GoMopar440 Samba Member
Joined: February 06, 2015 Posts: 491 Location: Montana
Posted: Sun May 01, 2016 10:12 pm Post subject: Re: Budget rail rebuild and dual carbs project |
Ugg, I'm beat. I had to make a two hour round trip to drop the wife off at the airport by 7AM after getting a little bit less than an hour of sleep last night. The weather was really nice today for a change so I took advantage of it and started working on the rail as soon as I got home. However, my energy reserves were all used up a few hours ago, so I'm going to bed as soon as I finish this post.
I still had some of that crappy steel sheet metal floor (under the seats) beneath the old 1/8" aluminum diamond plate that came was on rail when I got it. The PO had it riveted, screwed and welded all over the place, so it fought me the whole way. I ended up basically chopping and beating it apart into a bunch of smaller sections in order to be able to get it out. Here's all the pieces of what used to be a single sheet (with holes everywhere).
With that finally out of the way I was able to prep the frame to remove the rust and prime it. I just quickly sprayed a heavy and messy primer coat as this frame is going to be replaced as soon as I'm able to get a better one. It's also going to be hidden under the new diamond plate floor section so I won't have to look at the paint runs everywhere. I laid on a foam mat underneath the rail to get coverage on all the exposed metal I could find down there as well.
After a bit of measuring, drawing and cutting this is what I ended up with for the new floor section. It's only 16ga aluminum diamond plate, so it's about half as thick as the old front floor section. I used a coarse flap disk on the angle grinder to remove the raised diamonds around the edges of the panel after cutting it to shape. That will make attaching it to the frame easier when I get to that part of the project.
With a little fine tuning I was able to get it to fit fairly closely to where I wanted it. I still need to trace the frame outline onto the bottom of the sheet from underneath. That will give me am exact location for the seat and tunnel supports so I can get the mounting holes lined up without guessing. I don't want a bunch of extra random holes drilled all over the place like the PO did on the old floor. The gaps around the edges will get filler strips to close them off and seal it up. If I have enough of this diamond plate left after the tunnel is finished, I'll use it to make a forward bulkhead to close off the open area in front of where our feet go.
With the new floor section temporarily in place, I was finally able to orient the seats to get them aligned where I wanted them. This is right about where I want it, but I need to move it back about an inch so the lower outer front seat corner slips under that diagonal frame tube. It was crowding the space down the middle for the tunnel with both seats sitting like this. In this pic the top of the head rest is almost at the bottom of that square tube right behind it.
To get the front corner of the seat where I wanted it I just had to nudge the seats back just enough so the top of the head rests were about even with the top of that square tube.
With the head rests moved up just that little bit, I was able to get the front seat corners to go under those diagonal tubes. That more than doubled the space available down the center for the tunnel.
I now have 4.5" between the seats in that position. The tunnel will be 3" wide, so I'll have 3/4" on each side to slip the seat belts between the tunnel and the seats.
These last two pics were real blurry. Like I said, I was pretty tired by this time so that's the best I could do. Also, the sun was already down by the time I finally saw how blurry these two pics were.
This pic is the height measurement at the front inner corner on the passenger seat. The bottom edge of the fiberglass seat is right at 4.5". The rounded top edge is somewhere around 5.5-6". It will be a little higher than that with the seat cover and the extra foam padding. The tunnel will be 6" tall and the base of the shifter will be fairly close to that corner of the seat. I'll fine tune the shifter placement after I have the seats mounted and the tunnel base built.
This last pic is about where the E-brake handles will sit. The bottom edge of the seat is about 6" right there and the top of the rolled edge s around 7.5-8" tall. The upward sloping curve at the middle of the seat right there is going to help shroud the E-brake handles quite a bit and make them less likely to snag on stuff.
So far I'm liking these seats right where I have them now. Once I can put some temporary supports under them to hold them in this position I'll be able to try them out and see if the seat back angle is acceptable or not. I'm hoping it's good as is since everything seems to be fitting together well with the seats where they are now. _________________ Homemade rail for street & off road: BJ front beam (bent), IRS rear (boxed/maybe bent), stock T1 DP 1600, 009, 34PICT-3 (soon to be dual 40HPMXs), 4-1 glass pack exh, T3 brakes (F disk, R drum & Dual MC), Bug trans (002, 5 rib going in soon).
Link to my rail (re)build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=629493 |
dustymojave Samba Member
Posted: Mon May 02, 2016 12:51 pm Post subject: Re: Budget rail rebuild and dual carbs project |
I see where you're going with this. My only comment is that I would install the floor sheet UNDER the frame rails. For one, then it could be a full one-piece floor with no little pieces to fill in around the edges. If you need to have multiple pieces, then the forward piece should be under the rear piece so the front edge wont snag.
