Iguana Samba Member
Posted: Thu Sep 03, 2015 6:00 pm Post subject: |
Stock ECU's are fine and there are plenty of them out there. I have done a lot of conversions with Subaru Engines and used the Stock ECU on them all.
It takes better care of the engine and makes it run nicer with less issue.
If you are on a budget I would buy a driving Subaru and then you can pull everything you need from it. The car will give you headers, ecu, loom radiator, fans etc etc.
When doing a conversion you can always sawp $$$$ for Time so if you have time you can save $$$$$. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Fri Sep 04, 2015 4:36 am Post subject: |
Dale M. wrote: |
Mount radiator in back and just use rubber....
Dale |
Dale - have seem om Shoptalk that it seems like most folks dont have success with rear mounted, but thats in a bug, so maybe with the kit car would not be an issue. Would sure make things simpler...... _________________ D-Dubya Manx clone - 63 Short pan,1914.
Tom_Kathleen Samba Member
Joined: August 26, 2004 Posts: 919 Location: Vernon, CT
Posted: Fri Sep 04, 2015 6:04 am Post subject: |
Here is how we did the conversion on a Manxter. Tom
http://www.manxgallery.org/gallery/album437 _________________ Manxter #16, 1968 Meyers Manx & Kick-Out SS #16 (WIP)
Manx Club & CVA |
Vito85 Samba Member
Posted: Sun Sep 06, 2015 8:33 am Post subject: |
jsturtlebuggy wrote: |
Vito,
What size of Subaru engine are you plan on using?
The 2.2L engine seems to be the most common swap. If you have a timing belt problem (breaking) the valve do not get bent like in a 2.5L
As has been said the Shop Talk Forums in the Conversion Perversion section has much more information then here.
I see in the one picture you posted the radiator is in the very back. This will work and be simple as long as you can get enough air flow to it.
I am using Outfront adapter and flywheel and their EMS computer set up.
I have a JDM engine that came with the electrical harness cut off where it would go to the chassis. |
well...... I think I can buy a ej25 at JDM here in texas for about 1,500 and they include the harness too,
I want to use the guages ( VDO jet cockpit style ) already on the car, and I think I will need a aftermarket ECU for that
I did not think about the return on the gas tank, not sure what to do about that,
it is getting complicated...... I would like to get a pro street or rancho transmission with a new clutch too, so I do not have any issues on the future
then...... I will need upgrade at least the front breaks to disk breaks ( for security even if I do not plan to speed )
also I would like to buy the complete car, in that way, I know the engine was running... lol
and of course part of this dream it is to get A/C on the car ( here in texas is HOT )
I'm not planning to sell the car, I just want enjoy the driving, cruising slow and enjoy the ride
please keep enter information, it help me a lot
thanks |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Mon Sep 07, 2015 7:31 am Post subject: |
Vito85 wrote: |
Vito,
thanks |
The VDO Jet Cockpit speedometer gauge should be driven by the VW left front wheel speedo cable (if it is a mechanical gauge), If gauge is electronic (doubtful), the VSS (vehicle speed sensor) can be installed at CV joint on transaxle & you can use an Electric Speedometer Pulse Generator Ring For Type 1 Beetle CV Joint. Stock Subaru ECU should have wiring pin-outs that can be used to drive tachometer. You will want a water temp gauge, oil pressure gauge, (oil temp gauge would be a luxury).
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Vito85 Samba Member
Posted: Sat Sep 19, 2015 5:51 am Post subject: |
I watch a couple of videos about the subaru conversion
so, I will need some help here please
on this video.....
VW Subaru Conversion Fuel Injection System DIY Plus $ Saving Tips
https://www.youtube.com/watch?v=GoAumihmEiU
he talks about a 5/16 hose...... but the VW use 1/4 hose for the tank
hoe can you change it or adapt it ?? I'm lost about it
he talks about a ford ranger fuel pump..... is that a good choice ??
and a fuel filter ( carquest 86097 )
but ...... about the return....... can I use the neck of the fuel tank to plug in the return line ?? or do I have to make a hole on the tank ??
also, on this other video
https://www.youtube.com/watch?v=dLYp80cCzB0
he talks about a mg migget (76--79 ) radiator........ is that a good choice ?? what is the best radiator..... I'm in texas where is HOT as hell ( 100 degrees )
he made a point to cut/trim the brackets....and mention that he add the oil pressure sensor..... ???? it is not part of the engine ? or the ECU ??
I know there are many questions, but I really would like your help
God bless
have a great weekend |
Vito85 Samba Member
Posted: Sat Sep 19, 2015 5:57 am Post subject: |
[/quote]
bnc[/quote]
mmmhhh...... please let me ask, a aftermarket ECU ( outdoor motors ) should provide all that.... right ? I just will need to buy the guages..... is that right ?? also I think ( I do not know ) the aftermarket ECU should not require a speed sensor ..... right ???
thank you in advance for all your help
God bless
Driftin Samba Member
Joined: August 27, 2012 Posts: 141 Location: Wilsonville, Oregon
Posted: Sat Sep 19, 2015 6:10 am Post subject: |
Yes Outfront Motorsports is where I purchased my EMs Stinger and engine wiring harness from. They ask you what motor your using it on and program it for plug and play. This saved me a lot of time. It cost me a little extra over a OEM ECU but it works perfectly!
