warwgn Samba Member
Joined: November 18, 2014 Posts: 260 Location: central Mississippi
Posted: Tue May 05, 2015 9:51 am Post subject: |
TDCTDI wrote: |
It even kinda makes a VW emblem, maybe you can enhance upon it with some more sheet metal. |
I do still have about half a sheet left! |
sailtexas186548 Samba Member
Joined: December 01, 2014 Posts: 423 Location: Kemah, Tx
Posted: Tue May 05, 2015 11:16 am Post subject: |
looking good!
I would swap the fuel and oil temp gauges. RPM, oil pressure, and oil temp are (in my opinion) the most important to see in a quick glance down.
I need to get back to work you're moving way faster than I am _________________ it's more fun loud and dirty |
warwgn Samba Member
Posted: Tue May 05, 2015 12:32 pm Post subject: |
Well it's done for now, need to cut the hole for the radio and dummy lights and what ever switches I decide to put in it. Still need to figure all that out but gauge holes are there and fit gauges, after I buy the other 3 I can decide on final arrangements of the small ones.
and yeah you might want to get after it if you wanna be done before me..... |
warwgn Samba Member
Posted: Wed May 06, 2015 7:37 pm Post subject: |
Just about done with the fenders, after a light coat of primer I can see a few spots that need attention. Also started dressing up the new dash, gonna be a little eaiser than the fenders I think. Ordered some indicator light and switches today too, think they are gonna look purdy good too. Dang just realized I jumped ahead a bit, forgot to cut the hole for the radio before I started the filler work....oh well won't be to hard to do.
warwgn Samba Member
Posted: Tue May 12, 2015 4:16 pm Post subject: |
No pics today, just sanding, sanding, sanding for the past 2 days and only about half way done. Need to pick up a Gallon Of self etchin primer before the weekend and will get it all primered i hope on sunday and paint the weekend after or before then start wiring and glass and all that stuff. |
warwgn Samba Member
Posted: Tue May 12, 2015 4:28 pm Post subject: |
Took some pics anyway.
warwgn Samba Member
Posted: Sat May 23, 2015 7:27 pm Post subject: |
Working lids for the front box and some final body work.
warwgn Samba Member
Posted: Sun May 24, 2015 12:39 pm Post subject: |
Well I don't think I like doing fiberglass cloth and resin, this is a messy process and it seems I lack any technique at all for this. Hope it turns out ok. |
warwgn Samba Member
Posted: Tue May 26, 2015 7:11 am Post subject: |
fixing the gap on the front hood, slowly coming along.
turning out ok so far. |
dustymojave Samba Member
Posted: Wed May 27, 2015 12:52 am Post subject: |
Before you spend too much effort on getting a beautiful fit along the flange, keep in mind the arc of the hood as you tilt it open. _________________ Richard
SoCalBajas Member
warwgn Samba Member
Posted: Wed May 27, 2015 5:21 am Post subject: |
should not be an issue, the sides sorta hang out and are floppy if you know what I mean so they clear everything when opening and closing the hood. The problem was an uneven gap on the sides when it was closed and the sides pushed in as they would be when latched in place, which I still need to figure out how I am going to secure the sides so they don't flop around. |
warwgn Samba Member
Posted: Mon Jun 15, 2015 7:18 am Post subject: |
Wow, I lost some serious momentum, I kinda stalled out on the build a bit. Almost ready for paint just a few spots to attend too, right now I am holding until the 3rd week in July to Paint. I am picking up a new project bike on July 11th and will paint it to match the bug so want to only set up the paint booth once if I can and also saves on paint since it will already be in the gun! |
ORANGECRUSHer Samba Member
Joined: June 09, 2006 Posts: 2649 Location: West Coast (Michigan's)
Posted: Mon Jun 15, 2015 9:21 am Post subject: |
I hear ya on setting up for blasting. I just did a new bumper for the baja yesterday and I was hoping to do that along with a grill/smoker I was repainting. Unfortunately, as luck would have it my sand blaster nozzle took a dump halfway thru the bumper. Oh well. What's new?
Look forward to seeing some paint soon _________________ Brian H.
I may not know everything,but I will try to help if I can
OrangeCrushER Berrien Warrior 2.4L Quad4
LAZY MARY 1970 Baja 1835cc |
Posted: Mon Jun 15, 2015 3:47 pm Post subject: |
Here's the way I latch the hood on mine:
They are like a "draw latch" available from McMaster Carr and such places.
http://www.mcmaster.com/#standard-draw-latches/=xn1bvw
http://images1.mcmaster.com/mva/Contents/gfx/large/6139a29p1-h02dl.png?ver=1345622178
I also have 3/8" hood pins in the cowl to keep it aligned. Be sure you put a rubber washer on the pins to seal out rain and other water.
SoCalBajas Member
Posted: Mon Dec 07, 2015 2:05 pm Post subject: Re: warwgn the 72 baja |
done yet ?!?!?! _________________ it's more fun loud and dirty |
warwgn Samba Member
Posted: Fri Jul 01, 2016 10:00 am Post subject: Re: warwgn the 72 baja |
Glad I started this thread, I forgot half of what I had done. I am still about in the same spot I was, just a lot of shit happened this year so trying to get back on track soon. I have built a motorcycle and boat so the bug got put to the side while that was going on but after reading this whole thread again I am getting the itch back..... |
tobiism Samba Member
Joined: January 21, 2004 Posts: 502 Location: Chandler AZ
Posted: Tue Apr 25, 2017 4:47 pm Post subject: Re: warwgn the 72 baja |
Any updates? _________________ "There has never been a genius without a hint of madness."
-Albert Einstein |
warwgn Samba Member
Posted: Fri May 05, 2017 6:01 am Post subject: Re: warwgn the 72 baja |
Only update so far is my Divorce was final in January
I have a new Motorcycle and a boat that got me sidetracked along with the divorce and junk, but not to fear I am getting back on track, have started dating a tall blonde nurse so my creative side is waking back up and I am ready to get back out in the shop. |
warwgn Samba Member
Posted: Mon Feb 05, 2018 2:39 pm Post subject: Re: warwgn the 72 baja |
Trying out this new photo add stuff. This is what I came up with my side latch for the flip front end, it's a draw latch I took off of a military storage box I had. I welded the mating tab in place then will still need to drill a couple holes and bolt the wing tab part to the fiberglass.
I am sure nobody remembers but this is just to keep the sides from flapping in the wind, I have two large locking hood latches on the top to keep it down. I will add more pics soon and kinda give a brief refresher of my build with photos before I get full sped back into this.....well maybe half speed this time. |
warwgn Samba Member
Posted: Mon Feb 05, 2018 2:40 pm Post subject: Re: warwgn the 72 baja |
holy crap that pic came out huge!!! |
