tb03830 Samba Member
Joined: December 02, 2009 Posts: 1045 Location: Leavenworth, KS
Posted: Tue Mar 01, 2016 9:44 am Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
So we got the bumper mounts tacked on. We mocked up the muffler deck and it is all off. I now have to get it all correct. What a pain. Slow but steady.
_________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
1964 Convertible Bug - 1600cc SP engine with a stock H30/31 Carb and SVDA Distributor - Swing Arm Highway Flyer Tranny, Gene Berg's Temperature Dipstick, 2.5" drop spindles, 2" narrowed adjustable front end. Chromed OEM fan tower. |
Dake Samba Member
Joined: September 02, 2014 Posts: 481 Location: Georgia
Posted: Tue Mar 01, 2016 2:51 pm Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
I wanted to know whats the size of your both? |
sportin-wood Samba Member
Joined: September 12, 2010 Posts: 2008 Location: Texas
Posted: Tue Mar 01, 2016 3:14 pm Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
Nice progress!! _________________ .
Paused 66 project bug
"Relax, all right? My old man is a television repairman. He's got this ultimate set of tools. I can fix it." --- Jeff Spicoli |
Posted: Tue Mar 01, 2016 3:17 pm Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
Dake wrote: |
I will find out. Not sure. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
Posted: Thu Mar 03, 2016 3:02 pm Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
tb03830 wrote: |
Dake wrote: |
I will find out. Not sure. |
14' x 19' x 9' on the outside. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
Posted: Mon Mar 07, 2016 11:12 pm Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
So we have been working hard but have found a lot of rust. When I say a lot I mean ALOT! So, even though we have a sand blasting booth we decided to have it glass bead blasted. Tomorrow we are taking it to a company in Independence, MO to have it fully stripped. When I say stripped I mean every nook and cranny. We loaded the body today into the box van we rented so it can stay out of the rain predicted. I hope to have more soon.
VeeDubWolf Samba Member
Joined: July 12, 2010 Posts: 656 Location: Yakima, WA
Posted: Tue Mar 08, 2016 1:27 am Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
Good plan! Then you can really get to work patching it when you get it back! _________________ Two Bugs-
'70 rust-bucket sunroof sedan
'69 PO hack-job special
-Plus a wide assortment of various parts'n'junk |
Posted: Tue Mar 08, 2016 11:14 pm Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
So we went to a Media blaster and had him blast the bug. It was a pain but we got it done. Let me explain. We had to get it there (one hour away) and then get it home with a lot of rain in the forecast. The box van we got worked great.
We then got it finished and as we drove away with it in the back it started to pore.
Once home we put it back in the booth and began to clean into so we could prime it.
We then got it primed and ready for metal work. We put a coat of filler primer on it. The stuff dries fast.
Posted: Sun Mar 13, 2016 10:34 pm Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
So we started to work on the metal this weekend. While I welded my Son started to tear down the 1200 CC engine. It looks bad but just needs some lovin. We think rings, cleaned up heads and maybe new bearings and she will be fine. Oh don't forget a lot of cleaning an painting. We will be switching to 12v also. Parts needed but know how to do it.
Posted: Sun Mar 13, 2016 10:44 pm Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
While my son worked on the engine I kept going on the welding. We got it all lined up with the finders and the rear apron and added a stiffener short term to hold it after we got it lined up.
Posted: Mon Mar 14, 2016 6:59 am Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
Body's looking a lot better already! That engine looks a lot better than most of the ones I've gotten for parts too! _________________ Two Bugs-
63Ragtop NZ Samba Member
Joined: December 04, 2007 Posts: 895 Location: West Auckland
Posted: Mon Mar 14, 2016 1:48 pm Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
yeah great progress! keep it up. _________________ If you can't join them, beat them! |
Posted: Tue Mar 15, 2016 11:01 pm Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
So we have started on the Right Rear Support Bracket. Found a lot of rust there.
A lot of rust.
So as we are setting it up and making sure it will go in the right place we notice the bracket is wrong. It is angled wrong. I then had to break the manufactured welds to reapply it in the right angle. What a pain.
The yellow line is the center of the current bracket and the Red line is were it should be.
Posted: Wed Mar 16, 2016 3:29 am Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
That's unfortunately a common issue with most cheaper panels, next to thinness. Also, and I'm sure you know this already, the paint on the repair panels should be removed before priming/painting as it's just cheap rust-deterrent for during shipping and peels easily. Good work on correcting it! _________________ Two Bugs-
Posted: Wed Mar 16, 2016 6:30 am Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
VeeDubWolf wrote: |
That's unfortunately a common issue with most cheaper panels, next to thinness. Also, and I'm sure you know this already, the paint on the repair panels should be removed before priming/painting as it's just cheap rust-deterrent for during shipping and peels easily. Good work on correcting it! |
I will have my son sandblast it. I noticed the thickness issue also. I will be adding second layer of steel to the bracket like a factory bracket. Notice the factory double layers. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Wed Mar 16, 2016 6:56 am Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
Looks like they did a good job blasting the bug. What do they charge for that? Thinking of having mine done, Thx _________________ 1963 Ragtop Bug |
Posted: Wed Mar 16, 2016 1:04 pm Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
EMPIImp69 wrote: |
Looks like they did a good job blasting the bug. What do they charge for that? Thinking of having mine done, Thx |
$450.00 for Glass Bead Media blasting only. The guy is in Independence ,MO USA _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
Posted: Sun Mar 20, 2016 9:58 pm Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
So after the debacle with the Support being at the wrong angle I final got time to work on the welds and get it all back together.
Once I get all the welds In the area done I will add a thin layer of Bondo and you should never see the difference. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
Posted: Wed Mar 23, 2016 1:01 am Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
The beginning of the 1200cc rebuild. My son got the case cleaned up.
Posted: Wed Mar 23, 2016 2:15 am Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
Wow, that's a clean case! What'd it take to get it so clean, and are you going to coat or seal it somehow? _________________ Two Bugs-
