andk5591 Samba Member
Joined: August 29, 2005 Posts: 16754 Location: State College, PA
Posted: Fri Apr 29, 2016 2:09 pm Post subject: Re: Neil's bubbletop volksrod build |
TDCTDI wrote: |
I don't know, not to take anything away from Ed Roth's genius, but weren't his creations fiberglass? I think this takes it to another level. |
Agreed... _________________ D-Dubya Manx clone - 63 Short pan,1914.
eyetzr Samba Member
Joined: October 09, 2013 Posts: 1423 Location: Toronto, Ontario. Canada
Posted: Fri Apr 29, 2016 5:23 pm Post subject: Re: Neil's bubbletop volksrod build |
Looks great, I am loving the progress. Shaving the oil cooler tin and relocating the oil cooler would be nice, but you will need a place for a oil cooler. (ask me how I know ). Keep up the metal madness _________________ I think he meant "rare", as in "not well-done" |
gr8cobbler Samba Member
Joined: May 04, 2006 Posts: 916 Location: Midlife Crisis, Midwest
Posted: Fri Apr 29, 2016 8:14 pm Post subject: Re: Neil's bubbletop volksrod build |
Insane vision, way cool and getting better all the time. _________________ Gary
Being a cheap old fart is just a front for my actual lack of money. |
VeeDubWolf Samba Member
Joined: July 12, 2010 Posts: 656 Location: Yakima, WA
Posted: Fri Apr 29, 2016 11:52 pm Post subject: Re: Neil's bubbletop volksrod build |
This is gonna be a mighty nice UDO! (Unidentified Driving Object) _________________ Two Bugs-
'70 rust-bucket sunroof sedan
'69 PO hack-job special
-Plus a wide assortment of various parts'n'junk |
nshaddox Samba Member
Joined: January 18, 2005 Posts: 612 Location: Hammatramma, MI
Posted: Sat Apr 30, 2016 8:55 am Post subject: Re: Neil's bubbletop volksrod build |
Thanks for all the complimentary comments. Helps keep me motivated.
No progress on car this weekend, visiting Pittsburgh and helping out on a drywall job here for more funds. Should be back at it on Monday. |
Posted: Tue May 03, 2016 2:41 pm Post subject: Re: Neil's bubbletop volksrod build |
alright, small progress.
reshaped t3 cylinder tins so they are less ugly
built a battery tray, obtained battery
also purchased enough wiring to hopefully build a complete wiring harness. wont arrive for a week or so though. |
Posted: Wed May 04, 2016 12:34 pm Post subject: Re: Neil's bubbletop volksrod build |
started today by making the panel that will hold the fuse panel
then started trying to figure out how to close up the back of the interior.
larger arch left over from hoops for bubble top welded in place. smaller arch bent up around a rear brake drum and just sitting in place for now while I decide whether I like it or not.
so the smaller arch will be left open to expose the transmission. space between two arches will be filled. space above outer arch will be blended into a parcel tray of sorts. that's the current plan at least, not sure if anyone has any suggestions? |
TheGreenVW Samba Member
Posted: Thu May 05, 2016 3:25 am Post subject: Re: Neil's bubbletop volksrod build |
Enjoying the build! Keep it up |
Petfisheric Samba Member
Joined: November 27, 2014 Posts: 121 Location: Knoxville, TN
Posted: Mon May 09, 2016 8:45 am Post subject: Re: Neil's bubbletop volksrod build |
I like the idea of exposed transmission but you will get a lot of heat rolling in from the opening. Maybe a lexan cover so you can see it but eliminating the air flow? |
Posted: Mon May 09, 2016 2:16 pm Post subject: Re: Neil's bubbletop volksrod build |
well ended up just bubbling the access panel for the transmission. looks more factory and matches bubble for steering box. also couldn't really envision how to make panels that would expose enough of transmission to look cool.
template shows how little of the trans would be exposed if I had cut a hole. decided that looked kind of dumb and a bubble would be better.
also got some wires in. still waiting on a few more things before I can start wiring harness.
Posted: Mon May 09, 2016 7:29 pm Post subject: Re: Neil's bubbletop volksrod build |
The bubble-panel looks good! I imagine it'll be removable for service? _________________ Two Bugs-
Posted: Tue May 10, 2016 3:57 am Post subject: Re: Neil's bubbletop volksrod build |
Yep, that's the idea. |
Joined: August 31, 2013 Posts: 12816 Location: North Carolina
Posted: Tue May 10, 2016 5:52 am Post subject: Re: Neil's bubbletop volksrod build |
That looks really close to a rear apron, perhaps you could start fabbing those up to fund the project. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue May 10, 2016 5:57 am Post subject: Re: Neil's bubbletop volksrod build |
There's other folks that can fab up stuff a little nicer than I can. But yea, if anyone needs any little bits for their projects I'm willing to try fabbing them. Always looking for ways to find the project... |
Posted: Wed May 11, 2016 6:15 pm Post subject: Re: Neil's bubbletop volksrod build |
more wires came in. everything for harness and battery hook up here except connectors. going with original style crimp connectors, had to buy new tool which is always fun.
no other progress because ive been working a demo job taking a Detroit house down to the studs. |
timcurtis67 Samba Member
Joined: August 21, 2013 Posts: 87 Location: Carlisle PA
Posted: Thu May 12, 2016 3:28 am Post subject: Re: Neil's bubbletop volksrod build |
Great build!
Where did you get your wire from? _________________ 67 Desert Fox Spoiler |
Posted: Thu May 12, 2016 3:57 am Post subject: Re: Neil's bubbletop volksrod build |
4RCustoms on eBay. Best deal I found on short lengths of striped wire. Battery cables from another eBay store. Also different sources for terminals and crimpers |
Posted: Thu May 12, 2016 5:37 am Post subject: Re: Neil's bubbletop volksrod build |
I started buying my wire from Del City. They sell on Amazon as well as direct. Only problem is that you can only buy full spools (100' or so), but a lot of their prices for 100' are what many places charge for 25' or less.
You need to be concerned, particularly with large wires, that they are all copper and not just copper coated aluminum. I discovered that way after the fact on one project. Ran some nice beefy power wires that was of adequate size, only later to discover that they were aluminum. You typically need to step up to the next size for aluminum wires. Fortunately I went heavier than I needed, so I should be OK. There's quite a few brands on Amazon that are not 100% copper and its not always stated. But the Del City stuff is 100% copper. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Mon May 16, 2016 4:02 pm Post subject: Re: Neil's bubbletop volksrod build |
good advice. didn't want more clutter n the house so I didn't buy much more wire than I needed. everything is copper.
started wiring harness today. figured out how dash will be laid out in the process. not much to photograph but took a couple snaps.
final trimming to take place later. |
Posted: Wed May 18, 2016 11:49 am Post subject: Re: Neil's bubbletop volksrod build |
ran battery positive cable and gas line thru tunnel yesterday
back to metal work today. fabricated sides of rear parcel tray and just finished blanking the top panel. jigsaw seems to have walked away so taking a break before hammering out flange. will likely add some ribs to top panel as well.
edges formed from leftover 1/2"x1/2" square stock from the hoop materials.
blanks
ribs
welded
top blanked
