rs58rag Samba Member
Joined: August 22, 2010 Posts: 419 Location: riverside,ca
Posted: Sun Aug 16, 2015 6:20 pm Post subject: |
Rust and nug......did you ever check the ohms output on primary and secondary circuits of your coils....bad wires and/or bad plugs can cause voltage overload....once that coil is overheated, it can cause hit and miss issues. |
rusty shackleford Samba Member
Posted: Tue Jun 21, 2016 12:56 pm Post subject: Re: Need advice on a condenser problem. |
Haven't posted in quite a while, not sure this needs its own separate subject, but:
Had a Bosch condenser fail at about 1000 miles, had to change it on the freeway left shoulder. Actually later re-installed the one that failed to confirm the failure would repeat, it did.
This is the second condenser I've had fail. The first one was conveniently at my house, but took a while to trouble shoot.
Anyway, local shops say "all the new production Bosch condensers will fail" and they've stopped selling them. Also they say they've contacted Bosch but "Bosch doesn't care".
I'm running a Rabbit condenser now, it kinda fits.
So, am thinking I might post a harshly-worded video ... would that be out of line ?
Thanks,
RS |
timvw7476 Samba Member
Posted: Tue Jun 21, 2016 11:40 pm Post subject: Re: Need advice on a condenser problem. |
Well, they don't put the part # or the classic Bosch "magneto", or
whatever that was, on them anymore either.
Maybe that's warning enough? |
Rustforlife Samba Member
Joined: August 24, 2007 Posts: 588 Location: Texas-y'all
Posted: Sat Feb 11, 2017 2:33 pm Post subject: Re: Need advice on a condenser problem. |
Necromancing a dead thread with an update...
I was cleaning the garage a few weeks ago, and found the .010. Dug out an old condenser from my pile, spliced a connector to it and put it and the .010 on the engine.
Zero issues so far. So unless I post up with another dead condenser story, consider this closed.... Thanks for all the advice, guys! _________________ 1956 Ragtop |
wcfvw69 Samba Purist
Posted: Sat Feb 11, 2017 5:34 pm Post subject: Re: Need advice on a condenser problem. |
Kind of scary, the amount of the "new" Bosch condensers failing. I've actually never experienced a condenser failure. I haven't installed any new Bosch condensers. The last batch of points and condensers I bought was about 10 years ago and I still have some left. Lately, I've been checking the used Bosch condensers in used distributors I buy that are made in Germany and run them if they check ok.
My bus distributor had an original Bosch condenser from the 70's in it when I bought it at a swap meet. The distributor had clearly sat on someone's shelf for decades after the vacuum can blew. After rebuilding the distributor, I checked the used Bosch points and the condenser (which checked out fine) and have run them for 6k trouble free miles since.
I think people were very quick to throw out points and condensers at a certain "mileage" on them. In many cases, they were still good. There's lots of VW veteran owners who've run the same condenser for decades. They only change the points when they are worn out. _________________ Contact me at [email protected]
The Samba member since 2004.
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Sat Feb 11, 2017 5:46 pm Post subject: Re: Need advice on a condenser problem. |
Can't find a good condenser?
Polyester film capacitors have been known to last a LONG time, and should be readily available. Condensers from other makes can be used. You can test them with a tester and find out the values.
I don't have any interest in it, but it might be of help to you. |
Posted: Fri Sep 08, 2017 3:27 pm Post subject: Re: Need advice on a condenser problem. |
Back from the dead. I have not driven the car that much, life and the Texas heat/humidity puts a damper on the fun...
Well, it killed another condenser- that one I spliced the connector onto. I guess I'm stuck with the Chinese .009. _________________ 1956 Ragtop |
Frank Bassman Samba Member
Posted: Sat Sep 09, 2017 10:01 am Post subject: Re: Need advice on a condenser problem. |
Hey Rustforlife, have you considered an electronic ignition adaptation using points? Get rid of the problem forever. And use your 010.
-Frank |
Posted: Mon Sep 11, 2017 5:41 am Post subject: Re: Need advice on a condenser problem. |
Frank Bassman wrote: |
-Frank |
It had one in the chinese distributor, and it died right after I bought the car in 2011.
*edit* Can an otherwise operational alternator be the culprit? _________________ 1956 Ragtop |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Mon Sep 11, 2017 11:55 am Post subject: Re: Need advice on a condenser problem. |
What's your C/R? |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Mon Sep 11, 2017 1:25 pm Post subject: Re: Need advice on a condenser problem. |
I've also had bad luck with the new Bosch condensers on a German 009. Now I'm running a 034 with a condenser that's probably 30 years old and no more issues. I used to toss unknown condensers into the round file as a matter of "maintenance" but not anymore. Seems the quality of the new ones is very poor.