My HiJumper got a 1-piece floor, from the front of cabin bottom cross member to the rear torsion housing. I left it open under the front. Then I had some trouble with damage to the brake lines and reservoir from rocks getting up in there. So I added another piece for that area from the beam to the front cross member with a 2" overlap at the back. Never had any more trouble after that. The 1/16" smooth 6061 T6 floor is still the original from the 1970s.
At the time, the thinnest aluminum diamond plate I could find was 1/8". But I wanted 1/16". If I were to build myself another buggy right now, it would get a floor of 1/16" diamond plate like you are using. Preferably 6061 alloy. I have my floor installed with 1/4" carriage bolts from below. The heads pull up into the round holes and I can work from above with a socket to install and remove the floor and the heads of the bolts don't snag on anything. _________________ Richard
SoCalBajas Member
Posted: Mon May 02, 2016 10:07 pm Post subject: Re: Budget rail rebuild and dual carbs project |
Honestly I looked at doing that, but the floor up front is pretty well locked in place by the frame for some reason. It looks like the PO built the frame around that piece of 1/8" diamond plate floor. I can't see any other way for them to have gotten it in there. I'd have to cut it up in order to remove it now. The PO also ran this rail pretty hard off road from the looks of the tubes on the bottom of the rail. I'd have to straighten or replace more than a few tubes in order to make it flat enough to put a sheet of plate under it and have it sit flat. For now I'm just going to keep this rail like it is and run it with the floors on top, until I get the new frame anyway. I'll be doing a lot of things differently with the new frame. Putting the diamond plate UNDER the frame being just one of the many needed improvements taken care of during the upgrade.
I put a few pieces of steel under the driver side seat base to support it so I could sit in it. The seat back angle is better, but not as far back as I'd like it to be. It's close enough though so I'm going to make the mounts to set the position where I have them now.
Today was another day of nice weather and warm temperatures so I went back to work. I decided to start on fabbing up the tunnel since I need the base part made so I can measure a few things from/on it. In order to decide on a permanent location for the shifter, I need the tunnel in place so I have somewhere to put it. For now I'm starting with the steel frame for the base which is made from 3/4" x 3/4" angle. I have the tunnel figured at 5' long, but I may have to shorten it to 4' if I run into any interference issues with the pedals. The sides and the top will be made of the same 16GA diamond plate I'm using for the floor.
The first step was to notch the twelve 6" long pieces of 3/4" angle so I could nest them into the 5' long pieces. That took quite a while to get done as I measured and cut each of them one at a time. I made sure the first one was perfect and then marked it and used it as a pattern for the rest of the pieces. It took me a couple of hours to get all the pieces cut and my arms felt like rubber after holding up that grinder for so long. I also cut twelve 1.5" long pieces to go in between both sides and make the tunnel base frame 6" wide overall. I already had the four long edge pieces cut to 5' lengths so those were already ready to go.
I set up the MIG and a work table in the shade and started to make sparks. I used magnets to hold the pieces together and used a square to make sure they were aligned properly at each joint. I worked until I had all six of the 6" long pieces welded to the first 5' long edge piece. The long edge piece warped a bit so I had to get it straightened back out with a little help from a hammer. After It was brought back into shape I placed the second 5' long edge piece into the notches in the 6" pieces. Once again I used the square to align the pieces, but this time I used long clamps instead of magnets to hold everything together. I verified the distances at the loose ends (12" from face to face) of the 6" pieces before tacking them in place. Once the entire length was tacked at all the corners, I started making 3/4" beads between the tacks. I only did one bead at a time on a joint and then I moved onto the next joint, and so on and so on until I had all the welds done. When all the welds were done the time spent making sure everything was aligned paid off. It was still perfectly straight after the second round of welding was finished. Lastly I fired up the angle grinder again, this time with a coarse flap disk on it, and proceeded to clean up all the welds and flux core spatter. Don't let the pics fool you, I'm not a professional welder by any means. I have gotten a lot of practice at grinding though as a result though.
Pics:
The first side is now done and I have one more to go just like it. Then I have to connect the halves together with all those little pieces. After I took the pics, I stuck this piece of the tunnel into the rail to see how it was going to fit. The roller on the gas pedal is sitting part way inside the last section of tunnel, so I may have to shorten it after all. I'll wait until I have the tunnel frame completed and try it again then to see if it will indeed be an issue or if I can figure out a work around for it. _________________ Homemade rail for street & off road: BJ front beam (bent), IRS rear (boxed/maybe bent), stock T1 DP 1600, 009, 34PICT-3 (soon to be dual 40HPMXs), 4-1 glass pack exh, T3 brakes (F disk, R drum & Dual MC), Bug trans (002, 5 rib going in soon).
Posted: Wed May 04, 2016 8:42 pm Post subject: Re: Budget rail rebuild and dual carbs project |
I didn't describe those 6" tunnel frame pieces very well so I got a pic of them today. This shows how I notched the 6" pieces to clear the 5' edge pieces where they nest in/on them. The notches are sized so the vertical dimension will end up at 6" after everything is all welded and cleaned up.
