D/A/N Samba Member
Posted: Wed Jan 27, 2016 10:11 am Post subject: Re: New (to me) 1965 1500 Variant S(!) |
sjbartnik wrote: |
They city has several red light cameras (and some dummy cameras) which are all permanently installed. |
Not to mention the "Bus Lane Only" enforcement cameras. Got caught by one of them once in Manhattan. How'd you get that fancy hi-res photo? All I got was a flimsy and faded print on paper. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5986 Location: Brooklyn
Posted: Wed Jan 27, 2016 11:48 am Post subject: Re: New (to me) 1965 1500 Variant S(!) |
D/A/N wrote: |
sjbartnik wrote: |
I got the paper too which had info on how to view the photos online. They do take a very high-res digital photo, it was ~5800 pixels wide! I guess they need that much resolution to be able to zoom in and get the license plate. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Sun Mar 20, 2016 11:08 am Post subject: Re: New (to me) 1965 1500 Variant S(!) |
Hi all,
So while my generator is out and being rebuilt, I decided to take the time and rehab the generator pulley + shims + shim cap so it'll all look nice when I get the generator back. Probably most people wouldn't care especially since it's hidden under a cover most of the time but I looked at as a chance to practice some metal prep and painting skills which I don't really have much experience with. I also decided to do the same to the bracket that holds the emergency flasher switch to the dash. I received that from ataraxia long ago and just went ahead and installed it with the idea that I could always easily remove it later and clean it up. This seemed like the perfect opportunity.
Here's what I started with:
Nothing too bad, just everything sort of crusty.
Almost done with the pulley parts but here's how the bracket came out. Not perfect but pretty darn good in Rust-Oleum semi-gloss rattle-can black:
Should have the generator back some time later this week.
Installed:
2000 Kawasaki W650
ataraxia Samba Member
Joined: March 19, 2010 Posts: 4504 Location: Illinois
Posted: Sun Mar 20, 2016 5:40 pm Post subject: Re: New (to me) 1965 1500 Variant S(!) |
Turned out really nice.
Funny story: I totally forgot that I sold that bracket to you - three weeks ago, when I was collecting all of my stuff for a trip to drop off stuff to be powder coated, I couldn't find the bracket and spent the better part of 20 minutes looking for it. Then right as I was convincing myself that I'd completely lost it, I remembered where it went. |
Posted: Sun Mar 20, 2016 6:19 pm Post subject: Re: New (to me) 1965 1500 Variant S(!) |
ataraxia wrote: |
D'OH! Well I hope you're happy to know it's out there in the world serving its proper purpose. _________________ 1965 Volkswagen 1500 Variant S
Posted: Sun Mar 20, 2016 6:39 pm Post subject: Re: New (to me) 1965 1500 Variant S(!) |
Yep...better with you in the car than with me in a cabinet! |
Posted: Sat Mar 26, 2016 12:18 pm Post subject: Re: New (to me) 1965 1500 Variant S(!) |
The brake light switch saga continues! The first FTE switch I put in died within a month. Today the second one (also FTE) died - intermittent brake light activation, high pressure required, etc. Same symptoms.
I replaced it with an NOS Ate switch; we'll see how long that one lasts.
The second FTE switch lasted longer than the first time-wise but that's a little misleading as the car has been sitting since the end of January due to a bum generator. I think I put the 2nd FTE switch in at the end of October but I definitely did not put as many miles on in that time as I did on the first switch. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22697 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sat Mar 26, 2016 2:50 pm Post subject: Re: New (to me) 1965 1500 Variant S(!) |
sjbartnik wrote: |
I replaced it with a NOS Ate switch; we'll see how long that one lasts.
The second FTE switch lasted longer than the first time-wise but that's a little misleading as the car has been sitting since the end of January due to a bum generator. I think I put the 2nd FTE switch in at the end of October but I definitely did not put as many miles on in that time as I did on the first switch. |
Ain't it just amazing?
The original switch lasts 50 years, and you're lucky if any replacement lasts 50 days. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Sat Mar 26, 2016 3:09 pm Post subject: Re: New (to me) 1965 1500 Variant S(!) |
Tram wrote: |
The original switch lasts 50 years, and you're lucky if any replacement lasts 50 days. |
I should have specified that this is with DOT5. No one seems to know the mechanism for how/why DOT5 kills switches but it seems that it does. _________________ 1965 Volkswagen 1500 Variant S
Posted: Sun Apr 10, 2016 10:49 am Post subject: Re: New (to me) 1965 1500 Variant S(!) |
Welp...went to adjust brakes today, gave the left front wheel a little check for play and found a clunk that shouldn't be there.
