groups there is a site dedicated just to VW powered Motorcycles.
"vwmotorcycles"
Butterfields, Willis 4's, Browns, Hamms, Burkey
None in your configuration tho.
Hope you find what you are looking for!
ooweel |
DeathBySnuSnu Samba Member
Posted: Tue Jan 12, 2016 4:05 pm Post subject: Re: Has anyone ever.....? |
I have seen one on a forum somewhere. I can not remember where though.
It was claimed that it got enough air. But it does not look like it would. |
2weel Samba Member
Posted: Fri Jan 15, 2016 3:27 pm Post subject: Re: Has anyone ever.....? |
Took the old 1600cc Kick Start only bike out to lunch today.
HeidelbergJohn4.0 Samba Member
Joined: March 01, 2004 Posts: 1199 Location: Havre de Grace, MD
Posted: Wed Jan 20, 2016 5:04 am Post subject: Re: Has anyone ever.....? |
you'd really be disrupting the cooling airflow through the cylinders running the motor sideways and would need to totally reconfigure the tins to get enough cooling air. I think you would really need to up the volume of air forced/ drawn through the cylinders that way. _________________ 71 LWB Manx style dunebuggy
71 Beetle
71 Volksrod
Machette Speedster
2012 Passat TDI SE (sadly sitting in a buyback parking lot somewhere waiting for it's heart to be ripped out.) |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Thu Jan 28, 2016 5:17 pm Post subject: Re: Has anyone ever.....? |
_________________ nothing |
Posted: Thu Jan 28, 2016 5:24 pm Post subject: Re: Has anyone ever.....? |
Not a VW engine, but an air cooled aircraft flat four.
2weel Samba Member
Posted: Fri Jan 29, 2016 11:46 am Post subject: Re: Has anyone ever.....? |
Anyone know how the power gets to the rear wheel? I'm guessing no transmission, just crank to rear wheel thru some clutch mechanism?
Honest Charlie made small Ford Flat head motorcycles using the flat head era small trans that they would weld it into third gear so you had a clutch and a gear to spin the rear wheel. |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sat Jan 30, 2016 8:08 am Post subject: Re: Has anyone ever.....? |
2weel wrote: |
The bike in the pic looks like it might have an old 4 speed transmission from a Harley Davidson. Looks like a mostly stock Harley frame too. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
