dbsmith Samba Member
Posted: Sat Mar 07, 2015 10:34 pm Post subject: Manxter#127 |
I hadn't figure out the rear seats yet, so I welded in a bracket to mount a bar to. The Weld-in Bung at the bottom is for the rear seat belt.
It's not cardboard but NASA approve 2x4's. Just something to mount the $25 Miata seats to.
Speaking of seat brackets, I saw a new one that Brad is making for PRP, and it's on the gotta have list. I'll try to get a couple on order.
I got the column all done and the dash tub mounted today besides the yard work.
David _________________ dbsmith
SoCal
#127 Manxter - 99.5% done.... |
sbussard Samba Member
Joined: April 19, 2011 Posts: 432 Location: Pittsburgh, PA (near enough)
Posted: Sun Mar 15, 2015 6:23 pm Post subject: |
Coming right along David! I've been hibernating through the winter and haven't been on the Samba much. I caught up on your progress and pictures tonight. This will be one top notch buggy when done. Budget, who needs a stinkin' budget! _________________ Manxter #122
First time, garage built, and living out the childhood dream of owning a life-size Hotwheel!
Check out my build thread-->My Manxter 2+2 |
Posted: Sun Mar 15, 2015 7:00 pm Post subject: Manxter #127 |
Time to come outside and do a photo shoot
And look the gas lifts are upside down.. If you can't do things 2 or 3 times it's not woth doing at all.
I spent a while trying to get the the gas lift to seat correctly, finally realized a little nut was inside.
Here's smiling at ya..
SoCal
Posted: Sun Mar 15, 2015 9:45 pm Post subject: Re: Manxter #127 |
dbsmith wrote: |
I spent a while trying to get the the gas lift to seat correctly, finally realized a little nut was inside. David |
I think it was the big nut that was really the problem!
Your punch list is getting shorter. Driving this summer?
Scott _________________ Manxter #122
Iguana Samba Member
Posted: Sun Mar 15, 2015 10:18 pm Post subject: |
looking good, you gunna make Big Bear |
jrailer Samba Member
Posted: Sun Apr 05, 2015 6:55 pm Post subject: |
How did i not see this last progress report looking great i still need to get the balls to mount the windshield and top |
Posted: Sun Apr 05, 2015 8:28 pm Post subject: |
Measure 12 times.
If things don't look right just walk away and come back to it later and ask questions.
I've kinda slow lately, been working on a bar to hold the battery and oil cooler. Then on to the side bars and step. Got to play with the bender. Cool having the right tool and a bitch when you don't. _________________ dbsmith
SoCal
Posted: Sat Apr 11, 2015 4:26 pm Post subject: Manxter #127 |
While others are at Buellton this weekend, I got started playing with the tubing bender.
SoCal
Posted: Sat Apr 11, 2015 8:54 pm Post subject: |
Looking good |
Posted: Mon Apr 20, 2015 5:35 pm Post subject: Manxter #127 |
A little bit everyday helps grandpa keep his sanity
SoCal
Posted: Sun Apr 26, 2015 6:25 pm Post subject: Manxter #127 |
Put a rack above trans to carry the battery and oil cooler
SoCal
TSFR Samba Member
Joined: May 14, 2013 Posts: 365 Location: Columbia, SC
Posted: Mon Apr 27, 2015 9:32 am Post subject: |
You are a BADASS David! It's really starting to come together. How did you cut your gauges and can you make me a rack please? _________________
Thanks,
Jeff
Manxter 2+2 #160 |
Posted: Mon Apr 27, 2015 12:16 pm Post subject: |
Brad cut it out for me. Using heavier aluminum. I ended up sand blasting it and using a clear coat. The clear was a little thick so it spattered out of the gun and gave me a textured finish.
Don't thick you'll have room for a rack. The 2" lift gave me lots of room. But I'll help you build anything you want. Just come on by. _________________ dbsmith
SoCal
Posted: Thu May 14, 2015 7:56 pm Post subject: Manxter #127 |
I wanted to build a battery box, so got a little distracted and built a metal brake. Ya can't have too many tools.
SoCal
Posted: Fri May 15, 2015 3:18 am Post subject: |
Rack looks very nice! As for the battery box, oh look, a squirrel...Any time in the shop is good.
Posted: Thu May 21, 2015 4:16 pm Post subject: |
What year gas tank has everybody had the most success with? _________________ dbsmith
SoCal
Posted: Fri May 22, 2015 1:13 pm Post subject: |
71 standard bug works great
Posted: Fri May 22, 2015 6:30 pm Post subject: |
Jim
Do you have pics of the filler neck?
And what did you use for the neck and cap? _________________ dbsmith
SoCal
Posted: Fri May 22, 2015 6:45 pm Post subject: |
I will get you a shot of it. It was a filler I had at work I think it was off a land Rover it had a good area to clamp a hose |
Posted: Fri May 22, 2015 6:55 pm Post subject: |
This works ok for now I might get a new tank and have a filler neck welded to it later on |
