sambaphil Samba Member
Joined: September 04, 2009 Posts: 206 Location: Bellingham, WA
Posted: Mon Jan 04, 2016 3:41 pm Post subject: 1964 Notchback - S or N or ? |
Hi Guys,
I need some help on this notch. It has a lot of S features (chrome signals, 2 carb engine, etc). However, I would like to solicit input from the community. This is an imported notch from Europe (see pic below).
It looks like it should have chrome rocker molding and side molding with markers on it if its an S. Do you guys think this is an S based on the pictures? It was build January of 1964. Just trying to determine if I should buy and add the molding or not from ISP West.
_________________ Link to 1966 Samba Build
http://www.thesamba.com/vw/forum/viewtopic.php?t=607420
Link to 1971 Bay Bus - Clipper - L
https://www.thesamba.com/vw/forum/viewtopic.php?t=671945&highlight=
Single Port Samba Phil
[email protected] |
ALLWAGONS Samba Member
Joined: June 03, 2000 Posts: 4164 Location: Pasadena CA/DTLA soon China
Posted: Mon Jan 04, 2016 3:45 pm Post subject: Re: 1964 Notchback - S or N or ? |
See attached
http://www.thesamba.com/vw/forum/viewtopic.php?t=212733 _________________ I'd be UNSTOPPABLE if not for Law Enforcement and PHYSICS.
NON INFLUENCER APPROVED |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17963 Location: Eugene, OR
Posted: Mon Jan 04, 2016 4:26 pm Post subject: Re: 1964 Notchback - S or N or ? |
Yes, Plain Jane N models never look as good as an S model with all their chrome trim! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22697 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Mon Jan 04, 2016 5:33 pm Post subject: Re: 1964 Notchback - S or N or ? |
sambaphil wrote: |
Hi Guys,
Even N cars had rocker moldings, so this tells me that someone has done some custom work. What I'd do is pull an inner door panel and see if there is evidence of someone filling the trim holes on the backside of the door skin.
The biggest hint I see here is than "N" cars did not come with push button switches. They had a blanking plate and push/ pulls. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Mon Jan 04, 2016 6:46 pm Post subject: Re: 1964 Notchback - S or N or ? |
sambaphil wrote: |
Hi Guys,
The biggest hint I see here is than "N" cars did not come with push button switches. They had a blanking plate and push/ pulls. |
Good suggestion and thanks for the push button input. I don't think many people would put in push buttons if it wasn't already there.. _________________ Link to 1966 Samba Build
[email protected] |
sevy price1 Samba Member
Posted: Mon Jan 04, 2016 7:54 pm Post subject: Re: 1964 Notchback - S or N or ? |
Can't you determine if it is an S or N based off of the vin #? Or am I mistaken? |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22416 Location: Escondido CA
Posted: Mon Jan 04, 2016 8:01 pm Post subject: Re: 1964 Notchback - S or N or ? |
It was more than likely an S. Tip one as Tram said is the push button. Tip two would be the springs on the rear trunk - no prop rod Tip 3 is the dual carb motor - if original makes it an S.
On the surface - looks like a restored/custom 64 S Notchback. Looks nice BTW and wouldn't take much to stock it out more _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
M113 Samba Member
Joined: August 12, 2003 Posts: 362 Location: Dripping Springs, TX
Posted: Mon Jan 04, 2016 8:08 pm Post subject: Re: 1964 Notchback - S or N or ? |
I think the easiest way to determine if this was an N model is to see if the rear trunk light is there. The N model the pressing is there but the whole is not punched so no some light in trunk. All the other N features could have been removed but I think dome light would get over looked. Also if it's that early of a 64 it should of had prop rods on front and rear no springs. _________________ Joe -----------
68 Ghia Vert |
Posted: Mon Jan 04, 2016 8:36 pm Post subject: Re: 1964 Notchback - S or N or ? |
Hey Notch and M113,
Thanks for the input. I am 95.349% sure its an S model. The previous owner had it restored and must not have put the chrome rocker or belt chrome back on it. I will look around for the trunk light and also take off the door panels to see if there is filler where the trim clips would have been.
Notchboy, I am in Bellingham and come to Seattle a lot on business. If I get this notch all stock, maybe the 1500 club is in my future . Beers sometime this summer with our notches perhaps?
Thanks for all the input, I read as much as possible on the boards before posting but this one needed some extra validation, much appreciated! _________________ Link to 1966 Samba Build
[email protected] |
Notch Samba Member
Posted: Mon Jan 04, 2016 9:12 pm Post subject: Re: 1964 Notchback - S or N or ? |
You don't have to remove a door panel just feel the backside of the front fenders. This just looks like someones mild custom. Armrests and dash are S _________________ '64 Notchback
'67 Bug
(sunroofs both)
1964 Lavey Craft, Flatbottom V-Drive, 406 Ford |
Posted: Mon Jan 04, 2016 9:14 pm Post subject: Re: 1964 Notchback - S or N or ? |
sambaphil wrote: |
Hey Notch and M113,
Thanks for all the input, I read as much as possible on the boards before posting but this one needed some extra validation, much appreciated! |
Hells yeah You will have to make a Summer tip just to have a beer. I think its pretty darn clean looking. Like I said it wouldn be hard to go all stock. Its hard to tell but if they tried to copy a Ruby Red then its a sinch. When my 64 gets here by the end of this month - ill be looking closer at interior reproduction. Ruby Reds had brown or gray interiors if I recall.
Keep us posted on your decision. Would be a big plus to have one more nice notch in the PNW _________________
t3kg wrote: |
1964 1500 S
Posted: Thu May 26, 2016 6:19 pm Post subject: Re: 1964 Notchback - S or N or ? |
So I purchased this Notch from a character in Budapest Hungary. It took forever to get into a container, then to Bremerhaven on a train, then on a ship to Los Angeles, then on a truck to Bellingham.
Runs strong, looks sweet, but it is not ruby red. It was repainted something close (very nice paint) to Ruby Red but it's like a metallic red/orange. I have the original title/bill of sale from 1964 when a German farmer purchased it. There are other docs from the 2nd and it appears I am the 3rd owner.
[email protected] |
RAIDER SS Samba Member
Joined: November 21, 2003 Posts: 270 Location: Fairport, New York
Posted: Fri May 27, 2016 5:00 am Post subject: Re: 1964 Notchback - S or N or ? |
Absolutely gorgeous notch - congrats on your purchase!
You have a strong desire to add the chrome back on. You are a better man than I, as I’d be shaking too hard taking a drill to that perfectly painted body! _________________ 1972 SquareBack.....recycled back to life......
"Elwood" |
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Fri May 27, 2016 5:32 am Post subject: Re: 1964 Notchback - S or N or ? |
What size are the tires? |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13247 Location: Tejas!
Posted: Fri May 27, 2016 1:18 pm Post subject: Re: 1964 Notchback - S or N or ? |
Your wheels look like the 5.5" wide wheel that never came on a Type 3? The size,ET & VW logo etc are usually stamped on the 4 mounting flats on the inside face of 4 lug VW wheels. _________________ https://imgur.com/user/FisherSquareback/posts
