GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Tue Jan 19, 2016 5:54 am Post subject: Re: The Stupid Question Thread |
adam78 wrote: |
I always jack mine up in the front first. This way, I have the hand brake and car in gear to stop it from rolling as apposed to nothing in the front. I put my jack on the front axle, it lifts the whole car up, then I put jack stands near the wheels on the axle. |
thanks, now I just have to figure out how to fit a trolley jack inside my extra-small garage! _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
vamram Samba Member
Posted: Wed Jan 20, 2016 2:09 pm Post subject: Re: The Stupid Question Thread |
What does it mean that a gear is "taller?" What makes a gear tall or short? Number of teeth on a wheel...? _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
EVfun Samba Member
Posted: Wed Jan 20, 2016 5:29 pm Post subject: Re: The Stupid Question Thread |
"Taller" means the same as "higher" when referring to gears, which means numerically lower. 4th is taller (higher) than 3rd, 3rd is taller than 2nd, 2nd is higher than 1st. Likewise, a 4.375 R&P is "shorter" or "lower" than a 4.125.
Taller gears (higher gears) are harder to climb, they give more vehicle speed at any given engine RPM. _________________
Wildthings wrote: |
vamram Samba Member
Posted: Wed Jan 20, 2016 5:59 pm Post subject: Re: The Stupid Question Thread |
EVfun wrote: |
"Taller" means the same as "higher" when referring to gears, which means numerically lower. |
Thanks for trying...but ya lost me right there. So 3rd is taller than 4th because 3 is numerically lower than 4th??
Then what reads to me like the opposite -
EVfun wrote: |
4th is taller (higher) than 3rd, 3rd is taller than 2nd, 2nd is higher than 1st. Likewise, a 4.375 R&P is "shorter" or "lower" than a 4.125. |
EVfun wrote: |
Taller gears (higher gears) are harder to climb, they give more vehicle speed at any given engine RPM. |
Ok, that one makes sense to me. Kinda. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Thu Jan 21, 2016 9:34 am Post subject: Re: The Stupid Question Thread |
vamram wrote: |
EVfun wrote: |
The RATIO is numerically lower, NOT the gear position, i.e. 3rd, 4th etc.
EVfun wrote: |
EVfun wrote: |
You've pretty much got it here. |
Taller gear has the same effect as a taller tire. More speed for the same rpm but less oomph. _________________ "Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote: |
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it. |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sat Feb 13, 2016 3:22 pm Post subject: Re: DF and D+ reversed? |
EDIT: I moved this question to the Late Model thread in the hopes of better input. See thread titled "Gen/Alt and voltage regulator relationship questions"
Last edited by Wasted youth on Sat Feb 13, 2016 7:47 pm; edited 3 times in total |
vamram Samba Member
Posted: Sat Feb 13, 2016 3:47 pm Post subject: Re: The Stupid Question Thread |
Sounds more like a post to the '68-up Bug forum than a stupid question post. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Sat Feb 13, 2016 3:56 pm Post subject: Re: The Stupid Question Thread |
vamram wrote: |
Sounds more like a post to the '68-up Bug forum than a stupid question post. |
Yeah, maybe so. I just felt like an idiot asking this. |
vamram Samba Member
Posted: Sat Feb 13, 2016 3:57 pm Post subject: Re: The Stupid Question Thread |
Wasted youth wrote: |
vamram wrote: |
Oh, you know how it is around here...even if it's not a stupid question, SOMEONE will make ya think it is! _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
tangot2 Samba Member
Joined: May 21, 2015 Posts: 9 Location: Grand Prairie, TX
Posted: Tue Feb 16, 2016 2:33 pm Post subject: Re: The Stupid Question Thread |
I'm aligning the front end of my 65 Beetle. On the drivers side the tie rod end has 2 bolts and a anti undo washer. On the passanger side are just bolts on the end of the tie rod. I got the tire side bolt loose. The inside one just seems to spin. Do I need to clamp on vice grips on the tie rod to hold it so I can break it loose? Thanks. _________________ TangoT2
><(((°> ><(((°> <x)))>< ><(((°>
Only dead fish go with the flow.
65 SID Beetle |
Vdub_SuperBug_72 Samba Member
Joined: February 22, 2016 Posts: 2 Location: Ventura, CA
Posted: Mon Feb 22, 2016 4:37 pm Post subject: Re: The Stupid Question Thread |
So here's stupid question that I need to figure out the answer to before I can puchase a new exhaust system for my 72 super beetle...
Are there different sized 2 bolt flanges for exhaust, or are they all the same? Is the size of the exhaust determined by the exhaust port on the heads? How can I measure the size so that I can order the correct header, or does it not necessarily matter?
