vugbug68 Samba Member
Joined: June 25, 2006 Posts: 2696 Location: sacramento
Posted: Mon Dec 28, 2015 8:37 pm Post subject: N/A "spinner" engine |
I have a few parts laying around and I'm thinking of building a high rpm spinner engine. I saw this video of a 64x94 1776 built by JPM https://www.youtube.com/watch?v=hgsjzTOm4EE and it got my mind thinking, not that I'm going build something that crazy but I like the principle of it.
I'll probably do a 1915 or 1835 thickwall with B pistons and long rods. Try to keep the engine narrow and the valvetrain light. Cam with a lot of duration but mild ramps.
I have a nice case opened for 94's and a nice 8 dowel non counterweighted German crank.
I have a set of Tim's stage 1 heads and another set of ported 42x37 heads but I have no idea who ported them.
Anyone build a high rpm spinner?
suggestions? _________________ 71 Super - Backroad Thrasher
66 Corvair - Weekend Cruiser
90 4 Runner - Muddin |
spencerfvee Samba Member
Posted: Mon Dec 28, 2015 8:48 pm Post subject: Re: N/A "spinner" engine |
sounds like a cool build . go for it .spencerfvee
vugbug68 wrote: |
suggestions? |
Brian_e Samba Member
Joined: July 28, 2009 Posts: 3284 Location: Rapid City, SD
Posted: Mon Dec 28, 2015 9:05 pm Post subject: Re: N/A "spinner" engine |
Keep the rods short and cut the barrels down to make it all work. The tin and header will become a problem, but the much shorter pushrods will be lighter and stiffer. B Pistons are usually slipper skirt, and are much lighter then full skirt A Pistons. I have been collecting parts to do the same.
Just make sure to do your math so your minimum cross section is up to par with your projected peak rpm.
Brian |
rs58rag Samba Member
Joined: August 22, 2010 Posts: 419 Location: riverside,ca
Posted: Mon Dec 28, 2015 9:45 pm Post subject: Re: N/A "spinner" engine |
Get your crank counterweighted and use the Tims stage one heads. |
fuguboy Samba Member
Posted: Mon Dec 28, 2015 11:10 pm Post subject: Re: N/A "spinner" engine |
How can you tell where stock crank was made ? why is 1500 cranks strongest and how do you identify ? What rpm is it ok to rev a stock 8doweled balanced crank and balanced rods 6000 ok ? Was thinking of a web 163 with 1.25 rockers . 1915 with Tims stage 1 40x35 maybe not a spinner like original poster just not sure on stock non-cw crank . |
theDrew Samba Member
Posted: Tue Dec 29, 2015 8:20 am Post subject: Re: N/A "spinner" engine |
I wanna say there was a thread on cal-look forums that covered that build.....trying to find it _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25 |
GTV Samba Member
Posted: Tue Dec 29, 2015 9:57 am Post subject: Re: N/A "spinner" engine |
I like the idea but I don't think the trouble of using a 64mm crank is worth it. Just use a 69mm, 1915cc, same parts, more power, less cost, easier to build. _________________ EMPI Power Rules! |
Posted: Tue Dec 29, 2015 10:08 am Post subject: Re: N/A "spinner" engine |
Nice thanks for that link.
my reason for non-counterweighted crank is less rotating mass, longer rods will help at high rpms and also make it easier to get the deck height correct probably will use 5.6" rods.
balancing will be key _________________ 71 Super - Backroad Thrasher
Posted: Tue Dec 29, 2015 10:13 am Post subject: Re: N/A "spinner" engine |
GTV wrote: |
I like the idea but I don't think the trouble of using a 64mm crank is worth it. Just use a 69mm, 1915cc, same parts, more power, less cost, easier to build. |
I'm using a 69 crank, the 1776 in the video has a 64 crank
I'm on the fence with the pistons, I can go 92 or 94, I'm leaning towards 92's for a bit less weight _________________ 71 Super - Backroad Thrasher
Posted: Tue Dec 29, 2015 10:17 am Post subject: Re: N/A "spinner" engine |
thick walled 92's! i'm assuming you'll be running a high compression ratio, so that'll help take the heat _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
Posted: Tue Dec 29, 2015 12:26 pm Post subject: Re: N/A "spinner" engine |
Read through the entire thread linked above, and take notes whenever Johannes posts. His super light shorty pistons are the key to making the stock crank live above 7000rpm. He gives all the equations showing how they put less force on the crank above 7000rpm then a stock piston does at 5000rpm. His is a 1603cc, and made 194hp around 8000rpm.
