vwhelmot Samba Member
Joined: May 04, 2006 Posts: 617 Location: united kingdom
Posted: Mon Jul 20, 2015 6:46 am Post subject: |
There was also a section which was thin so I cut that out too . I had to make a buck to form the panel in one piece.
Cleaned up the inside more.
Almost ready to start attaching the front on for good
Tacked
Kept a check on this
So much time welding this on and being extra careful with dressing the welds after
No filler
Posted: Tue Jul 21, 2015 5:03 am Post subject: |
After welding the tank support on I trimmed the lip so that it flowed straight
Cheeky pic through the glove box
Canadian VW Samba Member
Joined: August 24, 2007 Posts: 220 Location: Ontario Canada
Posted: Tue Jul 21, 2015 5:19 am Post subject: |
I can't even handle this level of detail. |
Posted: Tue Jul 21, 2015 5:21 am Post subject: |
Onto the other side and I knew this was going to be more of a challenge as mixing a new style quarter with an old front would be difficult to get to look right. There was numerous differences.
In the pic you can see I had to add a piece to the new front as it had been previously cut short.
Notice too the scorch mark, this is where I had to heat up the metal to get rid of the bulge pressing for the twin brake master cylinder feed pipes to pass between the tank and the quarter. This took quite a while to get right as the metal wasn't playing ball to start off with.
Like I thought , this side was proving to be a pain :D
See if you can spot the other problem
Posted: Wed Jul 22, 2015 2:33 am Post subject: |
Next
The speedo cable clip was wrong for my car so I modified it to the correct sixties spec
I did think about cutting it out and welding this genuine section in but I came up with another idea
I lined up the old section and sprayed some primer through it to get an outline
Cut two slots
I then made a form to replicate the bridge
Tacked the former onto the quarter
Posted: Thu Jul 23, 2015 3:37 am Post subject: |
Next I had to do something about the crappy factory pressing
Matched to the other side
Tacked on
Wing on to check
Seems to fit ok
Posted: Thu Jul 23, 2015 4:09 am Post subject: |
Problem I would have to sort later
Nearly done
The black line is where I made a cut
You can see the problem here
Sorted
Posted: Fri Jul 24, 2015 1:42 am Post subject: |
Tank support welded back on
Factory spot welds still there
Time to do something about the crappy factory bumper mounts
Next problem ;D
Posted: Fri Jul 24, 2015 5:14 am Post subject: |
Looking at this there seems to be a common issue, I could have easily welded it all together and hammered it into place but it would have looked crap so I spent a lot of time making it good
The only way was to make a pie cut and add a section in
I was so careful to get this right, the bonnet and wings were constantly on and off
Autocraft front valence fits nice
Obviously had to do the same on the other side
Other bumper mount
Posted: Fri Jul 24, 2015 5:20 am Post subject: |
Well folks, this is it for now. Like I said I just wanted to show the amount of work that's gone into my bug so far. I`ve been doing many many more hours work on all the other details which I will keep to myself for now. I`ve done more bodywork and there is still lots to do but you get the picture?! Its got to be ready for paint by spring next year and then its off for its new coat of sea blue by someone who knows what it takes to paint a show winner. :D Cheers for the compliments
Parting shot. Bye for now...
lovethatconvertible Samba Member
Joined: August 22, 2008 Posts: 1434 Location: Las Vegas N. V.
Posted: Fri Jul 24, 2015 8:44 am Post subject: |
Don't go _________________ 1960 Convertible |
DBK UK Samba Member
Posted: Sat Jul 25, 2015 12:47 am Post subject: |
good stuff homie _________________ DBKUK |
wcfvw69 Samba Purist
Posted: Sat Jul 25, 2015 12:41 pm Post subject: |
Fantastic work my friend. Thanks for taking the time to post up all the detailed pictures of your excellent attention to detail.
Don't be stingy to share the body work and paint photos either! _________________ Contact me at [email protected]
The Samba member since 2004.
F-22A Samba Member
Posted: Mon Jul 27, 2015 12:54 am Post subject: |
Really top work Rusty, keep at it!
I can tell you the guys stateside are well impressed with the quality of your work. |
Posted: Mon Jul 27, 2015 2:01 am Post subject: |
:lol:
Cheers , Us limeys can do some things right some of the time :wink: |
ConcreteAce Samba Member
Joined: May 19, 2005 Posts: 856 Location: Spring, Texas
Posted: Tue Nov 10, 2015 8:59 am Post subject: |
Thanks
I`ve been busy Tonnes of mock up and more metal work and built a body stand :D
Posted: Sat Dec 19, 2015 11:02 am Post subject: Re: Fubar64 The rebuild of an ex show car |
Not far off the body prep stage
WayneMcCarthy Samba Member
Joined: April 29, 2009 Posts: 121 Location: Fermoy Co Cork Ireland
Posted: Mon Dec 28, 2015 2:58 am Post subject: Re: Fubar64 The rebuild of an ex show car |
Looking Good ...... Quality ! _________________ Pog Mo Thoin |
Posted: Thu Jan 28, 2016 1:59 am Post subject: Re: Fubar64 The rebuild of an ex show car |
Been a busy boy. Body welding done, I reblasted the shell and re etched and epoxy primed it.
Blasted all the excess weld through primer off
Epoxy coat