I was thinking about how little space I'll have down the middle of the tunnel frame so I decided to open it up a bit. The short 1.5" long pieces had one side chopped off with the cut off disk and they were reduced from 3/4" to 1/4" on the cut side. The other side was left alone and is still 3/4". I think it'll be easier to handle thinning the inner edge of those 6" long pieces if I wait to narrow them until after they're all welded to the long edge rails. I'm going to use a 1/2" ball nose end mill to put a radius on the inner corners of all the cuts.
Since all the pieces were already shaped, today went a little quicker than the last day. I built the second tunnel frame side identical to the first. It had the same bends in it at the halfway point, so I straightened it out before welding the second long edge piece on. When I checked it over after the last welds were done, it was warped again. I'm not sure what was different this time. I thought I did everything the same as the last one which turned out perfect at the end. It wasn't a big deal over all, it just needed some more love taps from the hammer to line it back up. After the second side was cleaned up with the flap disk it now looks just like the first side. I didn't take a pic of it since it's so hard to tell them apart now. If you need a pic, just look at my last post.
Tomorrow I'll start notching the inner edges of the 6" pieces on the mill. I'm going to make all the edges that point towards the inside of the tunnel 1/4" long. That will give me 5.5" x 2.5" of room all the way through. Without that modification there would only be 4.5" x 1.5" at most. That's a little tighter than I feel comfortable with having. I want to run all my wiring, brake line, clutch line, throttle cable tube and the shifter shaft through there. I'm also going to round off all the edges inside the tunnel with the flap disk and Dremel. That should keep the risk of sharp edges cutting anything passing through the tunnel to a minimum.
If there's any room left, I'd also like to try to plumb the heat ducting through the tunnel. If I'm careful I should be able to mount one of those compact semi truck cab heaters on top of the very front of the tunnel. They run on diesel instead of gasoline like the optional VW heaters so I'll also have to add a dedicated diesel tank for it up front. _________________ Homemade rail for street & off road: BJ front beam (bent), IRS rear (boxed/maybe bent), stock T1 DP 1600, 009, 34PICT-3 (soon to be dual 40HPMXs), 4-1 glass pack exh, T3 brakes (F disk, R drum & Dual MC), Bug trans (002, 5 rib going in soon).
Q13931152 Samba Member
Posted: Wed May 04, 2016 9:01 pm Post subject: Re: Budget rail rebuild and dual carbs project |
I like where you're going with your tunnel idea, but I wouldn't recommended running the heater output inside of it especially not if you're planning to run your wiring inside as well. Those heaters get VERY hot when running, and you could very easilly run the risk of melting wires in an enclosed space like that. I've seen first hand the damage they can do to objects placed near them, and its pretty impressive to say the least! |
Posted: Wed May 04, 2016 9:56 pm Post subject: Re: Budget rail rebuild and dual carbs project |
I'd only consider it if I have enough room to run an insulated tube in there. The wires and other lines running through would most likely get some sort of hear shielding as well. Maybe I should just install a sheet metal partition to divide part of the tunnel interior?
The main gas tank is behind the seats and the diesel tank would be up front behind the battery box. There wouldn't be any fuel lines in the tunnel except for the short (12" or less) diesel fuel line feeding the heater. The heater exhaust won't be run though the tunnel if that's what you're talking about. That will be run directly out the side of the frame and through the sheet metal skin. I'm also going to put on a little tail pipe tip that turns rearwards with a slight down angle so it doesn't fill up with mud, rain and crap from the road and the tires. _________________ Homemade rail for street & off road: BJ front beam (bent), IRS rear (boxed/maybe bent), stock T1 DP 1600, 009, 34PICT-3 (soon to be dual 40HPMXs), 4-1 glass pack exh, T3 brakes (F disk, R drum & Dual MC), Bug trans (002, 5 rib going in soon).
Posted: Wed May 04, 2016 10:12 pm Post subject: Re: Budget rail rebuild and dual carbs project |
Insulated ducting would be a smart idea if you have room to run it inside the tunnel, and is readily available along with a variety of air outlets and things of that nature.
http://sales.butlertechnik.com/eberspacher/eberspa...ccessories
Just one source, but its a start at least.whatever you use, you definitely want it to be able to withstand the heat. |
Posted: Fri May 06, 2016 9:30 pm Post subject: Re: Budget rail rebuild and dual carbs project |
Nothing new to report here lately since my back started acting up pretty bad over the past two days. The temps here have turned mild again (40's to 50's) along with the damp weather again. That weather combo has always given me problems since my second back surgery.
If it's going to be more of the same weather for tomorrow, I'll just bite the bullet and try lighting a fire in the shop stove so I can get back to work. I really need to finish milling the tunnel halves so I can weld it together.
EDIT: The weather forecast for tomorrow looks like high 60's to low 70's and 0% chance of precip. Yay.
