ritchiet002 Samba Member
Joined: January 27, 2003 Posts: 1676 Location: Kaneohe, HI
Posted: Wed Aug 20, 2014 3:41 pm Post subject: |
Would this work? For those without air? I used mine on my gates and latches and then replaced all the screws with SS. Haven't gotten to the doors yet, but then I don't have a major rust problem in that area.
_________________ Somewhere there is a jar with your name on it!
From now on, I'm gonna connect the dots my own way!______________________________________
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24738 Location: Olympia Wash Rinse & Repeat
Posted: Wed Aug 20, 2014 5:50 pm Post subject: |
ritchiet002 wrote: |
Image does not seem to work! _________________ In Stereo, Where Available! |
Posted: Wed Aug 20, 2014 6:02 pm Post subject: |
FIXED! _________________ Somewhere there is a jar with your name on it!
From now on, I'm gonna connect the dots my own way!______________________________________ |
icekoffee Samba Member
Joined: March 14, 2005 Posts: 1239 Location: DeSoto, Missouri
Posted: Sat Jul 23, 2016 10:04 am Post subject: |
Bringing up an old thread but does anyone have a current link to this tool or the name of it?
Thanks! _________________ 1952 Zwitter
1959 23 Window
1963 Doubleturd
1958 Patina Beetle EJ25
1984 Vanagon Westfalia EJ25
1964 Lifted Mouse Grey Standard
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Sat Jul 23, 2016 10:51 am Post subject: Re: How to remove those 60 year old mangled door hinge screws? |
Thank you very much! _________________ 1952 Zwitter
1959 23 Window
1963 Doubleturd
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
Help Help Samba Member
Joined: May 03, 2013 Posts: 117 Location: Running willy-nilly with scissors in So Cal
Posted: Sat Jul 23, 2016 10:57 am Post subject: Re: How to remove those 60 year old mangled door hinge screws? |
I MIG welded some really large nails (1/2 thick) on to the heads of the screws and then took a wrench to the head that I had ground some flats on and they came out easily. The Thermal shock of being welded really helped and the point of the nail fit great in the mangled screw head. |
6t3bird Samba Member
Joined: February 08, 2014 Posts: 38 Location: Long Island, NY
Posted: Sat Jul 23, 2016 11:03 am Post subject: Re: How to remove those 60 year old mangled door hinge screws? |
Hey, if you don't have time to wait around for the tool than you can weld a hardened bolt to a c clamp and and then pop that sucker right out with a impact wrench. Of course you have to put a wrench or socket over the pin head so it can move. I got all mine out this way and they were in same shape as yours. Tool took 5 mins to make, think I used a 6" c clamp. Don't forget the PB blaster. |
esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
Posted: Sat Jul 23, 2016 11:38 am Post subject: Re: How to remove those 60 year old mangled door hinge screws? |
I've just dealt with some that were rusted solid from 40 years sitting. Trust me there was NO way the impact driver was getting them out, it sheared the "philips" right out of the screw heads. I used a 3/8" drill bit to remove the screw heads, which allowed me to pull the doors. Then center drilled each remaining stud with increasingly larger bits till I just touched the threads. Then an M8 tap cleaned the body threads the rest of the way. Tedious, but it works. _________________ modok wrote:
BarryL Samba Member
Joined: November 01, 2004 Posts: 14259 Location: Casa de Oro, California
Posted: Sat Jul 23, 2016 6:49 pm Post subject: Re: How to remove those 60 year old mangled door hinge screws? |
6t3bird wrote: |
Hey, if you don't have time to wait around for the tool than you can weld a hardened bolt to a c clamp |
Photo? |
Posted: Thu Jul 28, 2016 8:15 pm Post subject: Re: How to remove those 60 year old mangled door hinge screws? |
This is the greatest tool ever! It works so well
1959 23 Window
1963 Doubleturd
1967 21 Window
1968 Double Bubble
1969 Westfalia
1961 Ragtop Beetle
1984 GTI
1961 Kombi |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Thu Jul 28, 2016 8:21 pm Post subject: Re: How to remove those 60 year old mangled door hinge screws? |
Just ordered one, can't wait to try it out _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
