oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Wed Jul 27, 2016 7:17 pm Post subject: Re: 1965 westfalia so-35 flipseat |
The 'Rhombus Rollen' wheels arrived today. I think these are about the best replacement for the original short of finding a vintage one.
Original:
I had to buy the pair, so if you are in need of one pm me. The axle piece that mounts inside the cabinet is interesting, looks like it was heated and hammered flat to create the mounting surface. |
Red Fau Veh Samba Member
Joined: September 07, 2012 Posts: 3037 Location: Prescott Az.
Posted: Wed Jul 27, 2016 9:19 pm Post subject: Re: 1965 westfalia so-35 flipseat |
That is totally rad! You could get 3 more and build a Westy skateboard! _________________ 1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote: |
Swivel Seat panels are for people with no friends |
oakman Samba Member
Posted: Mon Aug 01, 2016 7:23 pm Post subject: Re: 1965 westfalia so-35 flipseat |
Here's the rack the day we picked up the bus. Bent up and no wood left on it. Badge missing but otherwise complete down to every brass screw. All six clamps with their correct hardware too.
I placed a wtb ad for original slats and quickly had a nice 'seasoned' set of slats from a very helpful samba member on the other end of the country. Thank you very much Nick! I went to work trying to straighten and assemble the rack. While not originals, I think these slats look great and match the look of the bus nicely. I had to set it up on the bus of course:
That's it for now, more later! |
velvetgreen Samba Member
Posted: Thu Aug 04, 2016 10:57 am Post subject: Re: 1965 westfalia so-35 flipseat |
Very good match on the Rhombus wheel. Did you end up scoring it off of ebay or somewhere else? The match looks almost identical and the font looks almost period correct. Doubt many people would notice that it has been replaced. |
oakman Samba Member
Posted: Thu Aug 04, 2016 5:32 pm Post subject: Re: 1965 westfalia so-35 flipseat |
velvetgreen wrote: |
I found them on e-bay from a private seller, not the actual company. I was surprised to find anything even close. I'm not sure what the modern application is for these although the Rhombus company does make many different types of casters/wheels for hospital equipment, shopping carts etc.
I will run the oq crusty one for now but it's nice to have a spare! |
oakman Samba Member
Posted: Fri Aug 05, 2016 12:36 am Post subject: Re: 1965 westfalia so-35 flipseat |
Speaking of wheels, i borrowed an og paint 15" from my singlecab and had this 215/75 all terrain mounted up to see how it fits and looks:
It seems to fit fine and clear everything ok. With it on the rear there was plenty of room on the inside of the tire from the spring plate. I ran bfg a/t's on my old toyota tacoma and they were a great long lasting tire and did good off road. These have a new sidewall tread that is gnarly looking compared to the previous generation. I like how it looks on the bus so i'm going back for the others tomorrow. |
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Fri Aug 05, 2016 5:21 am Post subject: Re: 1965 westfalia so-35 flipseat |
The rack came out very nice. And those tires look great on the front. About how much room is there on the back side between the tire and the jack port/ wheel well looks close in the photo. |
oakman Samba Member
Posted: Fri Aug 05, 2016 2:25 pm Post subject: Re: 1965 westfalia so-35 flipseat |
Big Bill wrote: |
With the wheels pointed straight, there's about 1 1/2" to that jackport flange. At the tightest point pictured below with wheel turned there's about 5/8" between there:
Turned the other way has plenty of room:
Of course it will sit lower once the cabinets and engine are back in. I studied the Big Meats thread and it seems like these will be ok. We'll see after i'm driving on them. If i don't like them on here or they rub too much it's ok because i'm planning to do a little lift to the single cab when it gets it's turn.
Eventually i want to fix the wheel wells and blend the paint so i can run stock looking tires and the chrome hubcaps that it is m-coded for. I don't like how hubcaps with cut wheel wells look, although i'm really diggin the baja flipseat look for now. The truck mirrors can stay for now too.
Enjoy
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Fri Aug 05, 2016 4:15 pm Post subject: Re: 1965 westfalia so-35 flipseat |
vwuberalles wrote: |
Those tires look amazing on there!!! I gotta get a set for my 67, I have a set of 66 Beetle wheels I want to mount some meaty rubber on. Do you think they'd clear an uncut wheelwell? |
If you have Beetle tires on, switching to a Bus load rated tire and Bus rim will make a huge difference in how it drives on the freeway. _________________ In Stereo, Where Available! |
Posted: Fri Aug 05, 2016 4:20 pm Post subject: Re: 1965 westfalia so-35 flipseat |
Eric&Barb wrote: |
If you have Beetle tires on, switching to a Bus load rated tire and Bus rim will make a huge difference in how it drives on the freeway. |
It's currently on the stock original 14's. The Bug wheels are a set I've had sitting around for ages. One of these days I was planning to clean them up and paint them & add some meaty rubber to run on the bus when the mood strikes. _________________ 1973 Superbeetle: 1st car, owned since age 12. Update thread --> https://www.thesamba.com/vw/forum/viewtopic.php?p=9919140#9919140
1966 Beetle: My new project. (SOLD) Build thread--> https://www.thesamba.com/vw/forum/viewtopic.php?t=678040 |
Enkiel Samba Member
Joined: October 21, 2004 Posts: 2771 Location: Quebec, Canada
Posted: Fri Aug 05, 2016 4:21 pm Post subject: Re: 1965 westfalia so-35 flipseat |
Are those "All Terrain T/A KO2" by BFGoodrich? They look alot more expensive than the Grabber AT2. Think the difference is worth it? _________________ 1964 Turkis Flipseat |
oakman Samba Member
Posted: Fri Aug 05, 2016 10:05 pm Post subject: Re: 1965 westfalia so-35 flipseat |
I'm going to try them on my 67 camper maybe this weekend, i will report back regarding the rear fitment. Not sure with the bug wheels though, aren't they skinnier?