The second HPMX carb, the snail gauge and the throttle cable kit all finally showed up in the mail today. With the cable kit here, now I can figure out where I want to route the throttle cable through the tunnel. Like mentioned above, I'll also need to be mindful of where I want to route the heat hoses in the future. That will just be a guessing game though until I can get one of those heater units in hand and the insulated duct hoses for it.
After the tunnel is sorted out, I'll move onto the rear engine cage next. I still need to add about 6" of clearance between it and the engine/exhaust before I can putt the muffler on. The dual carbs will be next up after that. _________________ Homemade rail for street & off road: BJ front beam (bent), IRS rear (boxed/maybe bent), stock T1 DP 1600, 009, 34PICT-3 (soon to be dual 40HPMXs), 4-1 glass pack exh, T3 brakes (F disk, R drum & Dual MC), Bug trans (002, 5 rib going in soon).
Posted: Sat May 07, 2016 8:10 pm Post subject: Re: Budget rail rebuild and dual carbs project |
I cut all the inner surfaces of the tunnel sides down to 1/4" on the Bridgeport mill today. I'm still not feeling so great today and I made a few stupid mistakes as a result. It wasn't too serious, just went a little deeper than I needed to on a couple of the ends (visible in pic). After I round over the freshly cut edges it'll be ready for welding. I'll MIG the sides together, with the short pieces in between them, tomorrow.
Posted: Sun May 08, 2016 9:42 pm Post subject: Re: Budget rail rebuild and dual carbs project |
My back is still hurting like a som-bich, but I'm pushing through the pain so I can make progress while the weather's cooperating.
Today I welded the tunnel halves together with the little 1.5" pieces in between. I welded all the little pieces to one side first. Then I clamped the second half to the other and welded it together one section at a time. That allowed me to tweak the halves as needed to keep the tunnel straight. It worked out well and it's all together and everything looks good so far.
Next I placed the tunnel in the rail between the seats and butted it all the way up against the rear torsion tube. The passenger foot rest was preventing the tunnel from being able to rest on the floor. I'll need to remove the foot rest before I can fit the tunnel properly. For now I just wedged a glove between the seat and shoved a paint can under the tunnel to hold it steady so I could get a look at where it was roughly going to be.
The foot rest is holding the tunnel up about 3" near the middle, and even more up front, so that's making a big difference in the height.
I took the old shifter mount box and cut it up so I just had the top and rear part of it left. After straightening the edges, I notched it at the bend so I could fit it around the frame and have it sit flat on top of the tunnel.
That allowed me to move it back and forth with the shifter sitting on top of the mount. I won't be able to figure out where I'll permanently attach the mount until I can get the tunnel sitting flat on the floor though. Most likely it will be welded in either one of these two positions.
Last thing I did for today was to hang the tunnel up and give it a quick coat of black paint. I still need to flip it over and get the areas I couldn't reach with it hanging like this. I'll get that done tomorrow as long as the weather stays nice.
Posted: Wed May 11, 2016 1:33 pm Post subject: Re: Budget rail rebuild and dual carbs project |
My wife posted the autographed Don Garlits book on Ebay for me. Here's the link in case anyone is interested. -> http://www.ebay.com/itm/301940455232?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649
It's still overcast outside but we're not expecting any rain today. The temps are up to the mid 50's so I'm heading outside to work on the rail some. I hope to get the tunnel fitted and the shifter location figured out today if possible. That should be do-able if I don't run into any unexpected snags along the way. _________________ Homemade rail for street & off road: BJ front beam (bent), IRS rear (boxed/maybe bent), stock T1 DP 1600, 009, 34PICT-3 (soon to be dual 40HPMXs), 4-1 glass pack exh, T3 brakes (F disk, R drum & Dual MC), Bug trans (002, 5 rib going in soon).
notime2d8 Samba Member
Joined: September 10, 2014 Posts: 27 Location: Birmingham, AL
Posted: Wed May 11, 2016 5:25 pm Post subject: Re: Budget rail rebuild and dual carbs project |
When you started this thread, I did not think that it was going to end up at 19+ pages. I thought your rail was ready at the start of the thread, obviously I was wrong. Also going to bug you with a PM. |
Posted: Wed May 11, 2016 8:34 pm Post subject: Re: Budget rail rebuild and dual carbs project |
When I got it, it was maybe OK for just putting around on dirt roads, but not much more than that IMHO due to the neglect and outright scary work done by the PO. I already had an idea of what I wanted out of a rail before I got this one, so it was destined to be tinkered on quite a bit. Making it street legal adds a lot of stuff to the basic package by itself. Then you have to remember that I want to make it a DD that I can drive year round, in Montana. So a completely enclosed cabin, heat and window defrost are other things I'll also have to add. This frame is tweaked pretty badly also, so a new frame is on the "to do eventually" list. Can't forget the performance upgrades either. Dual carbs are in hand and I'm going to be going through the second carb soon. There's also the 002 5 rib transaxle and Type 2 Bus CV's and axles I already have, but I still need 2x3 rear diagonal arms before I can install the bus trans and axles. If I had to guess, I'm probably about halfway there overall. lol
Ok, back to today's progress. Before I could do anything else, I needed to remove the bolts holding the passenger foot rest. Like almost every other bolt that was sticking out the bottom of the rail so far, they all needed their nuts cut off to get them loose. Wait, that sounded REALLY bad there... LOL.
