daveyork427 Samba Member
Joined: October 30, 2015 Posts: 2 Location: Ark City, Kansas
Posted: Fri Oct 30, 2015 3:50 pm Post subject: 67 912 Barn Find |
Hello, I'm new here and am looking for advice. I came across a 67 912 in an old fallen down barn. The car was shrink wrapped but pack rats still got to it. Appears to have a VW engine. Seats are still in the box. Most body work seems done for the most part. However there is still plenty to do. Appears to have a fender kit that makes it look like a 911. I will post some pictures. I would like to know what I've came across here. Any help would be greatly appreciated. Thanx!
jt912 Samba Member
Joined: March 16, 2006 Posts: 207 Location: Eugene, OR
Posted: Fri Oct 30, 2015 4:05 pm Post subject: |
Can you post a picture of the top side of the motor? |
Posted: Fri Oct 30, 2015 4:15 pm Post subject: |
I believe it's a Type 1 |
jt912 Samba Member
Posted: Fri Oct 30, 2015 8:08 pm Post subject: |
Diamond plate? Now I have seen it all. Certainly not a Porsche power plant. Looks like it should clean up nicely. |
Steve F Samba Member
Posted: Sat Oct 31, 2015 5:29 am Post subject: |
Love the wheels! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Sat Oct 31, 2015 5:43 am Post subject: |
daveyork427 wrote: |
And a bad one at that. _________________ Glenn
Member #1009
#BlueSquare |
VWCOOL Samba Member
Joined: June 02, 2006 Posts: 1821 Location: Down under
Posted: Sat Oct 31, 2015 3:04 pm Post subject: |
Good project! Hopefully you can replace those flared guards! |
Restomod Samba Member
Posted: Tue Dec 08, 2015 8:29 am Post subject: Re: 67 912 Barn Find |
Pressure washer and some glass and beat it like you stole it |
fuscavw Samba Member
Posted: Thu Apr 14, 2016 12:40 pm Post subject: Re: 67 912 Barn Find |
Cool find. Can you post pics of the motor mount/cross member? I'm faced with putting a type 1 engine in my 912. |
Starbucket Samba Member
Posted: Fri Apr 15, 2016 3:54 pm Post subject: Re: 67 912 Barn Find |
fuscavw wrote: |
You have to get a Type 1 Bus case motor or a universal as they are drilled for rear mount.
If you have your 912 rear mount it will be an easy adaption. |
Posted: Tue Apr 19, 2016 9:07 am Post subject: Re: 67 912 Barn Find |
I was afraid of that. I'm missing the original rear mount and have a nice, bigger VW engine I would like to run. Now I'm faced with either making my own mount or building my own motor. |
Posted: Tue Apr 19, 2016 1:14 pm Post subject: Re: 67 912 Barn Find |
fuscavw wrote: |
They used to make an adaptor for non Bus mount motor to Bus. It was a plate that used the oil pump studs (I think they needed to be drilled & tapped 10mm & be longer) to mount the plate to the motor. The plate was U shaped to mount to the "Mustache Bar. His mount looks like it mounts to the oil sump bolts and oil pump (he shows part of it in his pic.s). I think a 68-71 Bus Mustache Bar will be your easiest adaption. If interested I will measure the center of mount holes between VW BUS and 912 Porsche Bar as I have both. Then you can try to find one to use. |
Posted: Mon Apr 25, 2016 9:44 pm Post subject: Re: 67 912 Barn Find |
Starbucket wrote: |
fuscavw wrote: |
I appreciate the offer. Looks like I might be drilling and tapping the bosses on my late type 1 case/engine and just bought an original 912 cross member off this site. I hope to adapt it to work with this engine. |
