Third brake light
Page: Previous  1, 2, 3  Next
rdwood
rdwood is offline
PostPosted: Thu Sep 17, 2015 1:16 pm    Post subject: Reply with quote
Sorry I should clarify; I didn't go through the slots but inserted from the side, inside the engine bay up into the vent area and used the sticks to position it.
rdwood
rdwood is offline
PostPosted: Thu Sep 17, 2015 7:01 pm    Post subject: Reply with quote
Here are two photos of my 3rd brake light; with and without camera flash so you can get an idea of how it is really hidden in the shadows and not too obvious when not in use.
[/img]
René R.
René R. is offline
PostPosted: Mon Feb 22, 2016 4:51 pm    Post subject: Re: Third brake light Reply with quote
I realized I never posted a picture of what I ended up with. I decided to buy a light from J&L, as mentioned in my first post. It fits very neatly at the bottom of the rear window and is very unobtrusive when not lit up, and VERY visible when it is lit. This is a nifty unit.
mcem2001
mcem2001 is offline
PostPosted: Fri Jun 03, 2016 11:15 am    Post subject: Re: Third brake light Reply with quote
where'd you run the wires for this?
JeffRens
JeffRens is offline
PostPosted: Fri Jun 03, 2016 6:48 pm    Post subject: Re: Third brake light Reply with quote
Saw this at a local car show on a 56 Oval. Just what I was looking for and installed one on mine.....
http://www.jandlenterprise.com/products/brakelighter.htm
JeffRens
JeffRens is offline
PostPosted: Fri Jun 03, 2016 6:51 pm    Post subject: Re: Third brake light Reply with quote
Wired into taillight harness junction block under right side engine tar board (or whatever that's called) ...
My57Oval
My57Oval is offline
PostPosted: Thu Jun 16, 2016 5:50 pm    Post subject: Re: Third brake light Reply with quote
Hi. For anyone who used the J&L LED 3rd brake light for an Oval, did you buy/use the bracket offered or did you not and it's fine without it?
http://jandlenterprise.com/images/BacketInstructions8%5B1%5D.5x11.pdf
Thanks!
JeffRens
JeffRens is offline
PostPosted: Thu Jun 16, 2016 6:18 pm    Post subject: Re: Third brake light Reply with quote
I used the bracket because it would definitely not mount on a horizontal plane without it. The bracket does however create a small gap between the light and the glass and a small gap at the bottom which illuminates the interior with the red light a little more than I would like. If I get ambitious I'm going to try it without the bracket one of these days. The light will definitely be pointing up instead of horizontal eye level, but I bet it might be pretty effective anyhow. I'll let you know....
My57Oval
My57Oval is offline
PostPosted: Thu Jun 16, 2016 7:54 pm    Post subject: Re: Third brake light Reply with quote
Cool. Ill buy the bracket. Did you happen to find an existing access hole for the wiring? Must be a spot somewhere eh?
ZENVWDRIVER
ZENVWDRIVER is offline
PostPosted: Sun Jun 19, 2016 10:29 am    Post subject: Re: Third brake light Reply with quote
... also, use hand signals
5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
My57Oval
My57Oval is offline
PostPosted: Sun Jun 19, 2016 11:45 am    Post subject: Re: Third brake light Reply with quote
Yes. Best to have both hands off of the steering wheel when expecting to get wallpoped from behind. For the full effect steering shaft impale. 😬
JeffRens
JeffRens is offline
PostPosted: Sun Jun 19, 2016 12:27 pm    Post subject: Re: Third brake light Reply with quote
I decided to remount the J&L light without the bracket. The light definitely points upwards when flush mounted directly to the glass, but is still pretty darn bright and very little interior lighting. I like it much better. A very classy, well built lite....
ZENVWDRIVER
PostPosted: Sun Jun 19, 2016 6:35 pm    Post subject: Re: Third brake light Reply with quote
... I understand your concern... guess it all depends where you live and drive. I am on the southern plains of Oklahoma, where there are not that many other cars on the road and other drivers are truly very considerate of antique car drivers, for the most part... we (you and I) don't share the same concerns, I must say and I have learned, it is unrealistic to be concerned having expectations... having expectations is a state of mind and does not reflect reality... still, a more visible brake light is considerate.
