Tcash Samba Member
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Tcash Samba Member
Posted: Tue Jul 19, 2016 7:33 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Your readings are all over the place. Either the test leads are bad or the rotor is.
IIRC the resistance should be around 1 kohm.
thnx to mayor ratwell
http://www.ratwell.com/technical/IgnitionSystem.html
Tcash |
Posted: Tue Jul 19, 2016 8:04 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Wall outlets read 117, just shy of the 120 volts. I can't believe the rotor is that wack. I can't remember what brand it was, but I'm usually happy and successful with Napa parts. Anyway, would my original coil be in question?
Condenser does indeed lack a maker mark, and has a red wire.
Edit: Both the condenser and rotor are Echlin products. _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
Tcash Samba Member
Posted: Wed Jul 20, 2016 4:43 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
So I noticed I can find Bosch ignition components on here in the classifieds as well as through various VW vendors. Locally I can acquire Beck/Arnley components, any grounds to think these would be worthwhile items?
I'll test the coil this afternoon. It's black but I haven't noticed if it's original VW or not, it sure as hell looks like it. From Ratwell's numbers, ohm levels between 7-9 are good?
Edit:
Picking up a Altrom Rotor from Napa today at noon. The Beck/Arnley stuff cost and special order status was enough for me to just buy a Bosch tube up kit from Bus Depot. I may check out Van Cafe. _________________ The Bus Barn Ltd. Co.
Posted: Wed Jul 20, 2016 10:38 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Local Napa sourced a Altrom rotor from the warehouse, and when I picked it up I was pleasantly surprised to find a Bosch (made in Spain) rotor. First thing I noticed was the significant difference in weight and presumably quality between the correct and Echlin. $12.50 same day isn't bad.
Also noticed the bottom of the Bosch rotor has a 1.8 (my engine) and 983 (my canister short #), coincidence? I think not.
I tested the primary of the coil, reads 3.8 ohms. It is indeed a Bosch black coil stamped VW. _________________ The Bus Barn Ltd. Co.
Tcash Samba Member
Posted: Wed Jul 20, 2016 10:46 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Just out of curiosity Ohm test the new rotor. Might want to right it down to.
Thanks
Tcash |
Posted: Wed Jul 20, 2016 12:11 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
New Bosch rotor is good.
Took the bus for a little lap around town, too damn hot to be driving around for long periods at 100 degrees, but whoa was I surprised by the response on the throttle, the quick warmup, and the more consistent idle. I still need to tinker on the carbs.
I have a guy here locally with a true Brazilian ignition coil for $55 with a new bracket. I wasnt able to measure the secondary of the coil, any reasons why? I tried do as seen in the link Tim shared. _________________ The Bus Barn Ltd. Co.
Tcash Samba Member
Posted: Wed Jul 20, 2016 12:17 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Quote: |
I wasn't able to measure the secondary of the coil, any reasons why? |
That would lead me to believe the secondary winding has a break in it = bad coil
Tcash
You may not be getting contact on one of the terminals. Put both test leads on the same terminal to make sure you are getting contact on that terminal. |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Wed Jul 20, 2016 12:37 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Tcash wrote: |
Might want to right it down to. |
Huh? _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Tcash Samba Member
Posted: Wed Jul 20, 2016 12:49 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
jtauxe wrote: |
Tcash wrote: |
Huh? |
Huh
Tcash wrote: |
Might want to right write it down to. |
Tcash |
Tcash Samba Member
Posted: Wed Jul 20, 2016 12:50 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Quote: |
How could the secondary be bad and yet still fire up the distributor and allow the bus to run? |
It wouldn't |
Tcash Samba Member
Posted: Wed Jul 20, 2016 2:23 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Quote: |
I wasn't able to measure the secondary of the coil. |
Your test method must not have been correct if the engine is running.
Tcash |
Posted: Wed Jul 20, 2016 3:32 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Well maybe I have the Magical Coil
Or perhaps, just maybe I’m a doofus, but I like the first thought.
Still planning on going through with picking up the Brazilian coil tomorrow if the gent can locate it.
What’s a good wax compound to get that oxidation out, a month to the show and the bus needs to be nice.................. _________________ The Bus Barn Ltd. Co.
wcfvw69 Samba Purist
Posted: Wed Jul 20, 2016 3:50 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
SamboSamba22 wrote: |
What’s a good wax compound to get that oxidation out, a month to the show and the bus needs to be nice.................. |
Good to hear she's running well. I LLOOVVVEE my DVDA distributor in my bus. So smooth. Immediate throttle response, mid range torque..
You need a rubbing compound to remove oxidation. I'd suggest you review some videos on you tube as there are some good ones on how to buff the paint w/out burning holes in it w/a power buffer. The compound removes the oxidation, polishes the paint and restores the shine. A good wax seals the paint and adds shine. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Fri Jul 22, 2016 4:20 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
So both the WW center pin and Ate master cylinder are coming in tomorrow around lunch.
I have a couple questions. With regards to removing and replacing the original brake master cylinder, when going to install the new component, is it necessary to bench bleed the cylinder? I came across Colin’s techniques of bleeding the brake cylinder with it actually installed, loosely, and going through with the process of fitting the brake lines, again loosely, and priming the cylinder with the standard brake bleeding procedure.
Is this the best way to prime the master cylinder? Is there any other things to look out for or plan to do since I have the servo?
I hope this NOS Ate MC is as nice as the ole boy mentioned it to be, supposedly the seals are nice and soft.
Now for the center pin, I’m hoping it isn’t much more than what I’ve read on some very detail threads. It’s always a wonder when going into some nice and old metal sections with pivots and pressure. Better get some rest tonight and feeling mighty tomorrow afternoon.
Also have in the mail, a stock style Dansk muffler on its way, I can’t take the excessively hot and loud, let alone bulky twin-piped EMPI “performance” exhaust.
I’ve been thinking and lightly looking into the EGR valve layout and components on my 74. Please, wise and knowledgable folks, are there any perks to the EGR set being put back into the bus vs. leaving everything out? Apparently the 74 Cali-emissions layout is a little different than the years prior and the 75-79 layout?? The south, emissions are nothing of the matter, and two, the date makes it emissions exempt but I’m flirting with the idea of OG layouts.
Thanks guys _________________ The Bus Barn Ltd. Co.
