IdubThee Samba Member
Posted: Mon Oct 12, 2015 2:49 pm Post subject: Help me get my 68 squareback resurrected! |
I'm attempting to revive my 68 squareback that's been sitting for 5 years. Prior to parking it, I had her gone over by a VW mechanic who sorted out all the major issues. It ran fine for a while, but started to gradually run rougher and rougher. Eventually it would start, but couldn't stay running for more than a few seconds. I didn't have the money or energy to spend any more time with her, and so she was parked.
In preparation to sell, I would like to at least get her running. The pictures give an idea of what I'm dealing with.
One issue I remember from years back.... The spark plugs seemed to be shorting on the engine compartment lid. Do I need right angle plugs? Should I swap carb gaskets while I'm at it?
I'm already working on cleaning out the gas tank...
by the way I've got almost no automotive experience or VW knowledge, but am willing to learn and pretty handy in general.
any wisdom will be greatly appreciated
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22356 Location: Kimball, Mi
Posted: Mon Oct 12, 2015 5:46 pm Post subject: |
Yes, definitely get a set of angled plug wires. You can use Bosch wires for a 68 to 73 type 3, as they have the correct ends at the distributor cap, and are long enough for use with your carbs.
As for pulling the carbs and changing the gaskets, that might be a prudent thing to do, since it looks like you've got a converted bug engine in there, and might have the metal bug gaskets in place (you really want the thick paper style). While I had them off, I'd drill and tap the manifolds for a balance tube, to help make the engine run smoother at idle. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Fri Oct 16, 2015 10:10 pm Post subject: |
Thanks! |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17962 Location: Eugene, OR
Posted: Sat Oct 17, 2015 10:42 am Post subject: |
That fabric covered fuel hose is known to have pinhole leaks in it eventually. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sat Oct 17, 2015 8:19 pm Post subject: |
I'll replace those. I'm working on cleaning and sealing the tank right now. Drained the gas, rust inside wasn't awful but I got the por-15 kit and pulled out the tank...
Any links to more info on those carb balance tubes? |
Sqrbckguy38 Samba Member
Joined: December 21, 2004 Posts: 415 Location: Tooele, ut
Posted: Sun Oct 18, 2015 7:39 am Post subject: |
Move the fuel filter out of the engine bay. It's a fire hazard waiting to happen sadly. correct plug woes will help, and as stated before, changing manifold gaskets wo be good, but not required unless you're thinking they might be leaking. Might be good to clean off anyways. Also check your linkage to ensure the carbs are opening equally, that gave me fits until I figured it out. _________________ It's not the fall that hurts, it's the sudden stop at the bottom.
69 Square needs love, even after 15 years
70 Fasty former dd, now my daughter's
67 Beetle, Opal |
Posted: Sun Oct 18, 2015 7:57 pm Post subject: |
Where is an alternative location for fuel filter? |
Posted: Sun Oct 18, 2015 8:24 pm Post subject: |
IdubThee wrote: |
In the rubber hose beside the transmission, or up front under the fuel tank. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Oct 26, 2015 12:41 pm Post subject: |
In place of the fuel filter, should I use a connector in it's place, or route the line from front straight to the fuel pump? |
Posted: Mon Jul 25, 2016 4:39 pm Post subject: Re: Help me get my 68 squareback resurrected! UPDATE! |
so...
after some detours, i finally got the engine to start! The time has come to adjust the idle and attempt to synchronize the carbs I believe. The idle RPM in John Muir's book is 600 for type 3 and I think 900 for bugs. My question is what number should I be aiming for with this aftermarket engine? |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5986 Location: Brooklyn
Posted: Tue Jul 26, 2016 5:19 am Post subject: Re: Help me get my 68 squareback resurrected! |
The Muir book is cute but I wouldn't rely on it for specifications - get the Bentley manual.
600 rpm is low. I have seen two different specs for Type 3 idle speed, both from VW sources. I've seen 750 rpm plus or minus 50 rpm and 850 rpm plus or minus 50.
I like to keep mine on the higher end of the latter spec, somewhere between 850 and 900 rpm.
I figure it keeps the oil pressure up, keeps cooling air flow up a bit, keeps heater output up (in the winter), and keeps the generator spinning a bit faster. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Sun Aug 07, 2016 6:01 pm Post subject: Re: Help me get my 68 squareback resurrected! |
engine is running okay... but i've got a fair amount of gas dripping from connection at top of fuel pump and at t connection in middle. Can I swap lines for generic pep boys stuff, or do I have to get the braided vw line? |
Posted: Sun Aug 07, 2016 6:51 pm Post subject: Re: Help me get my 68 squareback resurrected! |
I used standard 5/16" reinforced rubber Goodyear/Gates etc fuel hose on my fuel injected '69. I had to buy bigger worm drive clamps for the bigger outside diameter 5/16" hose. I think carburetors use a little small 1/4"? The new braided stuff from Germany is still funky & will develop pinhole leaks according to Russ Wolfe. He had a big roll of new Continental braided fuel hose, but refused to sell any of it to us because of leaks he had when using it! _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Sun Aug 07, 2016 8:06 pm Post subject: Re: Help me get my 68 squareback resurrected! |
IdubThee wrote: |
Yes. And since you have carbs, use 1/4 inch hose from the end of the fuel filter to the pump, and out of the pump to the "T" and then to the carbs. The 1/4 inch hose fits the carb and fuel pump fittings better than the 5/16ths hose Mike suggested, and it fits better than the cloth 8mm hose you currently have on there. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Feb 23, 2017 2:39 pm Post subject: Re: Help me get my 68 squareback resurrected! |
UPDATE:
I finally got the engine running pretty swell after replacing the fuel pump, plugs, points, rebuilt carbs, and tuned the whole thing...then I didn't start the car for about 3 months or so until just the other day. Now it won't start. The battery is fully charged and it turns over, but it won't stay running more than one or two gasps. In theory, shouldn't it start fairly well considering how well tuned it was when I last started it? I don't know where to start since when I left it, I had gone through everything. Maybe add fresh gas? |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13247 Location: Tejas!
