cdnltded Samba Member
Joined: March 13, 2015 Posts: 381 Location: Pincher Creek, Alberta
Posted: Wed May 04, 2016 6:32 am Post subject: Re: My project Doom Buggy |
Well things a progressing nicely i think on my buggy. so i moved to the front end, got the drums and shoes measured. all good they both will pass the safety.
tires
well i wanted to go with skiny in the front and wider in the rear.
this is what i had for the front tires
bot withthem weather checked and leaking everywhere i needed something else. this is what i found, 7.75 -15 bias
and this is what they look like on the car
Posted: Wed May 04, 2016 6:34 am Post subject: Re: My project Doom Buggy |
Also found a rear brake line that just need to be shortened
i found this line on my last donor car. now i have to practice my bubble flares. |
Posted: Fri May 06, 2016 6:33 am Post subject: Re: My project Doom Buggy |
Got my rear brake line shortened and installed
and a new master cylinder
Posted: Wed May 11, 2016 5:34 pm Post subject: Re: My project Doom Buggy |
well the temps dropped here so i thought before i turned the heat up i would try to get rid of that gross black crap on the tunnel. it was perfect temp i think just flaked right off
Posted: Sun May 15, 2016 10:14 pm Post subject: Re: My project Doom Buggy |
does anyone know the easiest way to hook up a chevy steering column to a 64 steering box? |
Posted: Mon May 16, 2016 6:35 am Post subject: Re: My project Doom Buggy |
Well i think i have decided on my wheel and tire combo
245 60 14 in the rear and 195 75 14 in the front on 14" appliance wheels
Posted: Mon May 16, 2016 6:36 am Post subject: Re: My project Doom Buggy |
Its always a great feeling to start adding new parts to the project. small parts but still new parts
before
after
slalombuggy Samba Member
Posted: Mon May 16, 2016 11:45 am Post subject: Re: My project Doom Buggy |
Make sure that those tire sizes are available new before committing to them. Most tire companies have all but deleted 14" tires from their catalogues. The last bias ply tires were made in the early 80s and will be WAY beyond their best before date. Tires that old are for show only. Delaminating tires play havoc with fiberglass not to mention they make vehicle control a bit of a challenge.
brad |
Posted: Mon May 16, 2016 12:42 pm Post subject: Re: My project Doom Buggy |
slalombuggy wrote: |
brad |
the front tires will be new should be in tomorrow. the rears are just some decent used one we had at work. they are radials. next year i will look for some good ones if i like the look and feel
these are really to pass the inspection when i get it done |
Posted: Wed May 18, 2016 2:36 pm Post subject: Re: My project Doom Buggy |
ok here is some shot of the new wheel tire combo
and the body back on
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Wed May 18, 2016 5:54 pm Post subject: Re: My project Doom Buggy |
The seam on those boots look to be pointed straight up. They should be rotated or they will leak. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Wed May 18, 2016 9:51 pm Post subject: Re: My project Doom Buggy |
Q-Dog wrote: |
The seam on those boots look to be pointed straight up. They should be rotated or they will leak. |
oh i would think straight up would be better. i have seen lots straight up.
i will have to check around and i thought the directions said straight up |
joescoolcustoms Samba Member
Posted: Thu May 19, 2016 8:03 am Post subject: Re: My project Doom Buggy |
The seam is rigid and does not flex very well. So, when the wheel travels to the up position, the boot kinks, gaps and all kinds of crazy stuff.
install the seam at 2 or 10 O"Clock. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Thu May 19, 2016 9:33 am Post subject: Re: My project Doom Buggy |
joescoolcustoms wrote: |
install the seam at 2 or 10 O"Clock. |
thanks Joe |
Posted: Tue May 24, 2016 11:00 pm Post subject: Re: My project Doom Buggy |
well i finally got my steering figured out
it is hard to connect a front wheel drive gm steering column to a vw
ended up using an older gm center section for the steering shaft, cuting and fitting and cutting and drilling but all done
i will pot pics tomorrow |
Posted: Wed May 25, 2016 11:28 am Post subject: Re: My project Doom Buggy |
here is the pics of the steering shaft
Posted: Fri May 27, 2016 6:21 am Post subject: Re: My project Doom Buggy |
Got the rear seat underside support all fabbed up last night. it will attach to the shock bolts and then down transmission mounts. that part will happen after i get the motor built and installed
Posted: Mon May 30, 2016 6:16 pm Post subject: Re: My project Doom Buggy |
just some pics of the support installed
but not 100% supported, that will come after the engine is in place
Posted: Wed Jun 08, 2016 11:26 am Post subject: Re: My project Doom Buggy |
What am i missing fir my wiper arm?
looked at many pictures and most have a nut on them this one does not
help
Posted: Thu Jun 09, 2016 6:28 am Post subject: Re: My project Doom Buggy |
nobody has any ideas?? |
