dtadpole Samba Member
Joined: November 15, 2012 Posts: 84 Location: Southern Illinois
Posted: Tue Apr 28, 2015 9:08 pm Post subject: |
Nice progress! I think my bus is your busses twin. I have all the same issues. LOL! Good work! |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14216 Location: Casa de Oro, California
Posted: Wed Apr 29, 2015 8:45 am Post subject: |
65Bugsmasher wrote: |
Edit: Anyway admin could change the thread title to 65' Velvet Green Walk Through Build |
See what happens if you go back to your first post and hit "edit". Once upon a time the originator of the thread could change the post's title. Maybe now there is a limit in time. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69733 Location: Phoenix Metro
Posted: Wed Apr 29, 2015 9:03 am Post subject: |
BarryL wrote: |
There is a time limit of 60 days.
I edited it. _________________ How to Post Photos
65Bugsmasher Samba Member
Posted: Wed Apr 29, 2015 3:23 pm Post subject: |
EverettB wrote: |
BarryL wrote: |
I edited it. |
Thanks! |
exotic plants Samba Member
Joined: January 30, 2006 Posts: 298 Location: God's Zoo
Posted: Wed Apr 29, 2015 4:30 pm Post subject: |
Engine looks like a 1300cc to me.
1300 - 1600 cc intake with 6 volt generator. _________________ 1956 Beetle - Jungle Green.
Parts needed to complete:
Front driver side fender.
Rear driver side fender.
Cash waiting.
Posted: Sun Jul 19, 2015 6:06 am Post subject: |
It's been a while since I updated this and figured I should. The bus is completely gutted and awaiting me to order the metal for it. I also ended up trading the unknown engine for a 1500cc engine that was rebuilt at some point as indicated by the stamping. The engine awaiting new pistons, which are back-ordered. While both await new goodies, I decided to start plugging away at the small stuff, kind of behind the scenes stuff that is not picture worthy. The front kick interior panels are in good shape and will be reused. Until the engine parts and metal come, I apologize for the boring pictures and behind the scene things. I guess its gotta be done sometime
Engine State: Had to clean off blue/gray paint that someone put on the block at one time. Still not perfect, but getting there.
Front Interior:
Horn Before and After:
Posted: Thu Aug 20, 2015 2:27 pm Post subject: |
Over the past month or so I put my main energy in to getting the engine back together. I decided to put bigger pistons into it (85.5mm) to take the engine from a 1500sp up to 1600sp. The only thing needed to be done is to do the timing. Below are a couple progress pics. It feels good to have a huge task completed!
glideking Samba Member
Joined: February 02, 2013 Posts: 990 Location: California
Pinetops Samba Member
Posted: Thu Aug 20, 2015 8:14 pm Post subject: |
That motor looks clean, nice work. _________________ "A rolling bus gathers no rust." |
Posted: Thu Aug 27, 2015 2:50 am Post subject: |
Motor looks awesome, looking forward to seeing the rest of your restore! Nice job thus far! |
vwbusman66 Samba Member
Joined: May 17, 2014 Posts: 386 Location: Kingsville, MD
Posted: Sat Aug 29, 2015 9:12 am Post subject: |
If you're having any issues, Bob Cook of Cooker's Vdubs is in smiths burg right near you. Not sure if you've heard of Simple Transport but that is a show that I frequent right near you.
James _________________ WANTED: Annis Morrill Corp. dealer information and stuff
1958 L53 Pressed Bumper Panel
1973 Wild Westerner
Click to view image |
Posted: Sat Aug 29, 2015 2:49 pm Post subject: |
vwbusman66 wrote: |
James |
Thanks for the advice. I actually was just at his shop and went to simple transport last weekend. Are you somewhat local to me? |
Posted: Sun Aug 30, 2015 5:12 pm Post subject: |
UPDATE:
I got a little more motivation these past 2 weeks and decided to cut the cargo floor out. I unfortunately discovered that the front top hate section needs patched and replaced at the ends, and the 2nd to rear section (c pillar) needs replaced as well. Next time is to grind down the welds and get primer on it to prevent rust from spreading.