Sorry for my ignorance as I'm 17 and it's my first car. Any help would be appreciated, Thanks!!!! |
jonnyrose Samba Member
Posted: Tue Feb 23, 2016 10:02 am Post subject: Re: The Stupid Question Thread |
howdy heres my latest stubid question,i have a Baja bug the pan is a 1962,but I think the body is newer,it has rear window defroster,and padded dash,also has wiper switch on columb,any ideas on the year? |
vamram Samba Member
Posted: Tue Feb 23, 2016 10:07 am Post subject: Re: The Stupid Question Thread |
jonnyrose wrote: |
'72 was the start of the wiper switch on the column. Defroster was earlier. _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
Posted: Tue Feb 23, 2016 4:42 pm Post subject: Re: The Stupid Question Thread |
thanks for the reply,i was guesing 1972,it also has a factory gas heatre |
SLC74 Samba Member
Posted: Tue Mar 01, 2016 10:55 am Post subject: Re: The Stupid Question Thread |
I'm going to get my stupid questions out of the way while I still have a low post count
The two handles between the seats, one says defrost and one says heat. I haven't noticed a difference when they are up or down. What the heck do they do? The fan dial is on the dash, right? And the little button to the left of the steering wheel makes a loud MEEP MEEP when I push it. Is that normal?
Next up, find the Super Shimmy this weekend and order all new steering components. |
hannahler Samba Member
Joined: November 09, 2014 Posts: 19 Location: Washington
Posted: Wed Mar 02, 2016 11:08 pm Post subject: Re: The Stupid Question Thread |
Parts I need. Where to buy? I'm pretty accustomed to buying some body parts and other stuff from Rock Auto for my PT Cruiser, but we recently bought a repeater for my 1972 from them and they were crap. I'm not sure how well I can trust them for this stuff. I've seen jbugs but they're pricey, and my boyfriend recommended O'Reilly's but they don't carry a lot of stuff I need. I also got a copy of a catalog from mid america motorworks but that's almost TOO nice for me! We also have a Bow-wow euro imports about an hour away but I want something online that can be a little more convenient. I'm just not sure what order of websites I should be checking parts for! there's just so many! I even peeked at amazon but that was a crap shoot too
tl;dr best recommendations to buy parts? _________________ 1972 VW Super Beetle |
67jason Samba Member
Joined: August 28, 2005 Posts: 4741 Location: behind my back feet - Pittsburg CA
Posted: Wed Mar 02, 2016 11:43 pm Post subject: Re: The Stupid Question Thread |
hannahler wrote: |
tl;dr best recommendations to buy parts? |
cip1.com _________________ 67 bug x3
67 ghia
64 bug |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
Posted: Thu Mar 03, 2016 6:30 am Post subject: Re: The Stupid Question Thread |
hannahler wrote: |
Wolfsburg West, West Coast Metric, CB Performance, Airhead Parts, Aircooled.net. Most of the cheap stuff is pure crap, and even some of the better stuff is too. Keep as much of the original German stuff as you can. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
jgvt88 Samba Member
Joined: February 17, 2014 Posts: 5 Location: Fort Wayne
Posted: Fri Mar 11, 2016 5:54 pm Post subject: Re: The Stupid Question Thread |
I don't want to be the guy asking before doing a search, but it's difficult to do a search when you don't know what a part is called!
The green and white thing that I had to remove to access the fresh air box. (Come to think of it, is that called a fresh air box? What's that part called that houses the blower?)
I assume it has something to do with the fuel tank emissions controls. I'm guessing it's also why I get that gasoline smell in the cabin.
vamram Samba Member
Posted: Sat Mar 12, 2016 6:13 am Post subject: Re: The Stupid Question Thread |
The white plastic triangular container is the expansion chamber for recirculation of fumes from the gas tank. The green tube is part of that system too. One of the lines leads to a charcoal canister mounted inside the right rear wheel well. That canister should have a has a hose at that top that runs from the top right of the fan shroud and a return hose from the bottom that runs to a fitting on your air filter. So unburned gas fumes get recirculated into the intake.
By now, that charcoal canister either needs to be rebuilt or has been removed altogether so you're venting fumes into the atmosphere.
You have disconnected hoses so you probably get a "healthy" dosage of raw gas fumes when you drive the car, especially after filling the tank.
This thread explains it all, w/picutures!
http://www.thesamba.com/vw/forum/viewtopic.php?t=389074 _________________ Eventually, "we are what we pretend to be.’”
Click to view image
Save the Supers!! |