Then I went under the rail and traced the outline of the frame on the new piece of floor so I would know where to drill so the screws would hit their marks. I got everything lined up well enough that every hole hit its mark, but the crappy self drilling screws I bought were having trouble in the thicker pieces of metal. I have over half of them in so far, so I just left it at that for right now. After I have everything fitted and located, I'll take it all back out for final paint and finishing. I'll go back and get the rest of the floor holes drilled and screwed down at that time. I sat the tunnel frame in place and centered it side to side. It has also been slid all the way back to the rear torsion housing.
After than little bit of surgery, the tunnel was finally able to sit flat on the floor. However, the roller for the gas pedal was halfway inside the tunnel and had no room to move forward without hitting the upper part of the tunnel frame. For now I just unbolted the roller to get it out of the way. I'll also be repositioning the pedal assembly so I'll move it a little away from the tunnel at that time.
I also had to remove some of the left over bug sheet metal around the middle of the rear torsion beam. A couple quick cuts with the angle grinder and they weren't an issue any more. I might need to stick with the smaller old round style of shift shaft coupler. I'll need to check them both out to see which ones will work inside the narrow tunnel. I'll go with which ever one works best.
Then I put the drivers seat back in place and slid a piece of steel under the front to temporarily give it a little extra support. I loosely bolted the shifter to the mounting plate and maneuvered it into place on top of the tunnel. Where I had previously guessed it would be is going to be way too far back for comfort. It's a couple of inches more forward with the tunnel sitting flat on the floor now. I ran it through the limits of the gear throws, including reverse. Here it is in 3rd (approximately).
This is where reverse should be.
A look at the shifter in the reverse position looking straight from the side.
And the shifter in the same position, just looking at it from the other side.
This is a peek under the hood showing where the tunnel is ending up at. I'll build the small front bulkhead somewhere between that blue bar and the front of the tunnel.
Last pic is showing the top of the tunnel in relation to both seats. I'm happy with how it's turning out so far.
Posted: Fri May 13, 2016 8:16 pm Post subject: Re: Budget rail rebuild and dual carbs project |
I was outside working for a few hours today, but it doesn't seem like I got a lot done. I cut the sides and top pieces for the tunnel out of the big sheet of diamond plate. The two sides are 6" x 5' and the top is 5&1/8" x 5'. I had to remove the raised diamonds from a 1" strip along one of the long sides of each of the side pieces. That is to allow the top piece to sit flat on it once the edges are bent over. The top will have 1" of each long side folded over so it will wrap around the frame and both side pieces. That should cap it off nicely and keep it looking neat once it's bolted in place. The narrow top edges of each side piece were also radiused to allow for the bend in the top piece. All this cutting and grinding is what took the most time today.
Next I started to attach the first side by lining it up on the frame and then clamping it in place with a couple vise grips. I marked the holes on the bottom 1/2" up from the lower edge and spaced them about 12"apart. I raised up the holes on each end slightly to avoid the thick welds in the corners. On the top edge I started 6" back from the first corner and then marked the rest of the holes at the regular 12" spacing after that. When I mark the holes for the top piece, they will be 1/2" from the top edge and lined up directly over the holes along the bottom edge. Doing it like this allows me to bolt the sides down independently and still have them stay put when I remove the top piece for any reason. I drilled the holes to 3/16 to clear the #10-24 countersunk screws. I used a countersink bit to open the tops of the holes so that all the screw heads are flush with the surface of the diamond plate. I installed a screw and nut in each hole as soon as it was finished before moving on to the next hole. That way everything stayed aligned as I drilled it.
I ran out of daylight right after the first side was finished so that's where I stopped at for today. There's supposed to be a couple more days of rain coming starting tomorrow unfortunately. However, the messy cutting part is already done so I can finish drilling the diamond plate inside the barn. I'm not sure yet how I'll put those two long bends in that top piece without a sheet metal brake. I may have to farm that job out to a local fab shop.
EDIT: BTW, If I wanted to temporarily run the 5 Rib transaxle with the stock IRS arms, what length axles would I need? The inner CV's would be Type 2's and the outers would be Type 1's with this setup. I was just planning on doing it this way until I can afford 2"x3" arms and outer stubs for the Type 2 CV's.
