jdub1974 Samba Member
Joined: January 16, 2014 Posts: 5 Location: North Austin, TX
Posted: Thu Apr 16, 2015 2:50 pm Post subject: MK1 changed strut cartridges, now rides high, looks ugly |
So I changed the front strut cartridges on my 84 MK1 Rabbit 4 door and now the front looks like it rides high.
Thought I did it by the book but is it possible I did something wrong? Is there an inexpensive way to level out the ride height of my MK1?
I also replaced rear struts already so don't want to by a second set of new struts if I can avoid it.
Thanks,
J in Austin |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Thu Apr 16, 2015 8:46 pm Post subject: |
Depending upon what struts you put in, they could add a bit of height. Drive it and see if it settles some. |
Posted: Sat Apr 18, 2015 1:03 pm Post subject: ride height settle |
That is what I thought....I actually did the install about 4 months ago and figured it would maybe settle, but no luck.
Could I have got the wrong struts? Could I have re-installed the pieces wrong or something? |
ps2375 Samba Member
Posted: Sat Apr 18, 2015 4:15 pm Post subject: |
Did you do just the struts? Or did you also do the upper strut mounts. What struts did you install, a high pressure gas charged one or not? |
Ian Samba Moderator
Posted: Sat Apr 18, 2015 10:18 pm Post subject: |
If you put MK2 suspension in a MK1 it raises it up. Maybe you got the wrong front cartridges? _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012
**ACHTUNG DO NOT USE AA BRAND PRODUCTS OR BUY ANYTHING FROM PACIFIC PARTS INTERNATIONAL IN CALIFORNIA** |
Posted: Thu Apr 30, 2015 7:15 pm Post subject: cartridges |
I got them from Rock Auto so it's quite possible they are the wrong ones....there is some 'nose pressure' to the cartridges but I wouldn't have thought it was enough to change ride height.
No I have not changed the top mounts, but I do have new ones that I was going to install....maybe that is what it needs. |
crsmp5 Samba Member
Juanito84 Samba Member
Joined: March 17, 2012 Posts: 2436 Location: Colorado Mountains
Posted: Mon Feb 08, 2016 3:32 pm Post subject: Re: MK1 changed strut cartridges, now rides high, looks ugly |
Strut cartridges raising the suspension?! I've never heard of such a thing. I did change all the strut cartridges and springs on my MK2 and it made the front a little higher. But I think that's because I got the "heavy duty"springs from Parts Place Inc. _________________ If a water cooled engine cools its water with air, isn't it just an overcomplicated air cooled engine? |
sgnimj96 Samba Member
Joined: May 14, 2015 Posts: 49 Location: Melbourne, FL
Posted: Sat Feb 13, 2016 9:15 pm Post subject: Re: MK1 changed strut cartridges, now rides high, looks ugly |
maybe new parts in the rear suspension will even it out. IMO a little more lift is better, less chance of hitting things or getting stuck;
To me, it keeps resale value up. When I see a lowered car i just think something is wrong with it. |
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Mon Feb 15, 2016 9:27 am Post subject: Re: MK1 changed strut cartridges, now rides high, looks ugly |
There were differences in spring perch height & spring lengths depending on year & where the car was built. Most of the aftermarket manufacturers don't recognize this or just don't care anymore. It sounds like your car had the taller springs/lower perch & the replacement struts have the higher perch. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Mon Feb 15, 2016 9:31 am Post subject: Re: MK1 changed strut cartridges, now rides high, looks ugly |
Never mind, I saw that you only replaced the inserts. Some "high pressure gas" shocks & struts effectively have their own spring rate, bilsteins will have a tendency to raise a car 1"-1.5". _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
cub Samba Member
Posted: Thu Mar 10, 2016 10:53 pm Post subject: Re: MK1 changed strut cartridges, now rides high, looks ugly |
Shock absorbers don't determine ride height though. If that were the case and these were too tall there would be issues noticed before they got on the car. _________________ I love old cars |
