bug_n_67 Samba Member
Posted: Sat Jul 19, 2014 10:50 am Post subject: Height difference in Heads |
So I was just replacing my jugs and piston and when I when to put my heads on one didn't seem to fit down as far as the other side. So I pulled them off switched them around to see if it was the jugs not right or the heads. As you can see from the pictures there is a difference on how the head sits. So do I worry about this, do I shim the other side so I have the same height for both sides. Or something maybe?
John |
stan_tichomirov Samba Member
Joined: May 24, 2005 Posts: 1719 Location: San Francisco, CA
Posted: Sat Jul 19, 2014 11:04 am Post subject: |
Are they different castings? Could be the picture, but the one on the right looks to have one less cooling fin then the left.
Stan _________________ Aircooled.net
Jansen Enterprise
My 1835cc build
My budget 2276 build |
Posted: Sat Jul 19, 2014 11:28 am Post subject: |
Well Stan you were right on, cooling fines are pretty much the same but they are different castings. One says Mexico the other says 2BR. So should I use them or try and find a matching pair?
PumaVW79 Samba Member
Joined: January 31, 2012 Posts: 487 Location: WGS84: 22.9083° S, 43.1964° W
Posted: Sat Jul 19, 2014 12:07 pm Post subject: |
Measure the chambers volume
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Jul 19, 2014 1:21 pm Post subject: |
PumaVW79 wrote: |
Ditto...
External appearance mean very little if they seat properly, combustion chamber size is everything...
Actually the ...
043-101-375R head is 33 mm intake 30mm exhaust - fuel injection head...
040-101-375H head is 35.5mm intake and 32 mm exhaust , Brazilian replacement head...
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Sat Jul 19, 2014 1:30 pm Post subject: |
The 043 mexico head originally had a step in the chamber, the 040 did not. Yes you should CC the heads to make sure they match |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Sun Jul 20, 2014 2:04 pm Post subject: |
Check the valve sizes too...... _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
Posted: Sun Jul 20, 2014 6:06 pm Post subject: |
They are all the same
8mm stem
32mm exhaust
35.5mm intake |
Thomas333is Samba Member
Posted: Thu Jun 23, 2016 3:58 am Post subject: Re: Height difference in Heads |
I also
Just buy 2 haeds, they have the same part number but one is A
and other is R. Some say,!they are different valve diameter. I don't know who right or wrong
Thanks |
rockurob Samba Member
Joined: August 23, 2009 Posts: 358 Location: Okla City, Oklahoma
modok Samba Member
Posted: Thu Jun 23, 2016 5:30 pm Post subject: Re: Height difference in Heads |
Thomas333is wrote: |
I also
Thanks |
I think you will find they are a set.
If you told the whole part number the might be more to say about it. |