Posted: Fri Oct 02, 2015 11:23 am Post subject: |
After completely taking everything off the bus, I am not getting ready to start doing the metal work. For convenience, I was able to find a rotisserie to make the process easier.
I plan to order the metal next month. There is more then enough to be done metal wise that does not require metal. Stay tuned to see pictures as I tear into it now. |
Posted: Wed Oct 14, 2015 6:36 pm Post subject: |
The first thing I decided to tackle was to fix the passenger side seat frames. Both seat frames were super pitted with holes through the frames and broken springs. I saw an idea on a previous thread and went with it. I used a combination of rivets, welds, and parts from other seat frames to fix these up. All in all I think it turned out well. I still need to hit the frame with a grinder to grind down the welds, then hit with a light skim coat of metal glaze to make it look real smooth.
What I started with.
What I ended with.
Frame itself.
I also decided to fill in the holes where the air scoops were. I used the trick of putting copper behind it to have the metal fill in nice. Another tedious thing down and done!
Other side complete, but no pictures, as it looks the same.
Thoughts are welcome! |
BarryL Samba Member
Posted: Thu Oct 15, 2015 7:44 am Post subject: |
Nice repairs. All those jobs go in the savings account that is the bank of your bus. All it can do is get better and better. |
Posted: Wed Nov 18, 2015 3:58 pm Post subject: Re: 65' Velvet Green Walk Through Build |
Have not gotten a chance to do much as the work schedule has been a little crazy. Was able to get pretty much all the metal though from Klassicfab. I got finished with the seat frames as seen below. I also got a chance to repair the side where the bus was shot with a shotgun. The next pictures I plan to post will be when the major welding and replacement metal goes in
Seat frames finished...still trying to find a middle seat somewhat decently priced
shot to the side
scooby_drew Samba Member
Joined: May 30, 2015 Posts: 86 Location: Plainfield, IL
Posted: Wed Nov 18, 2015 4:51 pm Post subject: Re: 65' Velvet Green Walk Through Build |
Nice work so far. Love seeing others taking it one small step at a time too! |
Posted: Sun Feb 07, 2016 4:05 pm Post subject: Re: 65' Velvet Green Walk Through Build |
Finally got a chance to start on the major metal work. I began on replacing the whole front windshield as mine was beyond crusty. Although it looks decent in the first picture, it was beyond salvageable.
The first step was to remove the outer old metal. I had to meticulously cut the old metal out and use a 3-in-1 tool to break spot welds and remove the old metal around the front lips. I had to do this to both sides, which was a time consuming nightmare. With the metal removed, you can see the rust underneath the outer lip in the pictures.
Next I had to make a new replacement piece for the wiper opening due to mine being completely gone.
After that was fixed, I replaced the inner piece with some funky green.
Unfortunately after sandblasting the inner lips that on on the dash, I discovered that they both needed to be cut out and replaced due to the shocking resemblance to swiss cheese. I mocked up the outer panel to get an idea on the angle and put a few tacs in to hold in place.
Finally I mocked up the outer green piece. I needed to cut it just after the center on both sides due to fitment issues. I used the air punch to put holes in it for plug welding. To help it stay in place, I also used self tapping screws.
Then after it all the welding was done, I spent about 5 hours today grinding down the welds and finally cut the inner lip down. I left it a tad bigger for now to help the rubber fit better for the fronts. I still need to grinding down the welds for the inner lip. I figured that was enough for 2 days..
asesapie Samba Member
Joined: March 07, 2005 Posts: 756 Location: Spokane, WA
Posted: Sun Feb 07, 2016 11:50 pm Post subject: Re: 65' Velvet Green Walk Through Build |
Nice work, it always feels great to have rust gone and new metal in. Keep it up! |