Brian |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Tue Dec 29, 2015 4:46 pm Post subject: Re: N/A "spinner" engine |
Find an old roller crank and let it rev! |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Tue Dec 29, 2015 10:23 pm Post subject: Re: N/A "spinner" engine |
fuguboy wrote: |
The problem is the weight of the parts connected to the stock crank. The lighter the rods and pistons, the higher the assembly can spin w/o pounding. This can only be achieved up to a certain point with modified AA forged B pistons and modified H Beam rods. For higher RPM, you'll need exotic. With regular B pistons and stock rods, 4500 RPM.
If you don't have cash to mill out material on the underside of the crowns and lighten the rods, buy a C/W crank. Actually, just buy a C/W crank regardless.
If you want less mass, pay DPR to severely lighten one of theirs. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
mark tucker Samba Member
Posted: Wed Dec 30, 2015 8:55 am Post subject: Re: N/A "spinner" engine |
hey stupid high rpm requires heads that are capable of the high rpm, and heads off the stage coach wont get it.unless your one of those guys that think high rpm is 4000 rpm or likes wiring a 4 cyl tack like a 8 cylinder tach.......and then theres the exhaust, and the induction and ignition....and tit valves,trick springs,right rockers,right cam,right retainers,right pushrods........ yup throwing your spain parts togeather will do just that spin high then...........splat so...go fer it and postaa viedieieio. |
rosevillain Samba Member
Joined: December 28, 2005 Posts: 1290 Location: roseville, ca
Posted: Wed Dec 30, 2015 11:37 am Post subject: Re: N/A "spinner" engine |
I have a 69mm counterweighted crank that probably needs work (balance and such), that I would be willing to trade. |
Bob Brugge Samba Member
Joined: April 09, 2015 Posts: 721 Location: Missoula, MT
Posted: Wed Dec 30, 2015 12:04 pm Post subject: Re: N/A "spinner" engine |
Brian_e wrote: |
Brian |
Can you explain this please? I have never heard this before...I checked the thread link listed and was lost in 1300cc circuit racing land. _________________ Keep on Dubbin'! |
HotStreetVw Samba Member
Joined: October 03, 2004 Posts: 871 Location: Wild West
Posted: Wed Dec 30, 2015 12:39 pm Post subject: Re: N/A "spinner" engine |
Engines are air pumps. You might be able to breath through a straw sitting in your office chair, but you wont do it running a marathon.
Intake port cross section will dictate the maximum power potential. Period.
The 1776 has MS230s, JPMs 1915 has MS230s. Thats 230cfm @ .600" lift.
If you want a small motor to spin high, build a 1915 with a set of ultra wedgeports.
One thing to note is the JPM motors are pusing the boundries for HP/liter. If you don't have a lot of money to spend, you might as well make that 220 hp with a 2386cc at a much lower RPM.
Play with this calculator. It basically use mass flow rate to calculate HP. Keep the engine type constant and try different engine sizes. You will notice for the same head flow, the HP will remain constant, the RPM changes.
http://www.wallaceracing.com/calcafhp.php
Bob Brugge wrote: |
Brian_e wrote: |
Brian |
Can you explain this please? I have never heard this before...I checked the thread link listed and was lost in 1300cc circuit racing land. |
_________________ 4inBhore
50 Split - 2724cc NA. Haltech injected
62 Notchback - 2542cc Turbo WIP |
Posted: Wed Dec 30, 2015 2:27 pm Post subject: Re: N/A "spinner" engine |
What he said ↑.
If you dont know an accurate airflow for your heads, you can use this calculator to figure what your max RPM will be given the minimal cross section of your intake tract. Measure the smallest diameter, convert to area, and then plug in your numbers.
http://www.wallaceracing.com/chokepoint.php
Remember this is assuming your heads are perfectly ported, and not some as cast head with big valves tossed in.
Most properly done intake tracts will have the min. cross section just below the valve seat. With off the shelf offset and straight manifolds, the diameter about 1" up from the flange is smaller then the seat diameter on a 40mm intake, so that would be the smallest point, and also the reason all manifolds need to be FULLY ported, not just match ported. Think smooth even tapered funnel, ending in the correct cross section for your desired RPM range.
This one will work backwards for you. You input your bore, stroke, and projected max RPM, and it will tell you the smallest your cross section can be.
http://www.wallaceracing.com/ca-calc.php
Brian |
Posted: Wed Dec 30, 2015 5:16 pm Post subject: Re: N/A "spinner" engine |
I think the flow of the heads may be a better thing to use..... as properly is extreamly vauge term and meas oh somuch different things to different people&also different porters...and different applications also have different porting techniques. |