Actually there was a thread here somewhere where someone cut open a old one, and a new replacement to see if there was a difference. The new one had crappy insulation between the coils, and had almost none on the bottom of the coils and they would short out to the housing and burn up. I can't find the thread, but I'm sure it's here somewhere if someone wants to hunt it down.
It's just another replacement part that sucks right out of the box. If someone knows a part from another make/model that works, and will last, that would be good info to post for everyone to know. |
Posted: Mon Sep 11, 2017 8:00 pm Post subject: Re: Need advice on a condenser problem. |
Pruneman99 wrote: |
I continue to hear Echlin brand points and condensers from Napa are now the best to get. Robbie in the bay forum is at 35k miles on a set right now.
I also don't throw out German 70's condensers on used distributors either. _________________ Contact me at [email protected]
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2739 Location: Hamble, Hampshire, UK
Posted: Tue Sep 12, 2017 10:40 am Post subject: Re: Need advice on a condenser problem. |
One thing missing in this is the type of construction of capacitor used in the condenser., specifically the plastic dielectric.
Some types can self heal if subjected to a very high voltage like if you pull a plug wire without connecting it to a plug and let it zap across a gap of an inch.
Each time they heal they lose a bit of capacitance and eventually to points will burn and the spark will weaken.
Other types of capacitor will just short if they break down. _________________ Ancient vehicles and vessels
Posted: Wed Sep 13, 2017 12:38 pm Post subject: Re: Need advice on a condenser problem. |
FreeBug wrote: |
What's your C/R? |
8-something to 1. Got it written down somewhere.... _________________ 1956 Ragtop |
Posted: Wed Sep 13, 2017 1:28 pm Post subject: Re: Need advice on a condenser problem. |
Rustforlife wrote: |
FreeBug wrote: |
What's your C/R? |
8-something to 1. Got it written down somewhere.... |
ok, so that's not it...thought maybe the spark would have trouble jumping if you had said 13:1. |
Posted: Thu Apr 05, 2018 9:03 am Post subject: Re: Need advice on a condenser problem. |
Back again.
It killed another condenser. Engine was idling then just stopped, as if I had turned the ignition off. Tried to restart to no avail, had to push it through a busy 4 way intersection into a parking lot. Pulled the distributor, swapped in a new condenser and it fired right up.
Here's the difference: it wasn't the .010 this time. The Chinese .009 was installed, and I believe that it was the first time I had a failure with this distributor since the Compufire crapped out way back when.
A friend suggested using an external resistor... opinions?
Thanks again, guys. _________________ 1956 Ragtop |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Apr 05, 2018 9:23 am Post subject: Re: Need advice on a condenser problem. |
I have to love my Compufire.... 15 years so far and not a issue....
Posted: Thu Apr 05, 2018 6:08 pm Post subject: Re: Need advice on a condenser problem. |
Back again.
Thanks again, guys. |
I didn't read this whole thread but wonder if you're installing "new" condensers or NOS Bosch ones? The "new" Bosch ones can be problematic with quality. I only run NOS German made Bosch condensers now in my VW's. I install them in my restored distributors that I sell as well.
I also purchased a vintage 60's Merc-o-tronic ignition/coil/condenser tester and had it repaired and calibrated.
I check ALL condensers now with it that I mount on distributors that I restore. I find most used German Bosch condensers test perfect as well.
If you want to send me your bad condenser or more, let me know. I'd check them for free to see what they do on the machine. _________________ Contact me at [email protected]
Posted: Fri Apr 06, 2018 9:07 pm Post subject: Re: Need advice on a condenser problem. |
wcfvw69 wrote: |
If you want to send me your bad condenser or more, let me know. I'd check them for free to see what they do on the machine. |
Sure, Pm me your address and I’ll do that. Thanks. _________________ 1956 Ragtop |
modok Samba Member
Posted: Fri Apr 06, 2018 10:54 pm Post subject: Re: Need advice on a condenser problem. |
If I wanted a bulletproof condenser I would substitute a polyester (PET) capacitor of similar value, or... something like that....well I'm not an electronics guy but I'm sure that there is a better condenser out there and it probably costs a whole 3$, in this day and age.
Probably has been done. http://www.nonlintec.com/sprite/cap_failure/
But I have no desire to do that, I rather use a TFI module. |