Looked into it and it appears that my left outer tie rod end is shot:
Clearly a new tie rod end and an alignment are in my future. Right side is fine and on the left side it's only the outer.
Anything special about the left side outer? Anybody have any issues with any particular brands of replacement parts out there now for this? _________________ 1965 Volkswagen 1500 Variant S
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22358 Location: Kimball, Mi
Posted: Sun Apr 10, 2016 11:21 am Post subject: Re: New (to me) 1965 1500 Variant S(!) |
sjbartnik wrote: |
Anything special about the left side outer? Anybody have any issues with any particular brands of replacement parts out there now for this? |
Knowing Keith, it should be a standard left outer tie rod, and not the left inner like sometimes happens when someone inexperienced replaces them.
I've had good luck with the Meyle brand tie rod ends, but I'll wait for others to chime in. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Apr 10, 2016 12:17 pm Post subject: Re: New (to me) 1965 1500 Variant S(!) |
Never had any issues with Meyle front end parts.
If you make the overall tie rod assembly the exact same length as it is now you can just check tow with a tape measure and roll. Alignment really isn't a "periodic maintenance" thing, it's only really needed to compensate for worn and damaged parts. Since you're correcting a worn part, keeping the alignment exactly as it is while correcting the wear is where you want to be.
Hint: Pull the entire tie rod assembly and note the orientation of the ends, then use one of these to gauge the exact length of the original and assemble to fit:
Bryan67 wrote: |
Posted: Sun Apr 10, 2016 12:35 pm Post subject: Re: New (to me) 1965 1500 Variant S(!) |
I don't have one of those but I would imagine I could get pretty close with a tape measure? _________________ 1965 Volkswagen 1500 Variant S
Erik G Samba Member
Joined: October 16, 2002 Posts: 13247 Location: Tejas!
Posted: Sun Apr 10, 2016 12:56 pm Post subject: Re: New (to me) 1965 1500 Variant S(!) |
Yes. I did
I bought a whole NOS assembly either here or eBay for like $90. Popped out the old, measured end to end, popped in the new. Of course this takes removal of the gas tank, draining the gas into your armpit, etc. but I was glad I did, I changed the fuel line underneith and added some considerable length to it to make jobs easier later _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Sun Apr 10, 2016 1:21 pm Post subject: Re: New (to me) 1965 1500 Variant S(!) |
sjbartnik wrote: |
I don't have one of those but I would imagine I could get pretty close with a tape measure? |
You could, but why do "pretty close" when you can do "exact"? Those clamps are under $20 new. How much is an alignment? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Sun Apr 10, 2016 1:26 pm Post subject: Re: New (to me) 1965 1500 Variant S(!) |
Erik G wrote: |
Yes. I did
I bought a whole NOS assembly either here or eBay for like $90. Popped out the old, measured end to end, popped in the new. Of course this takes removal of the gas tank, draining the gas into your armpit, etc. but I was glad I did, I changed the fuel line underneith and added some considerable length to it to make jobs easier later |
Eh?
Even if you do remove the tank, on an early car it's easy without draining it... plug or cap the breather, clamp the fuel feed soft line, and out she comes... no draining needed.
Up on stands with one of those tie rod "popping" tools (not the fork) is easy without removing the tank, though. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Sun Apr 10, 2016 1:29 pm Post subject: Re: New (to me) 1965 1500 Variant S(!) |
Tram wrote: |
sjbartnik wrote: |
You could, but why do "pretty close" when you can do "exact"? Those clamps are under $20 new. How much is an alignment? |
Well there is a Harbor Freight just down the street _________________ 1965 Volkswagen 1500 Variant S
Posted: Sun Apr 10, 2016 1:54 pm Post subject: Re: New (to me) 1965 1500 Variant S(!) |
Tram wrote: |
Up on stands with one of those tie rod "popping" tools (not the fork) is easy without removing the tank, though. |
How do you get the neck through the opening in the divider panel without pouring gas all over the spare tire bowl? |
Posted: Sun Apr 10, 2016 2:05 pm Post subject: Re: New (to me) 1965 1500 Variant S(!) |
ataraxia wrote: |
Tram wrote: |
IIRC the cap with a good seal comes through. A low tank level is also helpful.
When I put the whole front end under Meyer's Variant years ago I pulled the whole tank, fuel and all. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Erik G Samba Member
Posted: Sun Apr 10, 2016 3:33 pm Post subject: Re: New (to me) 1965 1500 Variant S(!) |
If you have a 2inch fuel line you can't exactly just pinch it and damn old man I thought your back was bad? That shite gets really heavy really quick
you must be thinking of your younger years with a good back and good fuel line and good seals. That shit is long gone - drain the damn tank and get that gas in your armpit. It's good for you ... LOL _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
