tb03830 Samba Member
Joined: December 02, 2009 Posts: 1045 Location: Leavenworth, KS
Posted: Tue Nov 03, 2015 10:53 pm Post subject: |
So we moved the Body in the bay. Baby steps. Had to have four of us to move it safely.
_________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
1964 Convertible Bug - 1600cc SP engine with a stock H30/31 Carb and SVDA Distributor - Swing Arm Highway Flyer Tranny, Gene Berg's Temperature Dipstick, 2.5" drop spindles, 2" narrowed adjustable front end. Chromed OEM fan tower. |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Wed Nov 04, 2015 5:26 am Post subject: |
Love the home brew paint booth. I have been trying to figure something like this out that I could use to keep dust and paint all over to a minimum and the wife happy. |
Posted: Wed Nov 04, 2015 1:49 pm Post subject: |
We will initially use it as a sand blasting booth but it will later turn into a paint booth. I can do almost anything if I have the facilities and the tools. Tools I can barrow or buy but facilities are hard. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Wed Nov 04, 2015 4:39 pm Post subject: |
tb03830 wrote: |
We will initially use it as a sand blasting booth but it will later turn into a paint booth. |
Cool!
Be sure to wear a properly fitting respirator for BOTH operations! _________________ Jesucristo es mi Seņor y Salvador! |
Posted: Wed Nov 04, 2015 11:52 pm Post subject: |
So we finished the booth. We found if we do this again we would put the plastic on the inside of the frame. It allows for the sand to fall the ground and not build up on the wood. It would take a couple of pieces of wood in the top to do it but it doable. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
grandpa pete Samba Member
Posted: Thu Nov 05, 2015 7:11 am Post subject: |
I will suggest you put a fan on the backside of your "booth " that will blow air through and out the garage door .
The fine dust and the paint WILL go EVERYWHERE unless you guide it out..so the paint fumes aren't being pulled through the electric fan (fire hazard ).the fan has to be pushing out through the booth .
It took a month to get the paint dust off everything in the garage when I did this wrong 15 years ago _________________ 63 two fold rag
66 sedan delivery Type 6
http://www.thesamba.com/vw/forum/viewtopic.php?t=569619&highlight=sedan+delivery |
Posted: Thu Nov 05, 2015 12:58 pm Post subject: |
I will do that. Good point. My son was worried about paint and the motor and I had simply not put much thought into it. We will cut a hole in the back and mount a box fan on the outside blowing in. We will open the garage door a little at the bottom and air will flow out. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
Posted: Wed Feb 24, 2016 7:43 am Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
Sorry guys. I will add new photos very soon. We have been working but I forgot to update SAMBA. Lots of pictures to share.. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
Posted: Wed Feb 24, 2016 8:18 am Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
So we started to sand blast. We have also been using fine grain grinder and sander to get through the body paint. As you have seen the pain is amazingly thick. Pictures to come. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
Posted: Wed Feb 24, 2016 8:28 am Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
Posted: Wed Feb 24, 2016 8:41 am Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
Having trouble uploading photos for some reason. The yare small enough but suddenly they stopped uploading after I did about 5 of them. _________________ "Sic Vic Pacem, Para bellum - Pray for peace, prepare for war."
Posted: Wed Feb 24, 2016 8:46 am Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
MomoMoto Samba Member
Joined: March 02, 2015 Posts: 84 Location: Greenville, SC
Posted: Wed Feb 24, 2016 8:51 am Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
Thanks for updating, Uhg Bug is moving right along, great work you guys!! _________________ ------------------
'61 Beetle Ragtop
'15 Golf GTI |
Pinetops Samba Member
Posted: Wed Feb 24, 2016 9:55 am Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
Thanks for the uhg-date. Man, it has been painted a bunch of times. _________________ "A rolling bus gathers no rust." |
VeeDubWolf Samba Member
Joined: July 12, 2010 Posts: 656 Location: Yakima, WA
Posted: Wed Feb 24, 2016 12:51 pm Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
Well, hopefully the many layers of paint acted as a preservative!
It's coming along though! _________________ Two Bugs-
'70 rust-bucket sunroof sedan
'69 PO hack-job special
-Plus a wide assortment of various parts'n'junk |
Posted: Wed Feb 24, 2016 6:20 pm Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
I think it may have protected it, that bare metal looks pretty clean so far! _________________ "A rolling bus gathers no rust." |
Dake Samba Member
Joined: September 02, 2014 Posts: 481 Location: Georgia
Posted: Wed Feb 24, 2016 6:59 pm Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
Great job. I like the booth looks like you have some room in it. What are the dimensions? |
Posted: Fri Feb 26, 2016 12:28 am Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
Here are some pics of the sand blasting and the grinding we have done in the last week or so.
Flash makes the grinding look worst than it is.
Posted: Fri Feb 26, 2016 12:31 am Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
Taking big steps now as my son continues to sand blast. I have begun to replace the rear end. We plan on making the rear panel removable to make engine swaps easier. We have all the metal to do it and the tools now to get the measurements right.
Posted: Sun Feb 28, 2016 11:49 pm Post subject: Re: Verna Resoration - 1964 Type I Beetle Sedan (Uhg Bug) |
Starting the real work now that I have it ready. Note all the measurements I have written on the side.