I'm also looking for recommendations on where to get trans mounts to put the 5 Rib in the rail. I don't want to have the 10* tilt mounts since I'm making this new tunnel taller to work with the higher shift shaft location of the bus trans. I want to be able to use either factory rubber or urethane front and rear trans mounts since this will be a DD when I'm done. The mounts I'm seeing everywhere for the Bus to Bug trans swaps are either the solid mounts, 10* mounts or both. _________________ Homemade rail for street & off road: BJ front beam (bent), IRS rear (boxed/maybe bent), stock T1 DP 1600, 009, 34PICT-3 (soon to be dual 40HPMXs), 4-1 glass pack exh, T3 brakes (F disk, R drum & Dual MC), Bug trans (002, 5 rib going in soon).
Posted: Mon May 16, 2016 1:33 pm Post subject: Re: Budget rail rebuild and dual carbs project |
I think I finally got all the answers I was looking for!
I just got off the phone with Gary who is the Off Road specialist at CIP1's Tech Support help desk (PH# 800-313-3811). He's done an almost identical bus trans swap on his Baja a while ago and had all these parts figured out already. His setup is pretty much the same as mine is going to be, so his experience is directly applicable to my situation. Bus trans into Bug frame horns with stock boxed IRS arms, Type 1 stubs and outer CVs and Type 2 CVs at the trans.
For the axles, he's been running the stock Bug axles without any issues for a while now. He just had to cut the axles at the snap ring groove with an thin cut off wheel, bevel the ends of the splines to a 45* angle and omit the spring washers. The axle is free floating as a result of not having the clips or washers, but there hasn't been any problems running it hard off road like this for a while now. Not having to buy new axles will save me $190 and definitely makes this trans swap a LOT more affordable now.
As far as the mounts go, we've figured out a solution that gives me most of what I wanted, which is far better than any of the other options I had found so far. This kit still uses the stock Bug rear trans mount support that ties both ends of the frame horns together. That way I can still use the stock rubber or urethane mounts at the bell housing. The rubber or urethane mounts bolt to the cad plated brackets in the kit, and those cad brackets bolt to the Bus trans bell housing. At the middle the kit uses a solid mount that welds to the frame horns. At the nose it is left loose, relying on the mid and rear mounts, as well as straps over the top if they're used. I do want to use the straps over the top of the trans, so I'll have to make a way to reattach the rear strap and will also need to make a new mid strap to fit the bus trans profile. The mount kit is $24.64 and two new stock rubber mounts are $5.09 each. So now the total trans swap parts cost (not including the trans) is looking like it's going to be just $34.82, plus whatever shipping is going to be. Color me happy!
Here's the link to the mount kit:
http://www2.cip1.com/ProductDetails.asp?ProductCode=C26-311-205
And these are the stock rubber rear mounts for the bell housing:
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-113-301-263
FWIW: Gary at CIP1 was a very informative, knowledgeable and helpful. If anyone else has any hard to answer questions about any off road related parts combinations I'd highly suggest calling and asking for him specifically. He wasn't afraid to offer suggestions that would keep me from spending money that I didn't need to, even though that meant I would spend less at the shop he worked at. _________________ Homemade rail for street & off road: BJ front beam (bent), IRS rear (boxed/maybe bent), stock T1 DP 1600, 009, 34PICT-3 (soon to be dual 40HPMXs), 4-1 glass pack exh, T3 brakes (F disk, R drum & Dual MC), Bug trans (002, 5 rib going in soon).
Posted: Tue May 17, 2016 10:58 pm Post subject: Re: Budget rail rebuild and dual carbs project |
I haven't been feeling well enough to get back out to work on the rail lately, but I have received some parts in the mail at least. The most useful ones being those little rubber cable gaitors to connect and seal off the throttle cable and tube. They're about 4" long with a 1/8" hole on one end and a 1/4" hole at the other. I should have no problem making them work to keep the cable lube in, and the dirt and water out, of the cable tube. I picked up 4 of them, so I'll have 2 extra for spares. I'm running a Hyd clutch so I don't need them for that. The heat system will be electrically controlled, so they won't be needed for that either.
I also got a couple of small dual Cree LED back up/driving lights from Ebay. I don't know if I want to rework the rear lights on this rail, rather I was thinking these will be good to use on the next frame.
Most of the stuff I bought for the Baofung UV-5RTP hand held radio has shown up as well. The only things I'm still waiting on are the radio itself and the mag mounted mobile antenna. I also thought about getting that UV-5R vehicle mount on Ebay for it as well, but it's just a little bit of bent metal with a nut welded to the back. I can make something myself that will serve the same purpose, and not cost over $17 like that one does.
I may not have been working on the rail much lately, but that doesn't mean I haven't been thinking about what I want to do with it. I've decided to seal off the small rear end of the tunnel in order to help keep the cabin separated from the outside air once the rest of it's enclosed. Doing that will allow me to use a trans shift snout to body seal. I'm referring to the bellows type rubber unit found on most Bugs, Bajas, T3s, etc. _________________ Homemade rail for street & off road: BJ front beam (bent), IRS rear (boxed/maybe bent), stock T1 DP 1600, 009, 34PICT-3 (soon to be dual 40HPMXs), 4-1 glass pack exh, T3 brakes (F disk, R drum & Dual MC), Bug trans (002, 5 rib going in soon).