1960 single cab
'87 Toyota MR2
My57Oval
My57Oval is offline
PostPosted: Sun Jun 19, 2016 6:41 pm    Post subject: Re: Third brake light Reply with quote
Yes, I wholeheartedly agree.
“Out beyond ideas of wrongdoing
and rightdoing there is a field.
I'll meet you there."
Buying a 3rd brake light tomorrow!
JeffRens
JeffRens is offline
PostPosted: Sun Jun 19, 2016 6:45 pm    Post subject: Re: Third brake light Reply with quote
Yea, I'm mostly inner city driving. Just restored this car and have already had 2 people run up my butt when I was stopping and turning. The snowflake lights really are barely visible.... OK for the 50 MPH speed limit and traffic flow in 1956, but not so much now. I'm doing this more to save my ass rather than to be considerate Smile
ZENVWDRIVER
PostPosted: Tue Jun 21, 2016 10:22 am    Post subject: Re: Third brake light Reply with quote
... I can relate. I once had a 1955 Messerschmitt and nearly got hit a couple of times. That second time was a near miss and I would have been DOA. As a result, I sold the vehicle, right after that... those experiences were all in Bergen County, NJ... the most densely populated area of the country.
Eventually, we relocated to sparsely-populated Oklahoma and, for a whole host of reasons, would never go back to the craziness of crowded conditions and inconsiderate drivers.... being thoughtful and considerate is of paramount importance to me, at this stage of the game.
... look at the Messerschmitt tail lights... look like '52 to '55 VW hearts. That's my third brake light on the middle... Ha, ha, that wasn't the problem... most drivers did not even see the vehicle. Bought a big Vanagon Westy after that.
1960 single cab
'87 Toyota MR2
Eric&Barb
Eric&Barb is offline
PostPosted: Tue Jun 21, 2016 4:48 pm    Post subject: Re: Third brake light Reply with quote
Have you removed the inner plastic shade lenses that make the taillights so dim during the day?
Have been putting yellow accessory turn signal lights on our VWs on the license plate frame. Both vintage yellow cone shaped ones and smaller bullet shaped LED ones that are sold for 12 volt, but work just fine on 6 volt. These are connected into the turn signals so work both as turn signal and brake lights.
Found out years ago when going from USA all red taillights to Euro yellow topped taillight lenses on our 1963 KG that was 12 volt. With correct all red TLs had constant problem with other drivers not seeing the signals when changing lanes and getting the finger often. About 95% of that problem went away with just installing the Euro yellow top TLs.
So far have had not legal problems with the extra lights traveling thru most of the states West of the Mississippi River.
In Stereo, Where Available!
Hustlers67
Hustlers67 is offline
PostPosted: Mon Jul 18, 2016 9:54 pm    Post subject: Reply with quote
dc wrote:
I used an LED flexible rope/strip and it slipped in without much fuss in the vent area of my '61
I was thinking of doing something similar.. I have concerns how to fix it in there.. last thing I want is LED robe being sucked into the fan!! Also, how did you wire it up?
Frederik
Frederik is offline
PostPosted: Thu Jul 21, 2016 7:18 am    Post subject: Re: Third brake light Reply with quote
15W "Eagle eye" Led light and a home made alu bracket. Has steady light (for 3rd brake) and a flashing mode I'm going to use as emergency light. https://youtu.be/FHr8Uc5LP-Q
yamaducci
yamaducci is offline
PostPosted: Fri Jul 22, 2016 5:51 am    Post subject: Re: Third brake light Reply with quote
I have a Safety Star Tag topper on my Oval as a third brake light.
I have a few in stock if anyone is interested.
http://www.thesamba.com/vw/classifieds/detail.php?id=1689085
Also there is are a couple suppliers who makes the LED snowflake circuit panels for the normal brake lights. They are super bright.
-John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested.
Page 2 of 3
