OG Velvet Samba Family Man
Joined: February 24, 2003 Posts: 2168 Location: Portland, OR
Posted: Wed Dec 09, 2015 8:14 pm Post subject: Re: Another dwell question |
So it's been a couple days. Been raining like hell in Portland.
I went out and put the alternator belt back on. Tightened a bit. Started it up and took it out to test Colin's theory. It ran perfectly. No studder or bucking. I got on 2nd and 3rd hard. No problem. Let it warm up for about 20 minutes after that. Took it out again. Ran perfect. I'm feeling pretty good at this point.
An hour and a half later I jump in it to run an errand.
Same BS. Starts great. Then the idle starts fluctuating. Then the idle drops and it dies. But it will start right back up. I haven't taken it back out yet. (I had to get somewhere). I plan on doing that when I get home.
Bummed _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
Posted: Wed Dec 09, 2015 9:23 pm Post subject: Re: Another dwell question |
So I got home and took the bus out again. I took off cold with no warm up. I ran all over varying speeds. I drove around for about 25 minutes.
It ran perfectly.
I'm going to drive it to work tomorrow. I guess I'll see what happens. _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Wed Dec 09, 2015 9:47 pm Post subject: Re: Another dwell question |
Be sure to have your raincoat, AAA, and bus pass.
Best of luck and good fortune.
Aloha
tp |
Posted: Wed Dec 09, 2015 9:56 pm Post subject: Re: Another dwell question |
As always, I appreciate the help from everyone. I love this place _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
Posted: Wed Dec 09, 2015 11:00 pm Post subject: Re: Another dwell question |
If you haven't done it yet take the white wire that runs from the ECU to the TSII sensor and ground it out to the block once the engine has run a few minutes to warm up. Now take it for a spin and tell us what it runs like. |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3551 Location: San Diego (Encinitas)
Posted: Wed Dec 09, 2015 11:12 pm Post subject: Re: Another dwell question |
Opinions:
- the old distributor play, while not great, is typical, and shouldn't be causing your problem.
- the new distributor advance is bupkis - return that unit to where it came from, and request one that works.
- the points coloration is fairly normal - don't think that's the issue.
- the voltage at coil terminal 15 should be rock solid. If it's not, fix that first. If removing the alternator belt makes the voltage steady, then the alternator / regulator /interconnect harness needs attention. Do a sanity check and try a different voltmeter, to make sure you're not chasing your tail.
- sounds like a fuel delivery problem to me. Here's where a LM-2 fuel ratio meter would give you a quick answer, one way or the other. Without that, I'd do the following:
1) measure the fuel pressure at the test port and see if it's correct, and varies properly with throttle opening.
2) get a can of spray contact cleaner. Unplug every FI connector (including grounds, double relay, and computer), and give the contacts a good shot of cleaner. Reassemble. Look for marginal or broken wires and bent, damaged, or pushed out pins.
3) check the resistance of Temp Sensor #2, and make sure it's right.
4) inspect the "S" boot for cracks or damage. An air leak here will really mess up the engine performance. Actually, any intake manifold leak will, so check all the widgets connected to the "S" boot.
4a) inspect the 4 intake manifold coupling sleeves for integrity.
An ignition problem typically presents as a miss, or other quick engine speed variation. Fuel issues typically present as a RPM or power fade. Leanness will cause intake backfire and bucking.
For what it's worth... _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
1975 Kombi Samba Member
Joined: August 12, 2007 Posts: 2452 Location: Acton, Ontario, Canada
Posted: Thu Dec 10, 2015 9:30 am Post subject: Re: Another dwell question |
The old distributor is missing a fibre washer on the bottom I think. They usually breaks and fall out and add vertical play to the shaft. It bounces Dwell around a bit with vertical play. _________________ Brett
“He’s decieving you boy! Reach into his pocket and take what he’s got.” Mr. Crabbs.
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
Licensed pilot (single engine land VFR)
Rust In Pieces: 72 Bug, 73 Bug, 81 Rabbit LS D 2D, 83 Rabbit D 2D, 84 Jetta TD GL, 85 Jetta D, 68 Z28 RS 302, 91 Passat 16v |
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 3898 Location: Seattle, WA
Posted: Thu Dec 10, 2015 1:19 pm Post subject: Re: Another dwell question |
1975 Kombi wrote: |
The old distributor is missing a fibre washer on the bottom I think. They usually breaks and fall out and add vertical play to the shaft. It bounces Dwell around a bit with vertical play. |
It's not clear how a missing washer could do those things. The distributor shaft is under a fair amount of pressure from the anti-chatter spring. When the washer goes, the shaft will rise the thickness of the
washer, and stay there. _________________ '67 bug: seized by the authorities
Posted: Thu Dec 10, 2015 2:39 pm Post subject: Re: Another dwell question |
F?ck.
Drove perfect to work. (About 4 miles)
Just jumped in to run to a meeting. Bucking all over the place. Totally undrivable.