Posted: Wed May 18, 2016 3:12 pm Post subject: Re: Budget rail rebuild and dual carbs project |
It's starting to rain, so I'm done working outside for now. I got a good bit of work done beforehand and am at a good stopping point right now, so it's not really holding me up much.
Today I started out by getting the second tunnel side installed. All the holes for this side were drilled and countersunk and the screws and nuts were installed. Then I took the grinder and trimmed back a 1" wide area along the back edge of both sides so the end cap would have a flat area to wrap around onto. I cut the rear end cap piece to shape and then stuck it in the vise to make the side bends. The bend was a couple inches wider than the vise jaws so I used a pair of wide jaw vise grips to help hold the part that was outside the vise jaws. I tapped the part over with a hammer to get the 90* bend on the first side and then flipped it around and did the bend on the other side. It took a little bit more hammer work to get the fit just right, but it turned out fine. The end cap was clamped in place with vise grips and then four holes were drilled and countersunk just like the sides.
Once I finish getting all the tunnel pieces fitted, I'll be welding the nuts to the inside of the frame. That way I'll only need a phillips screwdriver on the outside to assemble the tunnel when I'm done.
At this point I started getting the top piece ready to fit to the tunnel. I drew a center mark at the front and rear ends and wrapped the mark around the end from the top to the bottom. I wrapped a piece of tape around the middle of the narrow top ends of the frame and marked it along the center line as well. With these marks in place I was able to sit the top piece into position and still be able to see that the marks were aligned. I clamped the top piece in place at both ends with vise grips and then traced a line along the edge of the side pieces to mark the under side of the top piece. Then I brought the tunnel and top piece to a local fab shop in town and showed them where and how I needed the top piece bent. I left it with them and am just waiting for a call to let me know when they're done with it. I can't do much else until I get the top piece back, so I'm kinda at a standstill right now. That's mainly why I'm not sweating the rain coming down right now. _________________ Homemade rail for street & off road: BJ front beam (bent), IRS rear (boxed/maybe bent), stock T1 DP 1600, 009, 34PICT-3 (soon to be dual 40HPMXs), 4-1 glass pack exh, T3 brakes (F disk, R drum & Dual MC), Bug trans (002, 5 rib going in soon).
Posted: Sat May 21, 2016 3:22 pm Post subject: Re: Budget rail rebuild and dual carbs project |
The local fab shop messed up the top piece when it slipped in the press brake. They got it close enough that the piece still fits over the frame, but the sides are different lengths instead of being equal. I can still make it work so all is good. They didn't charge me for bending it since they screwed it up.
It's been raining for the past few days and is forecast to continue through the weekend. In the meantime I've been out in the shop working on a few guns until the weather lets up. I've also been rounding up a few more needed parts for the rail.
As far as the bus trans mounts I decided to just go with a complete kit that has both the mounts and the top straps together. As a result, I'm making it solid mounted instead of soft mounted. I'll work out how to make a set of soft mounts for the Bus trans when I get the new frame. I also got a weld in solid mid mount piece so the nose cone doesn't get stressed out. Appletree had the main kit for $5 less than Cip1 and my order ended up over $75 so I got the free shipping deal as well.
http://www.appletreeauto.com/BUS-TRANS-MOUNT-6539-10/
http://www.appletreeauto.com/BUS-TRANSMISSION-CENTER-MOUNT-17-2538-0/
I decided to stick with the early type shift rod coupler so I picked up an adjustable shift rod adjuster as well. The early type will leave me more room in the tunnel frame for clearance.
http://www.appletreeauto.com/SHIFT-ROD-ADJUSTER-EARLY-5528/ _________________ Homemade rail for street & off road: BJ front beam (bent), IRS rear (boxed/maybe bent), stock T1 DP 1600, 009, 34PICT-3 (soon to be dual 40HPMXs), 4-1 glass pack exh, T3 brakes (F disk, R drum & Dual MC), Bug trans (002, 5 rib going in soon).
Posted: Fri May 27, 2016 2:20 am Post subject: Re: Budget rail rebuild and dual carbs project |
This stuff showed up in the mail the other day, so I brought it out to the barn and cleared off some space to work on the trans for a little bit.
I was starting on the front end first, so I cut the triangularish front mount from the package. I unbolted the original Bus mount from the nose cone and set it aside. When I dropped the new mount over the studs on the nose cone, it was rocking around noticeably. When I took it off I saw that the old mount had worn down the raised pads on the nose cone unevenly. To fix that, I removed the nose cone from the trans and cleaned it up inside the piece. The cover gasket was glued down with some clear rubbery stuff and tore into pieces when the parts were separated. As I was cleaning off the gasket remnants, I noticed that the gasket surface on the cover looked like it had already been filed and/or sanded down previously to remove the indentation from the big bearing. The trans fluid that came out and the plastic ball on the end of the hockey stick both looked like new, which lent a bit more credibility to the story I got about this trans being rebuilt not too long ago. Since I had access to the hockey stick now, I went ahead and polished the sliding surfaces on both ends, as well as the other long pin and cast sliding part. All the pieces looked to be in good shape and didn't have any nicks or gouges on them anywhere. This was kind of surprising, especially for the big end of the hockey stick that usually seems to get grabbed by vise grips or pipe wrenches for some reason.
