newa Samba Member
Joined: June 27, 2008 Posts: 13 Location: Portsmouth, UK
Posted: Wed Dec 23, 2015 8:49 am Post subject: 54 UK Kombi |
I started on my 54!
Yes, I have actually started welding. And totaling up new panel costs..
I have been trying to find some detail on the top of the B posts where the gutter or drip tray, reinforcement and roof support meet, there were cable holes here but there is no longer enough left for me to see where the holes were and how things routed etc. Anyone got pics? Here is what they looked like:
Thanks |
spit nolan Samba Member
Joined: March 08, 2005 Posts: 123 Location: redditch, united kingdom
Posted: Wed Dec 23, 2015 11:38 am Post subject: Re: 54 UK Kombi |
I put some pics on your ssvc thread, of top of my b pillar, I can get more in the new year when can get back up to my bus. _________________ 1963 Squareback
1967 Porsche 912
RSVP VW |
Andy dub Samba Member
Joined: July 23, 2015 Posts: 1 Location: Teesside, Middlesbrough
Posted: Tue Dec 29, 2015 2:22 pm Post subject: Re: 54 UK Kombi |
Hi Chief, i darn't take my head lining down in case I find the same result, I'll try and find a day to pop up if you wish, cheers Andy |
Hellberg Samba Member
newa Samba Member
Posted: Wed Dec 30, 2015 10:37 am Post subject: Re: 54 UK Kombi |
The LH roof rot before I cut it. Replaced the full length of gutter tray, it's welded in now but I have not put the strengthener strip in yet since I am not sure on the hole at the top of the B pillar and I am looking for a spot welder.
newa Samba Member
Posted: Sun May 29, 2016 4:10 pm Post subject: Re: 54 UK Kombi |
Perhaps time for an update here! You've seen it all before I am sure.
The roof is off and I just removed the remaining crust of the RH gutter, it was actually getting fairly solid toward the rear, it's a compromise between orig steel and decent rework. I also removed the inner side panel which will allow me to spot weld everything back together and de-rust. It should also help to properly repair the window frames and there are a few dings I can straighten out properly. I am weary of taking too much or more than necessary apart at one time and risk losing that character and detail of the original construction, possibly ending up with a scary pile of rusty pieces and ordering a containers worth of panels to build a new van.
I wasn't expecting lead on the inner panel to the B pillar, a lot of it too.
Also a seam in the outer side panel in the middle of the rear popout? Looks like a tidy gas weld? I thought this would be a single piece?
Top
Lower
_________________ Buying Barndoor parts & panels, RHD 54 Kombi in resto. |