Enkiel wrote: |
Are those "All Terrain T/A KO2" by BFGoodrich? They look alot more expensive than the Grabber AT2. Think the difference is worth it? |
Yes they're the ko2's. I couldn't find any of the ko anywhere. They're quite a bit more than the Generals. The Generals look good too, i almost got them instead. The Generals are probably a better value for the price, but i haven't tried either on a bus as of yet. |
oakman Samba Member
Posted: Sat Aug 06, 2016 10:04 pm Post subject: Re: 1965 westfalia so-35 flipseat |
I mounted the wheels on the 67 today and took it out for a little test ride. They went on with no problem and clear everything nicely out back with stock wheel wells. Even with the bus on jack stands they never contact the lip of the wheel well:
They never rubbed anywhere, even a couple of spots where i expected it might when i was off road. What i really liked was how planted the bus felt on the pavement compared to the kumho 195/75 14" passenger tires.
Big Bill wrote: |
It leaves about 1/3" with the wheel turned at it's closest point with the jack flange on the 67. A more realistic representation than the pic on the flipseat:
A few more picures here:
http://www.thesamba.com/vw/forum/viewtopic.php?p=8169780#8169780 |
oldbusboy Samba Member
Joined: June 25, 2006 Posts: 604 Location: Bowen Island, BC Canada
Posted: Sun Aug 07, 2016 10:35 am Post subject: Re: 1965 westfalia so-35 flipseat |
On your test of those tires on your '67 did you find them noisy? Did it effect your top speed at all?
When I swapped from radials to bias ply tires on my bus I noticed the top end speed was reduced.
Your sub hatch looks awesome btw!
Trevor _________________ 1968 porsche |
oakman Samba Member
Posted: Sun Aug 07, 2016 11:15 am Post subject: Re: 1965 westfalia so-35 flipseat |
HerrLowlight wrote: |
Trevor |
The "gearing change" with the large tires is noticeable. All the gears are longer now. The speedo is showing slower than my actual speed too. I still need to take it out on the highway and climb some grades. That will be a better test of the noise factor too. I can usually only hear the wind when i'm going 60. Most of what i tested yesterday was to see if the fronts were going to rub off road through cross ruts and body twisting off camber situations. I don't bash my bus very hard on the trails though, just slow 1st and 2nd gear most of the time. I use my motorcycle for the heavy abuse. |
earlywesty Samba Member
Joined: May 03, 2004 Posts: 2358 Location: In the woods, Ontario
Posted: Sun Aug 07, 2016 1:52 pm Post subject: Re: 1965 westfalia so-35 flipseat |
Enkiel wrote: |
I've had both on buses. They do not compare in quality, durability and traction. BFGs are way better. |
oakman Samba Member
Posted: Sat Aug 13, 2016 5:11 pm Post subject: Re: 1965 westfalia so-35 flipseat |
buseric wrote: |
Enkiel wrote: |
Thanks buseric, I always liked them on my old Toyota. The BFG's lasted 40k plus on that truck and were great off road too.
It's been too hot to do cabinet work lately, sometimes i have to go do something else instead. This week's evenings were spent working on the window seals.
I worked my way from the cargo doors around back and up the driver's side leaving the doors and windshields for last. I made sure to orient the logos as they were.
in case anyone is wondering where to put the seam, they were centered on the top for the stationary side windows so i re-installed the new ones the same way:
Everything went smooth until i got to the driver's windshield. The original Delog D-08 glass was still there and i was able to get it out carefully without any problem. Amazingly it wasn't pitted too bad and i was happy to be able to use it again. When i was re-installing it, i was down to the last 4" of string pulling when the lower corner against the 'split' bar went "tink". Damn..shit happens.
So to keep it as original as possible, i had an extra set of Delog windshields that i installed. The original that i broke was d-08 and these are d-110. I thought these were a matched set until i looked closer and noticed the font is slightly different and the driver side is "ver delog bund E". Not sure what the 'E' means. Anyway, i got them in using LOTS of vaseline around the frame and on my pull string. I was glad to get them in without any more drama!
I started on the doors last night. It took awhile to get the old petrified seal removed from the outer frame but here's where i'm at now:
Good times! Not much else new to report, just slowly making progress. |
oakman Samba Member
Posted: Wed Aug 31, 2016 10:21 pm Post subject: Re: 1965 westfalia so-35 flipseat |
I had to remove the truck mirrors to remove the window frames and now i'm not sure if they will be going back on or not:
Both original mirrors suffered this treatment, probably the same time the fenderwells were cut :
I like the area around the subhatch where you can see the hand painting from Westfalia after the roof was hacked:
Another thing I've noticed that some of the subhatch westy's I have seen have their tent mounts painted over. These were never painted:
Awhile back I got lucky and found this sweet flipseat brochure on e-bay just posted minutes earlier with a buy it now. I think it was thirty bucks shipped:
Below you can see the door cabinet with the sticker from 1978 Long Beach Formula One. That sticker was a pain to remove and it left a ghost image. The veneer beneath is actually raised slightly like a relief carving from the way it weathered over the decades. I did my best to flatten it out as much as possible without burning through the veneer:
Another e-bay score, I found the same sticker in France and just had to get it. Only difference is where the old one had the American flag with 'Long Beach' above it, this one is for French driver Paul Ricard with the French flag:
I'm not planning on sticking it on there but thought it was a cool small piece of the bus's history recaptured. I'm weird like that. _________________ Brandon |