Hopefully I can limp it home again in a couple hours. _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
Posted: Thu Dec 10, 2015 2:45 pm Post subject: Re: Another dwell question |
The bucking is not just under load anymore. It's sputtering at idle and when I rev it up. _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
Posted: Thu Dec 10, 2015 2:49 pm Post subject: Re: Another dwell question |
kreemoweet wrote: |
1975 Kombi wrote: |
washer, and stay there. |
It will only fluctuate the dwell as stated. Just something to fix later. _________________ Brett
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
Posted: Sat Dec 12, 2015 12:24 pm Post subject: Re: Another dwell question |
telford dorr wrote: |
Opinions:
For what it's worth... |
Thanks for all of the help here. I will be checking through these today even in monsoon Portland.
Another clue.
This problem is either present or it's not.
If it decides to run well, it runs well, with no sign of the issue. It does not seem to degrade into the problem.
If it decides not to run well, it does so from start up and does not fix itself.
I drove it to work on Thursday. It drove great. 4 mile commute, no freeway.
I get it to run an errand about 4 hours later. Bucks and sputters all over the place. I leave it on the street near work and it spends the night there. I get back to it yesterday morning and it drives like shit the half mile back to work.
I drive it home from work last night. Zero issue. _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
Posted: Sat Dec 12, 2015 12:27 pm Post subject: Re: Another dwell question |
Is the issue humidity or temp or temp/dew point related. _________________ Brett
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
Posted: Sat Dec 12, 2015 12:37 pm Post subject: Re: Another dwell question |
I'm not yet sure if this is correct...
But let's say what if, the issue only was happening when it's raining balls outside? (been a lot of that lately) What could that mean? _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
Posted: Sat Dec 12, 2015 12:45 pm Post subject: Re: Another dwell question |
My neighbours Harley had something like this and anytime there was a close temp/dew point it would coat his bike in little dew drops and run bad. So I told him to start it in the dark on different nights and sure enough he had a small crack in his coil on the bottom by the frame and in the dark on some nights he noticed a blue flame/spark arc to the frame. He replaced the coil and Bob's your uncle. Fought with it for the whole summer.
So turn everything off and in the dark and watch for anything arcing. Just another thing to check. You might have a wire somewhere that the rubber coating is cracked and arcing and will only arc when the humidity is high. _________________ Brett
75 Westy auto
03 Jetta TDI
71 SB
74 Westy
Posted: Sat Dec 12, 2015 12:51 pm Post subject: Re: Another dwell question |
A weak ignition system may be affected by humidity or rain.
There are many places the ignition system can be weak, but the high tension wires and their contact points are the first suspects.
As just posted, check it in the dark. Very dark.
You may see gremlins dancing around their playground.
Aloha
tp |
Posted: Sat Dec 12, 2015 1:35 pm Post subject: Re: Another dwell question |
Opinions:
Could you define rock solid? The brand new coil is fluctuating between 13.68 and 13.79 at terminal 15. _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
Posted: Sat Dec 12, 2015 1:45 pm Post subject: Re: Another dwell question |
If the ignition system is wet and compromised it can be dried with LPS-1 spray.
"LPS 1® Greaseless Lubricant is specially formulated to penetrate minute crevices, displace moisture, and leave behind a thin, dry lubricating film. It is the top choice for drying out critical electrical/electronic components and lubricating precision instruments."
Displace moisture are the key words. Buy a spray can or bottle and next time it starts bucking spray everything from the coil to the plugs and in between including the inside of the distributor cap, but not on the points. Also check the inside of the distributor cap for carbon dust buildup.
Here's a thread that gets a bit off track, but related to moisture and humidity.
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...mp;start=0
Aloha
tp |
Tcash Samba Member
Posted: Sat Dec 12, 2015 2:47 pm Post subject: Re: Another dwell question |
Tcash wrote: |
Since electricity follows the path of least resistance. You can use a test light to find High Tension Leaks on a running engine.
Hook the alligator clip to the Battery Negative Terminal (this is the best ground) and run the probe over the plastic pieces of the coil and distributor cap. Then the plug wires.
No test light. You can use a screw driver with a plastic handle. Wrap a piece of wire around the blade (metal part) connect the other end to the Battery Neg. Terminal. While holding the screw driver by the plastic handle (if you don't you will soon know what it feels like to have shock therapy). Perform the test as stated above.
High Tension Leaks are hard to find, because they generally show up under engine load. Which means you are in the drivers seat going down the road. Sometimes you can get lucky. When you open the engine cover at night you will see arcing from the coil, cap or wires to ground.
Hope it helps
Tcash |
Posted: Sat Dec 12, 2015 7:52 pm Post subject: Re: Another dwell question |
I will look for fireworks tonight. But of course now it's running great.
I did find a spot on the #1 FI wire that had worn through. Unclear if it was enough to arc out. I taped it up pretty good. Couldn't find any other obvious breaks.
Thanks again for sticking with me here. _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