Vito85 Samba Member
Posted: Sat Sep 19, 2015 6:30 am Post subject: |
new question regarding the A/C system......
I think ( please correct me if I'm wrong ) that getting a complete donor car is the best way to go with the swap......
now the question is.... how do I transfer the A/C system ??
get a professional shop to drain the gas, and how do I get the controls.... ???
do I just take it apart one by one ?
I want to plan all before get stuck in the middle of the process.... lol |
Posted: Sat Sep 19, 2015 7:13 am Post subject: |
MG Midget radiator will be too small; I've had 4 MG Midgets/Austin Healey Sprites, and their cooling suffered with the 1275cc engine...
http://www.griffinrad.com/tips.cfm
Iguana Samba Member
Posted: Sat Sep 19, 2015 11:48 am Post subject: |
With the A/C you are better off getting a universal head from Vintage Air etc as it will fit much better. That is what we use in the buggies and kit cars and have no issues.
We retain the factory compressor on the Subaru Engine
Vito85 Samba Member
Posted: Sat Oct 31, 2015 9:32 am Post subject: |
ok, I'm reading and researching a lot ( too much information )
anyway....... I came across this pic ( buggy with a 6 cylinder subaru )
I wonder how hard can it be ?? if I'm going to do the swap..... why not a 6 cylinder ???
do you guys have any info ?? any pro's or con's ??? |
Posted: Sat Oct 31, 2015 10:57 am Post subject: |
... talk to Outfront or Smallcar regarding the Subaru flat 6 swaps. I'm looking into a swap using the Subaru EZ30 series engine, but there can be issues in trying to use stand alone ECM. Frankly, the 6 opens up a whole new can of worms. If you proceed with the Subaru project, keep it simple and stick with the EJ-series of 4 cylinder engines...
Why not simply use an Audi A4 or VW Passat 1.8 turbo 4 drivetrain, or the V6 variants?
Posted: Sat Oct 31, 2015 2:13 pm Post subject: |
A 4 cylinder EJ25 turbo has about the same HP as that 6 cylinder and will get better gas mileage (if you can keep your foot out of it). You will have a little boost lag, but what we find is that when you are on the boost, you are going too fast! Tom _________________ Manxter #16, 1968 Meyers Manx & Kick-Out SS #16 (WIP)
Manx Club & CVA |
weasel_ugs Samba Member
Joined: March 16, 2012 Posts: 721 Location: Prescott Valley,Az.
Posted: Sat Oct 31, 2015 6:09 pm Post subject: |
Alot of extra weight using the 6cyl. |
Posted: Sat Oct 31, 2015 6:38 pm Post subject: |
weasel_ugs wrote: |
Roughly 75 pounds.
GPM Samba Member
Joined: February 21, 2008 Posts: 133 Location: Leicestershire, UK
Posted: Sun Nov 01, 2015 8:30 am Post subject: |
The only question I have to ask is why?
AC in a buggy, unless you have a full hood etc, is about as much use as tits on fish. It's a huge pile of extra work, at least one extra rad and then all the pipework....to me, its like those who buy a cabriolet and tick the AC option box....
As for engine, consider old skool Corvair power.....its the route I've gone. No standalone mgt, no miles of wiring and a simple adaptor plate and off you go.... |
Posted: Sun Nov 01, 2015 10:06 am Post subject: |
GPM wrote: |
The Corvair is, well... ancient. Fun little engine, but power limited for it's displacement, without going to an expensive build. Reverse rotation required to mate properly to VW trans. A stock 2.5 Subaru engine can easily achieve Corvair power levels, with strain.
But - the 'vair is a fun engine, regardless.
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sun Nov 01, 2015 10:10 am Post subject: |
GPM wrote: |
AC in a buggy, unless you have a full hood etc, is about as much use as tits on fish. It's a huge pile of extra work, at least one extra rad and then all the pipework....to me, its like those who buy a cabriolet and tick the AC option box...... |
The OP doesn't have a buggy. It's a full-bodied kit car. Full doors with roll-up windows. I'm working on an assembling an AC setup for my VW powered version right now. And I use it as a semi-daily driver. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
GPM Samba Member
Posted: Sun Nov 01, 2015 12:54 pm Post subject: |
didget69 wrote: |
GPM wrote: |
bnc |
I get all of that, absolutely i do. However, it requires so little in the way of fabrication or extras to fit, its a worthwhile consideration. I run the 110hp, 160lbft torque engine. Unless you are going drag racing, its more than enough and propels a buggy to a scary speed very quickly indeed. I didnt even reverse rotation mine, just flipped the diff in the box and its held up, despite being given some serious abuse.... I don't really get the need for any more power and the added complications of a water cooled lump. Still, that's just my view.
As for the OPs vehicle, I didn't realise it as a full bodied car. That will teach me to read the whole thread. Makes more sense now. Is still a lot of work but good luck to the OP. |
