motorhead364 Samba Member
Joined: November 04, 2008 Posts: 715 Location: Amarillo Texas
Posted: Mon Oct 19, 2015 3:03 pm Post subject: |
_________________ 63 ghia coupe |
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3916 Location: In Molinya Orbit
steveoutlaw Samba Member
Joined: November 14, 2014 Posts: 211 Location: Woodbridge, VA
Posted: Tue Oct 20, 2015 5:46 am Post subject: |
That's a trip! I'm going to do what spot welds I can on the top (there is some rust damage on the top that won't work). On the sides I'm going to overlap for some additional support, and on the bottom I'm just going to butt the edges together and weld. I'm going to take my time on the bottom so I don't overheat it and warp it.
I'll continue to post pics as I make progress.
What is your plan? |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13952 Location: Southampton U.K.
Posted: Tue Oct 20, 2015 9:48 am Post subject: |
John - Absolutely. That was one of the deciding factors in including the entire 66 dash instead of only part of it. I saw that someone on here is making aftermarket trim pieces so once I get the paint done I'll get some of the trim. |
Posted: Sat Jun 25, 2016 7:23 am Post subject: Re: Outlaw's barn find |
It's been a while but I finally got to start work on the paint. I didn't want to use chemicals to remove the paint and I read somewhere on here about someone using a heat gun and a razor scraper. So, $22 at Harbor Freight and 6 hours of relatively easy work and I'm making quick work of it.
[/img] |
Posted: Sat Jun 25, 2016 7:30 am Post subject: Re: Outlaw's barn find |
Looks to be a bit of bondo work on there and I found some areas of rust under the bondo so it looks like I'll be sanding the rest of it down to the metal to see just how bad it is. |
c21darrel Samba Member
NOVA Airhead Samba Member
Joined: July 20, 2005 Posts: 5221 Location: Richmond, VA
Posted: Mon Jun 27, 2016 11:51 am Post subject: Re: Outlaw's barn find |
Looks like someone mudded the entire car! _________________ Ghia Owner Emeritus |
Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Mon Jun 27, 2016 9:45 pm Post subject: Re: Outlaw's barn find |
Mine had a thick layer of spray filler all over it even where there was clean and straight metal underneath (as well as plenty of body filler hiding poor repairs in some areas). I think this is done by shoddy spray painters because it is less labour to do this than it is to block sand the whole car after priming like should be done. You may find that the brown is the original paint underneath the filler. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Posted: Tue Jun 28, 2016 7:19 am Post subject: Re: Outlaw's barn find |
c21darrel wrote: |
Quote: |
Looks like someone mudded the entire car! |
it does.
Normally i would think that is shoddy work (and it may be in this case). I noticed recently on most of the car shows on TV (foose...) and they all seem to put down a layer of filler over the entire car. |
From what I have seen it appears to be pretty common now for shops to mud the entire car but usually to smooth out small dings, etc. - i.e. to slick the body. This is Ok if after the car is mudded what is left is just where the small dings were but yours does not seem to fit that type of work. _________________ Ghia Owner Emeritus |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Tue Jun 28, 2016 8:33 am Post subject: Re: Outlaw's barn find |
Poor quality body shops seem to like using lots of 'bodyman in a can' as no one apparently knows how to bodywork sheet metal these days...
... and Time is Money.
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
Posted: Wed Jun 29, 2016 4:49 am Post subject: Re: Outlaw's barn find |
The entire car was mudded. It looked flawless before I started getting into it. I wanted to make sure I repaired what metal I could and determine if there were any rusty areas under the current mud.........and there were.
The brown looks to be primer but I'll know a lot more once I start sanding it. |
Posted: Wed Jun 29, 2016 6:23 am Post subject: Re: Outlaw's barn find |
It does not appear to be a thin layer either. A good body shop gets the metal to the point where it should not need more than a credit card thickness of filler. _________________ Ghia Owner Emeritus |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Wed Jun 29, 2016 5:47 pm Post subject: Re: Outlaw's barn find |
NOVA Airhead wrote: |
It does not appear to be a thin layer either. A good body shop gets the metal to the point where it should not need more than a credit card thickness of filler. |
What if they stood the credit card on edge? |
Posted: Thu Jun 30, 2016 5:55 am Post subject: Re: Outlaw's barn find |
iowegian wrote: |
Oh I am sure that would be fine as long as they feathered it into the bodywork! _________________ Ghia Owner Emeritus |
Posted: Thu Jul 07, 2016 6:20 am Post subject: Re: Outlaw's barn find |
Well, I'm taking it down to bare metal (or close to it) and am going to fix all of the damage instead of covering it up with filler. Body comes off the chassis this weekend.......Let the fun begin!! |
Posted: Sat Jul 09, 2016 1:01 pm Post subject: Re: Outlaw's barn find |
Ok, dolly is built! Now I just need to find some muscle to transfer it on.
