1978 Champagne Bus VR swap aka BUSTDBVR
Page: Previous  1, 2, 3 ... 13, 14, 15, 16, 17  Next
forn
forn is offline
PostPosted: Fri Aug 21, 2015 6:27 am    Post subject: Reply with quote
Here are some rough cuts of what I am gonna try.I will box in the top so air has to be slammed down and out.Still have to get a fan and shroud.
Bansheelos
Bansheelos is offline
PostPosted: Mon Aug 24, 2015 5:51 am    Post subject: Reply with quote
Looks good. Sounds like it will definitely work!!! Just get some high CFM fans and you will be good.
Just me and my Bus!
http://www.thesamba.com/vw/forum/viewtopic.php?t=540073
secretsubmariner
Champagne Wrangler
secretsubmariner is offline
PostPosted: Tue Aug 25, 2015 1:20 pm    Post subject: Reply with quote
Good luck with your issues, man.
Hey, in the nature of gathering more information about our champagnes, do you care to decode your m-plate and post it? If not, would you mind snapping a pic of the m-plate with all the numbers and sending it to me? I'm compiling pictures and build dates of champagnes
-Tony
ᏣᎳᎩᎯ ᎠᏰᎵ
1978 Champagne Edition Bus FI
1970 Auto Fastback FI
Bansheelos
PostPosted: Wed Aug 26, 2015 1:03 pm    Post subject: Reply with quote
Yeah was just looking at your thread and seeing how to find this M plate you speak of! lol
Just me and my Bus!
Tcash
Tcash is offline
PostPosted: Wed Aug 26, 2015 1:11 pm    Post subject: Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?p=7551789#7551789
http://alltheprettybuses.com/_d_decoder.asp
http://www.vw-mplate.com/mcode.php
Bansheelos
PostPosted: Tue Sep 08, 2015 9:14 pm    Post subject: Reply with quote
Still going! Getting ready for the Flanders all aircooled show!
Just me and my Bus!
vwwestyman
vwwestyman is offline
PostPosted: Tue Sep 08, 2015 9:26 pm    Post subject: Reply with quote
Well how on earth are you going to take it to an all aircooled show? Very Happy
I was able to get a pic of my m plate by holding my phone up in there. Took a few tries to get it aimed right but was able to get a readable shot.
Dave Cook
1973 Wild Westerner
My Thing
Bansheelos
PostPosted: Wed Sep 09, 2015 4:40 am    Post subject: Reply with quote
Drive really slow, stick my head out the window and make the aircooled motor noise? Lol
Just me and my Bus!
forn
forn is offline
PostPosted: Wed Sep 09, 2015 5:59 am    Post subject: Reply with quote
It cools and will get on down the road.Header wrap made all the differance in the world reducing engine bay temps.
Bansheelos
PostPosted: Wed Sep 09, 2015 7:33 am    Post subject: Reply with quote
Looking good! Funny thing you said that, my exhaust wrap will be delivered tomorrow!
Just me and my Bus!
panel
panel is offline
PostPosted: Wed Sep 16, 2015 10:58 pm    Post subject: Reply with quote
Do they make you park with all the water-cooled guys when you're at a show? Just kidding...........great build , just read all 14pgs!
My '65-Subaru EJ20 Turbo conversion
Sloride
Sloride is offline
PostPosted: Thu Sep 17, 2015 4:34 am    Post subject: Reply with quote
Header wrap helped my engine bay temp as well. Worth the upgrade in my opinion.
1972 Westfalia - 1.8 VW in-line h2o conversion
Ottawa, Ontario, Canada
Link to the engine swap:
http://www.thesamba.com/vw/forum/viewtopic.php?t=565304&highlight=
1964 Ruby Red Beetle
https://www.thesamba.com/vw/forum/viewtopic.php?t=705757&highlight=ruby+red
Bansheelos
PostPosted: Fri Sep 18, 2015 10:56 am    Post subject: Reply with quote
Wrap is on. Gonna wrap the exhaust manifold but I need to get some safety wire. Has Anyone used safety wire to secure the wrap on?
Just me and my Bus!
Sloride
Sloride is offline
PostPosted: Sat Sep 19, 2015 3:41 pm    Post subject: Reply with quote
I've used a stainless hose clamp in a pinch.
Bansheelos
PostPosted: Mon Sep 21, 2015 8:02 am    Post subject: Reply with quote
Took the BVR to the all aircooled gathering in Flanders NJ. Had an awesome time. Let the kids run around it was an awesome show! The exhaust wrap and and engine sealing made a huge difference in cabin temps!!!
Just me and my Bus!
BusPriest
BusPriest is offline
PostPosted: Mon Sep 21, 2015 6:20 pm    Post subject: Reply with quote
Did you sort cooling out?
1977 Champagne Transporter Custom Camper.
SOHC EJ25, tubbed, wagenswest
Work in progress build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=619684
Not a Priest.
Bansheelos
PostPosted: Mon Sep 21, 2015 9:59 pm    Post subject: Reply with quote
Been going through templates and I'm so low that I cannot get a scoop under. Trying to run ductwork from the front of the bus is almost impossible w/ my height of the beam. There is a hole where the heater tube goes through that I tried to use today but really how much of that 3" of air going to remedy the situation. Thinking about coming off the sides. Getting an oil cooler. Bigger thicker radiator or run the rads in the engine bay.
Just me and my Bus!
Sloride
Sloride is offline
PostPosted: Tue Sep 22, 2015 4:26 am    Post subject: Reply with quote
I'm not sure if I mentioned it to you or not but I installed an oil cooler and while I never had any overheating issues I found that it helped especially on long climbs. I run one off of the oil filter stand. A Volvo sandwich plate with the cooler mounted underneath out by the entry scoop to the rad. Oil temps are never higher than 185 even on the hottest of days.
I wonder if the fact you are so low it is restricting the air flow?
Craig
vwwestyman
PostPosted: Tue Sep 22, 2015 5:06 am    Post subject: Reply with quote
As one of the newest converts to be sold on under-bus radiators, I am afraid that you are really going to struggle with cooling with as low as your bus is. There simply isn't much room!
You might have to have not only the belly radiator but also engine compartment radiators too, all plumbed in series. The engine compartment doesn't see lots of air flow being forced through it while driving, it seems that the engineers were relying on the vacuum created by the fan to get the air in there. Look into a pair of those clear plastic "Earz" (I think that is what they're called) to turn them into more of a scoop and push air through the radiators.
Another idea I kicked around but didn't really try was a couple motorcycle radiators up front somehow hanging from the beam. It seemed like to me that area probably has a good deal of air flowing through it.
Dave Cook
1973 Wild Westerner
My Thing
Bansheelos
PostPosted: Wed Sep 23, 2015 5:57 am    Post subject: Reply with quote
Idea
Just me and my Bus!
Page 14 of 17