Next I took the nose cone over to the mill and bolted it down flat onto the table (too big for the mill vise). I used a carbide insert flycutter to cut down the raised pads. I only cut deep enough to get the majority of the pad surfaces level. There's still a few low spots left from wear, but not enough to prevent the new mount from being able to sit solidly when bolted down.
I removed the seal holder from the snout on the nose cone so I could replace the seal. The seal didn't look to bad, but the outer edge of the big end of the brass holder was dented pretty badly on one side. After a little gentle prying I was able to get the old seal out without doing any more damage to the brass holder part. I popped the seal holder back into the nose cone to hold it while I made the larger diameter end round again. In case any machinists are reading this, the narrow end of a standard R8 tooling collet has the correct OD to fit inside the brass seal holder to reshape it to fit the seal properly. It took just a few taps with a rubber mallet to bottom out the R8 collet holder into the brass seal holder. Then I was able to tap the outside edge of the brass back into shape while using the collet holder as a mandrel to smooth out a few stubborn kinks. The collet holder came out without much effort and the seal holder now looked almost like new. The seal still had enough resistance when being driven in to know that it won't be going anywhere unintentionally. I also reapplied the three seal retaining divots around the outer edge of the brass seal holder, like VW did at the factory, to lock the seal into the holder.
Before I bolted the nose cone back onto the trans, I greased up a few spots where the parts would be moving around. The snout area between the seal holder and inner bushing was filled with waterproof grease. I also applied some grease to the plastic bearing and the shaft the cast slider rides on. I only used a little grease inside the cover as the trans oil will be doing most of the lubricating there. To replace the gasket for the nose cone I used a thin layer of Ultra Grey RTV around the outer edge and around the bolt holes. I let it set up with the cover just finger tight for a while as per the directions before tightening it to the final torque.
The two original mount studs weren't going to work with the new mount, so I needed to address that next. The unthreaded center section of the original studs was right where I needed the nut to go to be able to hold the new mount. The hardware store didn't have any M10x1.50 studs, so I got a couple fully threaded bolts that were long enough to get the job done. I clamped the bolt heads in the vise and cut the threaded part off with the cut off disk on the angle grinder. The cut end was cleaned up on the grinding wheel and then I put a starting bevel on to make it easier to get the nuts started on them later. I used some Locktite on one end of the newly made studs and threaded them into the nose cone. The new mount was next, followed by a few thick washers and some lock nuts.
I had some other things I needed to do, so I stopped there for now. I almost forgot to mention the nose cone was repainted gunmetal grey after milling to protect the newly exposed metal, and make it look like the rest of the transaxle. All the new main mount pieces (front, middle and rear), as well as the nuts and washers, were painted gloss black. The top straps and the mounting hardware are still in the package for now, so they'll get painted gloss black before I use them. _________________ Homemade rail for street & off road: BJ front beam (bent), IRS rear (boxed/maybe bent), stock T1 DP 1600, 009, 34PICT-3 (soon to be dual 40HPMXs), 4-1 glass pack exh, T3 brakes (F disk, R drum & Dual MC), Bug trans (002, 5 rib going in soon).
Posted: Fri May 27, 2016 6:18 pm Post subject: Re: Budget rail rebuild and dual carbs project |
Here's a pic of that new seal and the brass seal holder after being reinstalled and straightened out. It's also a good pic showing the staking job that helps to hold the seal in place.
I spent a little while out in the barn working on the trans mounts again today. This time it was the mid mount's turn. The first thing I noticed was that all four of the studs the mid mount bolted to were going to be too short. After another trip to the hardware store (they still didn't have any metric studs there), I picked up four M8 bolts that were 70mm long. I did the same operation on these smaller bolts as I did to the larger ones on the nose cone. As a result the mid mount plate, washers and stop nuts all fit now with room to spare. The washers were painted gloss black, but I left the shiny new stop nuts alone for now. The tops of the new studs were painted gunmetal while I was touching up a few nicks in the paint on the case.
After the paint was dry enough to handle I bolted the mid mount in place.
The light rain falling outside turned into a downpour, so I headed inside for the day. _________________ Homemade rail for street & off road: BJ front beam (bent), IRS rear (boxed/maybe bent), stock T1 DP 1600, 009, 34PICT-3 (soon to be dual 40HPMXs), 4-1 glass pack exh, T3 brakes (F disk, R drum & Dual MC), Bug trans (002, 5 rib going in soon).
